Tire question
Discussion in 'The Hokey Ass Message Board' started by andexxx, Sep 9, 2011.
  1. andexxx
    andexxx
    I have a 31 model A...I wanted to stay traditional and got a set of Firestone Gumball Ply tires. The problem is the front gets crazy looseover over 50mph. Any thoughts on switching the fronts to a radial? Do you think this will help with the 50+ death wobble?
  2. My guess is that the problem is somewhere other than the tires. Can you borrow some from a friend and run them top see if the problem goes away? I ***ume you have checked your suspension for any sloppy parts.
    Charlie Stephens
  3. andexxx
    andexxx
    I will try that.....I just had the wheels rebalanced and the front end realigned...but the wobble is still there
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Did this wobble appear after you changed to bias-ply early tires, or is this your first trips out of the garage?
    Did you put new kingpins and bushings in your spindles when you built the frontend?
    Caster set at 5-8 degrees, tilt of the axle to the rear?
    Toe-in at 1/4"-3/8"?
    Steering box rebuilt or at least adjusted correctly by factory manual?
  5. KrisKustomPaint
    KrisKustomPaint
    Two shackles or a dead perch on the axle? Panhard bar? How bout some pics of the front suspension.
  6. gal6xie5
    gal6xie5
    Are you just wanting to change the fronts to radials and leave the back to bias ply? That is a bad idea.
    Sounds like you've got something else wrong in the front end.
  7. chopt top kid
    chopt top kid
    Until the last thirty years, all we had were bias ply tires... NASCAR didn't run radials 'till sometime in the '90's... It's prolly your front wheel/tire combo, but it ain't the bias plys that makin' your wheels wobble... Set the caster where it ought to be and toe it out just a gnat's ***...
  8. fleetside66
    fleetside66
    There's a ton of info on this here...try doing a search under "deth wooble" & you'll be reading until the suns comes up. Mixing bias & radials is a bad idea..period. If your shimmy isn't too bad, a simple steering dampener will probably cure the symptoms, but not the underlying cause.
  9. derpr
    derpr
    check to see if the tire is out of round. it happens alot on cars that sit.
  10. in_circles
    in_circles
    from Denver, CO
    Gyroscopic precession's a *****. If everything's tight and right I'd look at caster.
