Need rubber boot/bellows
Discussion in 'The Hokey Ass Message Board' started by Dave Downs, Sep 22, 2011.
  1. Dave Downs
    Dave Downs
    from S.E. Penna
    I need a rubber boot/bellows; think of a master cylinder with the push rod - cover where the rod goes in with a boot sort of like what you see on a CV joint.
    1-1/4" dia x 3/4" dia X 1-1/2" long
    It would have to be one to fit a specific application that I can use on my set-up; I've 'googled' the heck out of the subject but can't come up with any sizes.
    Anybody use one about this size and can tell me where they got it?
  2. Gary in da UP
    Gary in da UP
    What comes to mind is a tractor shift lever boot, also some early 60's combines had steering brakes with master cylinders under the floor, so try a search for tractor parts, then try to narrow it down. Hope this helps.
  3. Unkl Ian
    Unkl Ian
    Try mcmaster.com
  4. Try your local auto parts store , ask for a "Universal steering rack boot"
    they have staggered sizes each end and you just trim to suit .
  5. Dave Downs
    Dave Downs
    from S.E. Penna
  6. 37gmc
    37gmc
    from upstate ny
    have you looked at any marine apps.? maybe look at west marine or other marine supply companys
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    Sounds like an early Chevy starter push rod bellows.
  8. JEM
    JEM
    Check mcmaster-carr, also i've got something here that's a little too big, its a golf cart steering rack boot, there might be other sizes...
