How do you remove "tar dots" from paint?
Discussion in 'The Hokey Ass Message Board' started by slepe67, Sep 7, 2011.
  1. slepe67
    slepe67
    The State of Florida has decided to resurface a 10-mile portion of luxurious Highway 98 in my area. The newly applied asphalt is all over my truck.
    I have tiny dots about every square inch of my white trucks' sides.
    The dots come off with my thumbnail, but leave a brown stain behind.
    I tried Bug & Tar remover and it didnt do a THING. WD-40, nope.
    Would they come out with rubbing compound?
    Any advice is appreciated (before I ruin the paint out of ignorance)!
  2. dirty4
    dirty4
    Diesel fuel will clean it off real well.
  3. chrisntx
    chrisntx
    from Texas .
    the local full service car wash uses kerosene
  4. Hdonlybob
    Hdonlybob
    WD-45 will do a good job too.
    Cheers..........
  5. 32SEDAN
    32SEDAN
    Try rubbing alcohol and then hit with clear coat polish. Local HW stores sell a clear solvent that is safe on paint/clearcoat. Same solvent the auto gl*** installers use... Don't recall the name...
  6. bab59
    bab59
    Clay Bar system works...
  7. Teal32
    Teal32
    I always use bug remover/cleaner. Bought it for Love Bugs when we lived in Orlando.
  8. scottydc
    scottydc
    from Waco TX
    recently found out that Wax and Grease Remover used for paint prep will take it off and is usually safe for most paints.
  9. loco_gringo
    loco_gringo
    Agreed.
    It's cheap, you probably have some, and it works well.
  10. 50scotbolt
    50scotbolt
    The roads dept around here are great fans of tar spraying.
    The wifes OT car was plastered with the stuff.
    Got great results with Autoglym Tar remover.
  11. 1beatnik
    1beatnik
    from indiana
    Gas works everytime.
  12. Dakota Boy
    Dakota Boy
    from Racine, WI
    Mothers Clay Bar Kit is a really nice product.
    I've used it on my daily drivers to take off bug guts, tar, unidentified filth, etc etc.
  13. dellyjonut
    dellyjonut
    from St. louis
    I detailed cars at a dealership for about 4 years. We used acurasolv (SP?) or whats called new car solvent. You can find it at any detail supply outlet. Apply it and let it sit for a second. You will see the tar melt off. It is clear coat safe. Keep applying and wiping and it will do the job. Follow up with a clay bar to knock anything else off. Be sure the solvent is gone (solvent eats clay). Dont use the clay bar first, it would be a mess. I dont think rubbing compound would do much to be honest. Or, swing by St. Louis with a 6 pack and ill take care of it for you :) Good luck!
  14. von zipper
    von zipper
    High pressure washer at the car wash! That's how I got the white that they stripe the roads with! I asked a guy on the road crew how to remove it, he goes, it don't come off!!! It was a plastic like substance!!
  15. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Gasoline. Follow it up with a wash, and wax.
  16. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I was thinking keroscene ,But wax and grease remover sounds the best to me ,
  17. TERPU
    TERPU
    I had the same misfortune one time in Texas on a fresh oiled road the Dip**** forgot to put a closed sign on. By the time I realized what it was it was too late. WD-40 is really good at removal. Lots of paper towels too. Be sure and throw it away in a big open dumpster to let the towels air dry. Don't want to cause spontaneous combustion for wadding them up in a ball in the heat.
    Tim
  18. jkherd
    jkherd
    :D Creamy Peanut ****er. apply to tar, let set overnight and wipe off in the morning, Its a trick I learned about over thirty years ago. And no I am not pulling your leg.:)
  19. slepe67
    slepe67
    Whaaaaat? :D
    You win for the craziest response in this thread! I have TONS of that stuff in the cupboards. I'm sure the black bears would come in m*** force!!!
    For everyone: thanks for the replies.
    I tried my high power pressure washer and went to two car washes and nada. So far, my thumbnail is the only thing I've tried that gets the little ******s off. I'll re-attack with the WD-40.
    I'll wait for one of my teenagers to get bad grades and have them pop off the dots, and I'll go through with everything mentioned above, and let you know what owrked best. Including the peanut ****er!
  20. Claybar and quick detailer
  21. Master of None
    Master of None
    I would use some PPG DX 3030 wax and grease remover . Shouldn't hurt the paint, but you will have to re-wax obviously.
  22. jkherd
    jkherd
    I have used the peanut ****er trick many times, the oil in the peanut ****er softens the tar so it will wipe off and isn't hard on the wax or the paint. And it will stay where you put it and doesn't run off the body panel or evaporate.
  23. Smiliesafari
    Smiliesafari
    I use mineral spirits. It's a pretty mild solvent.
  24. hoof22
    hoof22
    Any automotive pre-paint solvent called "wax & grease remover", like Prep-Sol will work fine. If you feel like scrubbin' and you want to do a really nice job, those Clay Bars are hard to beat! They'll leave the paint nice & smooth. One of the problems with using only wax & grease remover is it won't remove crud that's not solvent soluble, like things that are water soluble. Clay bars will.
    EW
  25. 63bigbird
    63bigbird
    WD-40 works excellent
  26. thorpe31
    thorpe31
    from nor-cal
    any asphalt release agent
    Zep Big Orange, don't and leave it on a plastic grille to long. It isn't as rough & doesn't evaporate like carb cleaner.
    Zep liquid Steam is better if you don't care at all.
  27. slammed
    slammed
    WD-40 will save money. Park inside, spay down area, let it work. What ever solvent you end up using you should wipe down paint clean and dry. A quality cleaner wax will then pull up any fine/left over residue. You can then use a clay bar to really smooth out the surface. Be sure to LOAD it with wax so the next time the surface will be harder for the 'road sling' to stick to.
  28. unkledaddy
    unkledaddy
    Mineral spirits. Used to be $2.00/gal, now $12.00/gal...........you can get a quart.
  29. evil dead
    evil dead
    from canada
    I have always had luck with WD40...but used to use TR808 it was a tar and asphalt remover, they stopped making it for environmental reasons. You could watch it melt and run off. tires were black as could be when you used it too. but wash it off well (ate rubber too.. and asphalt)
  30. low budget
    low budget
    from Central Ky
    I used either spray brake cleaner or spray carb cleaner on the lower portion of my truck,I cant remember which now,but it started running down off the sides imediately and I just wiped it off.
    I couldnt believe how easy it came off and it didnt hurt my paint but I wouldnt say that it wont hurt yours.
    If anyone tries either,test try it at your own risk in a area that wont be seen.:rolleyes:
