Top Secret Chrome Cleaner Ingredient
Discussion in 'The Hokey Ass Message Board' started by Charlie Chops 1940, Jun 4, 2011.
  1. badgeree
    badgeree
    Auto Sol still gets my vote.
    I laugh when I hear that Coke rots stuff and eats it away.
    When you drink it, it goes into your stomach. I hear your stomach is full of pretty good Acid, that dissolves everything that you eat, and is a lot more powerful than Coke.
    (Maybe that'd be good for cleaning parts too? ):rolleyes:
  2. crminal
    crminal
    Been pleased with Flitz. Works on many different surfaces too.
  3. Ralphies54
    Ralphies54
    To Monte Hendrix, Welcome from one FNG to another FNG. Try using caps to begin your sentences and periods to end them. It makes them a lot easier to read and understand.
  4. If memory searves most good chrome cleaner smelled like amonia.
    Bug and tar remover was normally just petrolium distillate, or kerosene.
    Naptha is a good cleaner that really works, you need to do a test spot on your paint before you use it on a painted surface. There is an OSHA rule against it in an industrial setting because it can cause retina damage as well as liver and kidney damage and was used ina lot of automotive applications back in the long time ago. You can still buy it in small quan***ies.
  5. wombat barf
    wombat barf
    from oklahoma
    yep. it also cleans older windows (non-tinted obviously) like nothing else in the world and will not scratch them. once you've used the steel wool to clean the heavy stuff off the windows clean them again with with a good liquid gl*** cleaner and newspapers (not paper towels) and you will have the cleanest windows you have ever had.
    the man who got me into old cars back in the 1980s taught me this method and his uncle taught him the method back in the 1930s though they used vinegar and water as their liquid gl*** cleaner.
  6. Dads1954
    Dads1954
    from New York
    try neverdul. its cotton soaked in what smell like kerosens but when you rub it on metal it polishes it well. but your best bet is to invest in a buffer and use the correct compunds. it will look like factory new.
  7. Deuces
    Deuces
    I've had tons of luck with SOS or BRILLO pads and warm water... ;)
  8. 69supercj
    69supercj
    Wenol works for me as well.
  9. brokenspoke
    brokenspoke
    Ketchup and aluminum foil.....
  10. butch27
    butch27
    The "secret ingredient " WAS cement powder. Honest--worked at portland cement co. for awhile.
  11. Bull
    Bull
    Many of the old products would never gain VOC compliance today, thus they either changed formulas or disappeared all together. VOC compliance is a constant battle in this industry. Thankfully we've always been ahead of the curve for 25 years. Check out my signature and feel free to browse our site for some good stuff -- with a HAMBer discount too!
  12. BobbyD
    BobbyD
    from Belmont NC
    Active ingedident in this is Oxalic acid, cheap on ebay or a woodworking shop if you have one close by. I bought 5 lbs off ebay and put a set of rusted-to-hell valve covers I was going to trash just to see what it'll do, I was amazed! And it don't take much, 5 lbs will go a long way. Theres a thread on here about it as well, search "oxalic"
