TECH?! Shoebox trunk floors with Mustang tank
Discussion in 'The Hokey Ass Message Board' started by Big A, Sep 6, 2011.
  1. It's a simple enough and common enough job to throw a Mustang tank in a '49-'51 Ford. 1x1 between the frame rails and a simple frame of 1" angle to set the tank in will keep it pretty level and keep it off the ground. I happened to have the body off while I swapped my frame, but when I first installed the Mustang tank the body was on. That's the easy part...
    I lost some sleep trying to figure out how the heck to finish the sheet metal in the trunk. I don't have a lot of tools, very little time, no experience and not a lot of brain-smarts at the best of times. I do have a highly engineered hillbilly bender that is accurate to within a foot as the crow flies, that also doubles as a stand for my cheapo bead roller that I beefed up a bit…
    I used some poster board to make a template. Lots of cutting and taping and head-scratching, and other-parts-scratching, but eventually I ended up with something that seemed about right. The trunk isn't 100% symmetrical, but close enough for jazz, so I only templated one side…
    I cut some 18ga, and using the aforementioned bender/roller combo, I ended up with a little something like this...
    Because of the wacky angles of the bends I could only make the first bend in the brake. The second bend on each side was done by hand using my vice and a BFH. Ugh.
    I managed to salvage one underfloor brace, but had to make one for the other side. Same deal, make a template from poster board, trace it onto 18ga and git cutting' and a-grindin' and a-bendin' (all the bends for this were done in the vice, or with vice grips). I even remembered to drill the darn holes before I bent the metal...
    Now, I don't have a fancy-*** shrinker/stretcher (or a killer stand for one like the one Finnrodder made!), so I had to use caveman tech… vice grips and a hammer. Most of this is out of eyesight, so I got it close, but not perfect. Good enough for the girls we dance with...
    And since the frame for the tank is sitting up on 1x1, I added some bracing blocks to the frame to hold the floor level. The body will be off the frame again in a couple of weeks, so I may run a solid bar across instead of small blocks…
    The job isn't quite done, I've got lots of finishing details to work out and welding to do, but if you squint a little, from say 10 feet or so, it almost looks pretty darn smashing...
    Now if I could only get the rest of the car looking this good... :D
  2. chrisntx
    chrisntx
    from Texas .
    I think there is another thread on how to do this. Did you do a search?
  3. northerndave
    northerndave
    from Badger MN
    Veddy, veddy nice!!
  4. THE CHIEF
    THE CHIEF
    from MIAMI
    very nice tech
  5. akreone
    akreone
    from SLC 801
    Great tech, thanks for posting. Looking at doing this myself.
  6. Yes I did Chris, actually I have a bunch of the shoebox build threads bookmarked. Finnrodder is working on his at a slightly faster pace than me, and has more experience than I do. This is just the way I did it, perhaps it will help (or at least entertain) someone.
    zip357 likes this.
  7. choptvan
    choptvan
    Clean. Perfect. ( not just strokin your ego! ) Looks like you thought this out very well. Good work!
  8. Jalopy Joker
    Jalopy Joker
    Thanks for the post-always good to see different ways to do stuff. most of us do not even have the tools that you used except vise, vise grips and the big f---ing hammer
  9. northerndave
    northerndave
    from Badger MN
    It will help me with our 51.
    Seriously, that's inspiring work.
  10. Thanks for the comments guys. I guess that's part of my point is to show that you don't need a big shop and fancy stuff to do this. I work by myself with minimal tools, and this is the first time I've tackled this sort of work.
  11. northerndave
    northerndave
    from Badger MN
    plans for the filler neck?
  12. coolmilitary
    coolmilitary
    from So Cal
    Great Tech!!!
    The more the merrier as far as I am concerned. Each one has something that gives a clearer picture of how to do it. The pictures really help.
    Thanks for sharing!
  13. Finnrodder
    Finnrodder
    from Finland
    Well,i dont anything about faster pace,its been really slow progress in this summer with my project...
    But you did a really nice job with the trunk,just cant wait to see how your floor will look after you've done it.
    Keep it up!
  14. shinysideup
    shinysideup
    from ruskin, fl
    Looks to be capped in the trunk? No vent? If its a vented cap its vented inside?
  15. DYNODANNY
    DYNODANNY
    Cool set up, we are getting ready to do my buddys 54 chevy.
  16. I had a cap within reaching distance so I stuck it on there for the photos. I'm open to suggestions.
  17. THE BRONSON
    THE BRONSON
    Came out pretty good man, very clean
  18. Finnrodder
    Finnrodder
    from Finland
    Here is one suggestion:
    I cant find the thread,but there was pretty simple trick to vent your gas tank.
    There was a bung with same threads that brakeline fittings have welded on the filler neck and the vending tube was just regular brakeline,which was lead outside of the car.
  19. Last edited: Sep 6, 2011
  20. jerseymike
    jerseymike
    floor came out great. question since i'm about to do the same, what did you do where the floor meets the quarter panels as far as sealing it somehow? thanks, jerseymike
  21. Finnrodder
    Finnrodder
    from Finland
  22. msalamanca
    msalamanca
    Looks pretty good that for sure. The nozzle is in kinda of a weird spot though. I wanted to use the mustang one for mine, but I would have to relocate the filler neck, I need the trunk space.
  23. Finnrodder
    Finnrodder
    from Finland
    I bought a 66' Comet tank.Pretty much same than the mustang tank,but the filler neck is located to the right corner.
  24. Yep, Comet and Falcon tanks are the same dimensions (I think), but the filler neck is off at the front corner. The Mustang tank came with the car, so that's what I'm using. I'll work around it.
    To seal around the edges I was thinking something like flexible strip caulk...
    http://www.eastwood.com/3m-flexible-strip-caulk-20-yd.html
    Any thoughts? The entire trunk will be sprayed with rhino liner or something like that.
  25. Turbos10
    Turbos10
    from Texas
    I would just hit all the seams with adhesive body caulk. You can get it at any automotive store that sells body work products. Careful, it is messy and takes laquer thinner or similiar for cleanup. You can also use a solvent to smooth the bead once the caulk is in place.
    And very, very nice work!
  26. Blacklisted
    Blacklisted
    Looks good, keep up the good work. Hope I can do as good of a job when it comes time for me to do my trunk.
  27. THE CHIEF
    THE CHIEF
    from MIAMI
    here is a install i did on a 55 olds
  28. niceguyede
    niceguyede
    from dallas
    Seam sealer is what you're looking for. 3M makes a lot of different kinds, but fast and firm is what you want. I know, but get your mind outta the gutter and back on the car. It does just what it says, sets up firm fast!! laquer thinner is what you want to smooth it out. I use it on all the rustangs I restore at work. Works great, but a little pricey. 1 tube will do ya with at least half a tube left over for the other seams you welded up. Good work man.
  29. Cool. Thanks for the info, much appreciated.
  30. chevy3755
    chevy3755
    looks pretty good to me..........
