Projects Twisted Drill Special LSR Build
Discussion in 'The Hokey Ass Message Board' started by kasselyn29, Sep 25, 2011.
  1. kasselyn29
    kasselyn29
    Twisted Drill Special LSR Build 1929 Model A 1935 Ford Roof
    Nailhead A-V8 likes this.
  2. kasselyn29
    kasselyn29
    Hope to drive this car to loring next year and them hopefully run in the 175 Cl***.
  3. kasselyn29
    kasselyn29
    I jumper the photos ahead a little My friend Barney Is doing the sheet metal work ont this car,he has build a couple of other land speed cars. Will post more pictures if there is interest Thanks
  4. Crazy idea that should not work but it does!
  5. Animal
    Animal
  6. Mr48chev
    Ditto the I like it. That looks slick.
  7. Marcia
    Marcia
    Looks great.
  8. Boeing Bomber
    Boeing Bomber
    Looks real good. what's going to power it to 175?
  9. resqd37Zep
    resqd37Zep
    from Nor Cal
    I was thinking the same thing. Looks good!
  10. kasselyn29
    kasselyn29
    Thanks Marcia. SBC four speed winters V8 rear.Couple more photos.
  11. squirrel
    neat! what (body) cl*** are you planning to run in?
  12. JimC
    JimC
    from W.C.,Mo.
    That's just crazy!
    Wish I had thought of it.
  13. kasselyn29
    kasselyn29
    Compe***ion Coupe & Sedan Cl***
  14. metalix_421
    metalix_421
    I like the look
  15. dirtbag13
    dirtbag13
  16. Joe's 32 Ford Sedan
    Joe's 32 Ford Sedan
    What a great Idea.It looks like Ford could have build it. It really blends together,Great work. Only on the HAMB would you see this. Joe.
  17. electromet
    electromet
    from Tucson, AZ
    I'm really liking the look of this project. I do have one observation, however. Wouldn't it be more beneficial to narrow the top to fit the body rather than widening the body? I understand that it would entail more welding and m***aging, but reducing the frontal area is the name of the game here.;)
    Mike
  18. Unkl Ian
    Unkl Ian
    Pretty sure changing the roof is not legal in Compe***ion Coupe.
    At least according to SCTA rules.
    But it does look very good.
  19. kasselyn29
    kasselyn29
    We didnt widen body only the front cowl area for al ittle more foot room.The trans and bell housing real intrude in to the cowl and space is a problem.Thanks
  20. Kevin Lee
    Kevin Lee
    Super Moderator
    Model A with a 35-36 windshield? That will never work. :)
  21. Yeah, but he took it one step further and used the whole roof!:) Looks like a Thom Taylor Phantom.
    Better buy a rulebook if you want to run it.
  22. jay7262
    jay7262
    It worked !!!
  23. Marcia
    Marcia
    The Loring rule book is the same as SCTA. But I know you have a Loring book.
  24. Jeem
    Jeem
    Alliance Vendor
    I love it! Please tell me you'll work on the base of the A-pillar some more. Really *****in'.
  25. 38FLATTIE
    38FLATTIE
    from Colorado
    IF the Loring rule book is the same as the SCTA rulebook, what makes you think this modification is allowed?
    The way I read the rules, this won't make the cut!
  26. I like it - all I'd do is take some bulk out of the crown as it seems heavy up there. Really like the transition at the rear above the beltline - the "kick" forward gives it a great look.
    Steve
  27. kasselyn29
    kasselyn29
    Will run T/O cl*** if I have to. The real fun is building the car.
  28. doctorZ
    doctorZ
    it looks great, but you will end up in T/O if you want to run Bonneville. remember, if you're running T/O you essentially still need to build to the record for the 'closest' cl***. running an SBC (probably C-cl*** 306-372 ci) will put you around a 200 mph record (whether you're running G/BG/F/BF). you will need to build to that record to p*** tech which will require higher SFI rated equipment, parachute, full fire system, etc. it's a lot of work for T/O!!
  29. gotit
    gotit
    I wonder how an a-400 Vicky rear section would flow with that top.
  30. kasselyn29
    kasselyn29
    I was aware of that rule for scta I remember Sam explaining that problem to me years ago but, I don't know if it is the same for ecta or Lta. that is the reason I was going with the safety equipment for 175 Lta rules.Going to call Joe Timney next week to ask a few questions.
