54 Chevy CL find is it priced right?
Discussion in 'The Hokey Ass Message Board' started by SulphuriousSam, Sep 22, 2011.
  1. SulphuriousSam
    SulphuriousSam
  2. retro54
    retro54
    from PA
    Looks su****ously like a 2-door sedan with the top cut off, if photos are zoomed in on.
    I'd pay that for a solid original car with 20 foot paint... that ran and was complete.. meaning it still had it's roof.
  3. I'd be afraid the doors would never close right. I would say no.
    Sent from my iPhone using TJJ
  4. Jalopy Joker
    Jalopy Joker
    do not even call about this abortion-good for a parts car now-if he still has roof maybe someone can put it back together again for a much lower price.
  5. brad chevy
    brad chevy
    Well at least they didn't weld the doors shut when they cut the top off. Body don't look to bad but flat black paint covers screwed up parts pretty good.I personally wouldn't pay over $2000 for it. Might have brought $4,000 if they hadn't screwed it up.
  6. SulphuriousSam
    SulphuriousSam
  7. chaddilac
    chaddilac
    I've got a 51 ford shoebox roof if you end up buying it!! :D You can have it free!!
  8. SulphuriousSam
    SulphuriousSam
    Thanks Chaddilac! I'll remember that if it happens. :D
  9. Convert54
    Convert54
    from Oklahoma
    NOT a real convert..........door gives it all away.
    Never be strong enough in the frame to be street worthy.
    <<<<< thats a REAL convert
  10. SulphuriousSam
    SulphuriousSam
    Gotcha guys thanks. Wishfull thinking I guess :eek:
  11. Jalopy Joker
    Jalopy Joker
    '56 Ford looks much better - best have the seller do a compression check on engine. Y blocks have limited top end oiling system. sometimes there is a copper tube running to valve covers to help with this. check and smell transmission fluid - and look at water in radiator. brake job may be needed because drums worn out.
