Projects the '27 Roadster saga
Discussion in 'The Hokey Ass Message Board' started by Paul, Jul 20, 2010.
  1. Boones
    Boones
    from Kent, Wa
    this looks great Paul...
  2. Paul
    Paul
    Editor
    spent a couple days getting the turtle deck to fit a little better
    brEad likes this.
  3. Paul
    Paul
    Editor
    filled dash will get '38 Chevy truck gauges, gas pedal and under dash E brake mocked for fit, stock seat riser out, new tube steel seat riser in to tie the reenforced sides together and carry the school bus seat
    oliver westlund and brEad like this.
  4. 94hoghead
    94hoghead
    Really, really cool.....I'm so envious ....
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Love the gauge cluster Paul
    Coming along lovely.
  6. kisam
    kisam
    Love it Paul!
  7. Paul
    Paul
    Editor
    gauges broke my budget a bit
    but they were a lot less than the mid '30s Buick, Auburn, REO, Packard and other really cool gauges I'd been lusting after.
  8. n847
    n847
    Those guages are beautiful...
  9. RGG
    RGG
    Paul,
    I love this thread! It makes me want to build the 27 roadster that my dad had back in the day. However, I have to get my AV8 30 Coupe done first!
    Great work - keep the updates coming!!!
    RGG
  10. jipp
    jipp
    i dig the warped looking numbers very stylized.. man iv been planing on building a bobtail T.. but the roadster looks sweet.. one thing ill be using gl***. most hate on gl*** but it is what it is.. keep up the great work.
    chris.
  11. 41 Dave
    41 Dave
    Paul, Your '27 is sure coming along great. You are using just the right mix of parts. Going to be one neat Hot Rod.
    Dave
  12. Hotrod95
    Hotrod95
    Absolutely amazing! Beautiful! Great job!!
  13. rob-redm
    rob-redm
    Looking good Paul !!! can't wait for more follow up pictures. The attention to detail is awesome.. cheers Rob
  14. T Hudson
    T Hudson
    Looks great. I have a chunk of the dash bump out the gauges mount to. You can have it for the ride if you like.
  15. Paul
    Paul
    Editor
  16. Paul
    Paul
    Editor
    gauges came Monday, panel came today- thanks T Hudson!
    this is what they look like together
    and the shot of the dash is close to how they will be layed out
    using scanned images of the gauges taped to the uncut dash
    oliver westlund likes this.
  17. T Hudson
    T Hudson
    No Prob. Are you going flush mount or bump it out?
  18. 41 Dave
    41 Dave
    Paul, That is going to be one neat looking Hot Rod dash ! Just perfect ! Looking forward to seeing the completed dash.
    Dave
  19. Paul
    Paul
    Editor
    yesterday I welded the section of Chevy dash in the stock T dash,
    I also modified the bottom of the dash to have an upward curve thinking it might add something to the overall look
    as soon as I bolted it back in the car I could see it would never do
    so I welded the removed section back in,
    returning the line of the bottom of the dash to it's stock configuration
  20. jonathan
    jonathan
    from Phoenix,AZ
    I dig this one. Does the bus seat lower the seating height any? I'm collecting pieces for my 26/27 and have been thinking about seat position. Most of these I see look like guys are sitting *on* them, not in.
  21. woodysrods
    woodysrods
    I rember when mine was in that mock up stage 25 years ago. They are fun to build and even more fun to drive.
    Good Roads
    Brian
  22. Paul
    Paul
    Editor
    it's not so much what you use but how you use it.
  23. Kevin Lee
    Kevin Lee
    Super Moderator
    The dash looks great – putting that piece back in was a good call.
  24. Frenchy Dehoux
    Frenchy Dehoux
    Car is looking great nice work gives me some incentive to start on my next project. Where did you get your fuel tank this is the style I want to use on my 28.
    Thanks
    Frenchy
  25. opu27
    opu27
    from ONYX,CALIF
    Thanks for taking the extra time for the photos and writing the text.
  26. Man what a sanitary little hot rod. Love it, especially the mill. A neat simple little roadster, i really need to get back on my 27 project, it was damn near about the same lines as yours. Killer...Glad its back on top..
    TH
  27. Kona Cruisers
    Kona Cruisers
    Hey Paul...
    your builds are a true inspiration to me. what size tubing /square stock did you use in the trunk floor / p***enger floor area? I ***ume you use 20ga for the sheeting of both.
    thanks
    levi
  28. Paul
    Paul
    Editor
    thanks man,
    1/2" in the p***enger area and perimeter of trunk, to get the sheet to flush with the subrails, 3/4" for the rest of the trunk floor,
    and yes 20 gauge sheet throughout
  29. Paul
    Paul
    Editor
    aint much but, tail lights and license mounted
    brEad likes this.
  30. hydroshawn
    hydroshawn
    from Tx,Ca
    Is that a Cal Custom license plate light?
