I am interested in copying some doors in my off topic car and making them out of fibergl***. Does anyone know of a video, book, or person that can teach me the process on how to make one? I can do molds and lay down fibergl***. I just have never made a hollow object, nor have I bonded two pieces together in a permanent way. I am not going to have windows, but I will need to have a latch and a hinge mount.
I suppose it depends on how the original doors are constructed. Most comprise a tray-like body with generally simply-curved skin; it should not be too hard to pull a mould off each side, if you compensate for the greater thickness of material at the flange where the two pieces join. If the doorskin is simple it could be quite easy to make one in aluminium, and fold it over the flange of a grp door body. Another elaboration would be to make up a triangular steel door frame that just picks up the hinges and latch, and then hang your made-up door around it.
The guys on Musclecar TV ( spike ) made a hood for their Comet g***er a number of episodes back. The process for making the door exterior and interior molds would be about the same. http://www.powerblocktv.com/site3/index.php/musclecar-episodes?ep_num=MC2010-19&ep_sea=1002
Once you build the inner and the outer, leave a flange to glue in and use these new epoxies that the body shops use, I am using them on metal and I am pretty impressed with them.
iv been doing research on gl*** so i can modify a bucket T to fit my tall ***'s and bad leg.. ie.. stretch, and opening suicide doors ( have not bought a body yet ). also do not waste your money on buying the dvd from fiberglast ( I felt like i got ripped off on the dvds.. and the turtle deck he makes using foam, and gl*** no mold used in it.. cost about 300.00 ( well i have not done much research on buying the materials.. so i should not say it wont be cheap because it maybe cheaper.. im just going by what he said the cost was in the video. ) in materials.. so doors wont be cheap to make..).. just order there catalog if you want to buy anything from them. you can get the same info in the videos on youtube. good luck. chris.
Why not?, I use poly every day for all sorts, hoods, bodykits, campervan parts, fire retardant, UV cure, infusion....... It's all in the quality of the materials and your experience level. Building molds that stay the shape intended takes a bit of skill, something like doors need to be bonded together in the correct shape or they're in the bin. When bonding poly parts I use a single layer of gl*** to each side of the part, leave it to cure, rough it up with some 36 grit sandpaper, lay a "wet" layer of gl***, place together and clamp. Scotty.
Most guys screw up mix rations, demold green and lose dimensional stability, etc. I wouldn't use it for anything, I use only epoxies, but then, I'm an aerospace composites guy that wants his stuff accurate. Not aero accurate mind you, just close to what I tool for. Epoxies are fire retardant too, I'm an NHRA approved supplier of compsite interior panels, I've p***ed all the SFI testing regime. Even guys at home can buid parts that are a higher quality than most anything commercially available if they take their time and pay attention to detail...
I almost had a heart attack when I saw the prices of fibergl*** doors for an OT project of mine. $2200 for the pair, not including shipping from overseas. I figured I'd maybe learn a bit about 'gl***ing and try to make a set myself, as well as other pieces of the car. Then I thought maybe I could build the doors out of aluminum since they are pretty basic, but it would require just as much work as the gl*** for me... Then I remembered an article in a Mustang magazine that a 79-93 Ford Mustang Coupe door with gl*** & power components weighs in at 85lbs complete. Remove the door gl***, the power window motor, door lock stuff, regulator, ****ons, etc and you've shaved about 15lbs off each door. Then go further and start gutting them by cutting the inner structure away, and you've now got the doors down to about 65lbs each. Then take the inner safety bars out that are about 25lbs each. Your stock doors now weigh around 45lbs each, for free. Fibergl*** doors for Mustangs cost $700 for the pair and are 25lbs each. I don't know about you, but saving an extra 40lbs isn't worth $700 to me. I'm starting to lean towards gutting the factory steel doors on my OT project (not a Mustang BTW) and see how light I can get them before spending tons of time and money trying to save a few lbs. I'm still interested in reading up on fibergl***ing though.
Take a look at Smooth-On products. I took a number of courses in FRP and have cast a number of molds laying up layer after layer of FG mat. There are quite a few new products on the market now that make casting a mold a lot faster and simpler than the ol skool FG layup method. Once you have your inner and outer door panels layed up it's best to bond the two together using a structural adhesive such as 3M 08115. Never use resin to bond cured FG! Another source that I use for DIY videos is SmartFlix.com, you will find just what you need there along with many other videos related to automotive topics...welding, paint and bodywork, etc.
Storm King - I am in the process of trying to rescue a 17mx4m plug that was made in epoxies, 8 months later it's still soft and it was made by so called experts, people with a little knowledge can screw up what we would consider everyday stuff. If you can't add 2% catalyst by weight DON'T START! Yes epoxy is lighter and stronger, no doubt, but this guy is looking to make just a couple of things, non structural, and he say's he can already use poly. On the hoods I make, I leave the outer panel in the mold, de-mold the inner and use 5mm steel plate, pre-drilled and tapped smaller than what you will use, I then use short bolts to hold them in place then gl*** over, once that has cured you remove the bolts, re-drill and tap as needed, then join as said before. When I said leave to cure, this is when experience comes into play, knowing when not long enough doesn't become too long so secondary bonding is compromised. Once you've done that leave the outer in the mold for as long as possible (a week is better than a day) to avoid pulling early and getting fibre print through issues. Scotty.
There is an intermediate product between polyester resin and epoxy...that is vinylester resin. Vinylester is more expensive but it has the same workability properties as polyester but the added benefits of greater durability and lower susceptibility to thermal expansion/shrinkage. Scotty, good tip on the joinery and the print through. Most guys don't have a clue about these aspects of FG.
Yeah, Scotty, you do need to be precise with mix ratios. But I still think that's easier to do with epoxy than Poly. That's really how I got in the business. In 1968, I built a spoiler for my brother's '65 AWB injected hemi FX'er. Of course, back then I just bought a boat repair kit and went at it. Now, I don't know where that car or spoiler are today, but I'm pretty damned sure it still hasn't properly set up! When Rockwell offered me a job in composite tooling, I took it just so I could figure out what I did wrong! Then I spent the following 30 years in advanced aerospace composites.
