hydraulic throwout bearing or slave
Discussion in 'The Hokey Ass Message Board' started by silent rick, Sep 10, 2011.
  1. Cerberus
    Cerberus
    I ran a '60 Chevy Pick Up slave cylinder on my '55 Chevy with a 348. Made a plate the slave cyl mounted to that bolted to a threaded hole in the block that the pivot bar went to. Worked well for 12 years. only issue was the bleeder screw was upside down.Unbolted the slave cyl to bleed it. No big deal.
  2. Dennis D
    Dennis D
    Pics aren't the best, if someone wants more pics I can get them. Dennis
  3. bobscogin
    bobscogin
    Not to get to far off the topic of the thread, but I like the cable idea. What vehicle did you source that cable from?
    Bob
  4. FritzTownFord
    FritzTownFord
    Thanks - anyone have a pic of a Ford 5.0L cable install? It has to pull forward.
  5. gas pumper
    gas pumper
    Lots of good ideas and solutions here.
    5 or so years ago, there was a lot of this going on too and the posts are here in the T-5 threads about more solutions and brackets.
    On my T I used a Nova bell that needs a 153 tooth, small flywheel, and has the fork at about 7 o'clock left side. With a Speedway hydraulic pull cylinder mounted along side the transmission. Pedals thru the floor. Works fine and is trouble free.
    If I was to do another, I think I'd do a right side fork with a truck bell. and hydraulic cylinder.
  6. jagster
    jagster
    Yeah, S-10's and I think the lowly Ford Rangers used an hydraulic TOB.
  7. Hank37
    Hank37
    I use the hydraulic slave cylinder. It's easier to service then having to pull ****** if the hyd. throwout bearing leaks. Many of my friends had leaking hyd. bearings in the past.
  8. FritzTownFord
    FritzTownFord
    Okay, I a dope - misspoke. My clutch arm must move FORWARD (stoke 5.0 bell housing and right side ball position). But you pics make me think I can use the stock cable hole and run the cable to the lower lever on my clutch pedal to pull it from the front.
    I'll search now.
  9. Very difficult to service when it goes South on you.
    Please, go with the slave and a rugged fork.
  10. silent rick
    silent rick
    man, the way all you guys are talking, it sounds like a matter of when, rather than if these things start leaking. it has me thinking of sticking in an automatic instead.
  11. bobscogin
    bobscogin
    That will definitely eliminate any clutch actuation problems, but you won't have as much fun.
    Bob
  12. racer67x
    racer67x
    I've used the bearing type on circle track cars for years with no problems..like someone else already said just make sure its set up right..3 shims usually is a good starting point with a Muncie.
    one other thing..if you pull the trans back out be careful not to pull the thing apart,throw it away and get another one if you do..never had any luck trying to replace the "O" rings.
  13. mosimpson
    mosimpson
    Thanks for the pic. In studying your set-up I am confused on how your push cylinder can operate the clutch from where it is mounted. Can you explain where the pivot is for the clutch arm? Wouldn't a push cylinder have to be mounted on the engine side to function properly?:confused:
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Dave/..... that's a GREAT solution!
    I used McLeod T/out bearings and have never had a problem.... Howes on the other hand....UGH. no thanks.
    I have never used a slave just because of a space issue.I do like the fact they are easily accessible.
  15. shinysideup
    shinysideup
    from ruskin, fl
    The pivot is on the opposite side. Like I said it was a cable pull from the opposite end originally. 80-93+ mustang.
  16. mosimpson
    mosimpson
    You wouldn't happen to have a pic of the arm from the front of the ****** would you??
  17. shinysideup
    shinysideup
    from ruskin, fl
    Hope you can see it now.
