oil and fuel mixed
Discussion in 'The Hokey Ass Message Board' started by chavez1957, Sep 23, 2011.
  1. chavez1957
    chavez1957
    what does it mean if my motor oil is mixed with fuel on my rebuilt y block??
  2. Mr 42
    Mr 42
    from Sweden
    maybe Some sparkplug's is not working?
  3. monkeywrenching
    monkeywrenching
    from maryland
    Does the engine start and run fine? If it does check fuel pump diaphragm for possible leaks. If not look and see if carb needle and seat are stuck and allowing fuel to run into engine when the engine is shut off
  4. Slick Willy
    Slick Willy
    do an oil change before you wash your bearings!
  5. CutawayAl
    CutawayAl
    from MI
    In addition to the above suggestions; a slight leak in a carb needle & seat, combined with an electric full pump that is not being turned off when the engine isn't running, can add a LOT of fuel to the oil over time.
    ........ and cylinder walls. +1 on the oil change.
  6. chavez1957
    chavez1957
    the engine starts but turns off after 30 seconds im guessing the timing is off...i just did the oil change
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    leaking mechanical fuel pump., or an electric pump pushing fuel past the needle seat.or leaking of carb down the manifold
    and as said, dont run it with fuel deluted oil..you'll be sorry
  8. tcoupekyle
    tcoupekyle
    Magic... just kidding I vote leaky fuel pump diaphragm
  9. Jeff Norwell
    Jeff Norwell
    MODERATOR
    your bathing the engine... you will spin a bearing or worse. Have your carb rebuilt if fuel is indeed p***ing thru.
    What kind of Carb(s)?
    Set your timing properly....
  10. chavez1957
    chavez1957
    ok. the carb was leaking i fixed that, and did the oil change. now gotta set the timing right...
  11. Retro Jim
    Retro Jim
    The first thing you need to do is get that oil out of that engine before you need to rebuild it again ! Gas from the carb is draining down when the engine isn't running and washing the cylinder walls down and cleaning all the oil film you have on every part you have in that engine !
    First it is probably your carb so a simple carb rebuild should fix the problem . When you change your oil add a container of Lucas engine break in to your oil . That will help coat all the parts as you start your engine . You can buy that in Advance Auto and any place that carries Lucas products . You also need to use the proper oil for flat tap cam . DON'T use the thin synthetic oils either ! Use a good 10-30 or 10-40 oil and make sure you add the additives with ZDDP OR oils that have them in it . Not many in the stores where you buy oil but easy to get and don't use Diesel oil either !
    Amsoil , Brad Penn , Comp Cam , Joe Gibbs , Mobil 1 original are a few that has what you need .
    If you use good oils and a good filter and not FRAM and the other junk parts store sell , the engine will last a long time ! I use either a K&N or WIX racing oil filters on my engines ! They are the best ones to buy out there !
    Keep us posted on how your engine makes out !
    Retro Jim
  12. chavez1957
    chavez1957
    thanks lots for your help. my engine hasnt been driven on the road yet. it should still be fine right?
