8x2 intake for big block chevy?
Discussion in 'The Hokey Ass Message Board' started by BAD ROD, Sep 14, 2010.
  1. BAD ROD
    BAD ROD
    Hey,
    I ran across a guy getting rid of an 8x2 aluminum intake that he says came off a 427 Chevy engine decades ago. It has the word "Sharp" cast on it. It is set up for eight 2 bolt mounting carbs. He said that they are set up for 2 bolt strombergs. Is there such a thing as 2 bolt strombergs? I have never seen an intake like this one before.
    Is this thing worth anything? I was thinking of picking it up for a shop wall hanging.
    Mike
  2. theHIGHLANDER
    theHIGHLANDER
    Is it that cheap you can hang it on the wall? I'm intrigued. My period build kustom could use a MK IV BBC but I'd want a wierd intake. Sharp, huh? I'ma search that ****...
    A quick search brought up Sharp Speed equipment for flatheads. I'd call em and talk history if I were you before I popped dough for it.
  3. MilesM
    MilesM
    Sounds like a Weber or FI manifold.
  4. gimpyshotrods
    gimpyshotrods
    How about a picture? 1,000 words, they say.
    FI, 8x1 barrels, or maybe a whole mess of Webbers? Who knows? I've never seen a 2-bolt 2-barrel.
  5. BAD ROD
    BAD ROD
    Did they make 2 bolt strombergs? (like maybe one barrels?) He said that the guy he got it from decades ago ran "VW strombergs" on the intake. Does that make sense?
    I wish I took a picture, but I didn't think of it.
    I also thought it was a fuel injection manifold, but the guy swore that it was not. Webers might make sense too.
    I am not a big block chevy guy, but this thing looks cool.
    Mike
    Edit; I forgot to mention that there is a twist cap in the center of the manifold - like an oil fill maybe? that has Moon Eyes logo on it. Looks like maybe the moon eyes insignia was an add-on.
  6. Shaggy
    Shaggy
    from Sultan, WA
    What about Man-e-fry did they make one?? Kinda sounds like something they'd make
  7. squirrel
    maybe it fits a 427 ford? :)
  8. BAD ROD
    BAD ROD
    I searched around the net and I am guessing that MilesM nailed it. Looks like it is probably for webers.
    It kinda sorta looks like this intake.
    I will take a picture of the intake and post it here in a couple of days.
    Mike
  9. rschilp
    rschilp
    yes, early strombergs are 2 bolt one barrels. I've working on an engine now that has 2 EX-32 carbs on it and they are stromberg single barrel 2 bolt.
  10. kelzweld
    kelzweld
    Down here you get 2 bolt Bendix-Stromberg carbs. I think BXUV-2 and BXV-2 are single barrel and WW-2 is a two barrel from GM Holden cars. Am guessing there are more used on other marques. Would look cool with 8 of them on a manifold and a bonus if they match the Webber bolt pattern. The staggered pattern as shown on the sample manifold pik could make the linkage set up interesting.
  11. RichFox
    RichFox
    Looks like Webers to me
  12. BAD ROD
    BAD ROD
    Here are pictures of the intake. Yep, looks like webers to me too, now that I am more familiar with what weber intakes look like!
    Mike
  13. I guess you could have put 8 2 bolt Volks carbs on it but that isn't what it was intended for and if it had bug carbs it had 8 1 barrels.
    I'd probably like to own it myself but like you I would have to have enough cash to make a wall hanger out of it.
  14. gear jammer
    gear jammer
    from tucson az
    8X1bbl on a big block chevy, thats worst than a nightmare I had the other night! nice manifold though for the street rod guys who run webbers, or a wall hanger
  15. Weasel
    Weasel
    4 x 2bbl 48 IDA Weber manifold - can also use aftermarket throttle bodies such as TWM or Imagine. I have one of these BBC Sharp manifolds sitting out back if anyone is interested.
  16. Garthstorms
    Garthstorms
    from Canada
    Hello I am interested if you want to sell it I am building a BBC with 4 IDA's
  17. Garthstorms
    Garthstorms
    from Canada
    Is it rectangle port or oval port???
  18. Weasel
    Weasel
    They were for rectangular port only as I recall.
  19. Dreddybear
    Dreddybear
    I am not a BBC fan but that intake is bad***.
  20. Deuces
    Deuces
    I wonder if those were used on the CanAm big blocks???....
  21. Larry T
    Larry T
    Off the top of my head (so take it for what it's worth), most of the Can Am cars ran fuel injection, didn't they? Better fuel contol and distribution with the G forces involved.
    The intake is definately for Webers. I think Moon made a couple of intakes for BBC Webers too. Maybe one for vertically mounted carbs and one for horizontally mounted carbs.
    As far as 8/2 bbl intakes for BBC, the engine wasn't introduced until 1965 and I think most 8/2 intakes were out of production by then, weren't they?
    Larry T
  22. Chopt 34
    Chopt 34
    from Florida
    This is a little different, but it is a big block and it has 8 2 barrels. I am just posting this just because it is crazy. If you look close, it looks like an aluminum block too.
  23. Weasel
    Weasel
    Most of the Can Am Chevy big blocks used Kinsler and McKay or Lucas timed injection. Webers were used in the early years of Can Am but not by the time the Big Block Chevy came out. Most of the Can Am BBCs were ZL1 or Reynolds aluminum blocks as I recall. Webers were used in the early Can Am years on the SBC and other engines but not the big block Chevy if memory serves. The top photo shows very rare Weslake heads on a BBC with slide injection - a hallmark of Weslake compe***ion engines - in John Surtees Lola T 160 Can Am car. Cross ram injection was also used on the BBC....
  24. fab32
    fab32
    Yup, that manifold IS for Weber 2 bbl carbs. A kick *** setup but you've got to know your Webbers to make it function properly. I would guess Ingleese would be about the best source for information on how to make it work properly on the street.
    Frank
  25. RichFox
    RichFox
    Just for your own information. Those are two bbl. Stromberg 97 type carburetors with (I think) S&P tops on them.
  26. jipp
    jipp
    looks cool.. but man i do not think i have the skill needed to tune that many carbs. :(
    chris.
  27. 1moore
    1moore
    It is a fuel injection manifold. One was given to me that belonged to Mickey Thompson and has never been bolted on. He told me when he worked for Mickey they couldn't get the one on the car to run right so he gave him this manifold. Mine is also a sharp.
  28. Deuces
    Deuces
    How about posting pictures of yours???.... :)
  29. 1moore
    1moore
    I'll take some pics today.
  30. 1moore
    1moore
