Hey guys i have a 49 plymouth with airbags. I am running firestone 2500's. Is there such a thing that one bag will ride better than another? If so what is the best riding bag that is the same diameter of the 2500? Don't have much room up front for a bigger or 2600. Thanks matt
Most all of the bags can ride pretty good if they are set up correctly. Did you set them up to be in the middle when at ride height? Or are you having issues with ride at full dump?
I've had conitech, firestone, and slam specialties and never noticed a difference between them. The only time I've notice a better ride is when you put a larger bag. Hope this helps you.
Compressed air is compressed air. With a given weight, it has the same compliance at whatever psi you put it at, regardless of brand. Just sayin.....
Do most guys run the same bag all the way around?? Im sure the front bags hold alot more weight than the rears.
I like the slam re bags they don't balloon and they have a little more of a stroke than the firestone.
I really like the Air Lift Dominator bags, they ride really smooth. You do have to be a little careful since they balloon a little
