So I got this MIG welder for free...
Discussion in 'The Hokey Ass Message Board' started by Ben DeBumper, Sep 24, 2011.
  1. Ben DeBumper
    Ben DeBumper
    I got a free MIG welder today! The problem is, it's an oddball make (FRO) and it didn't come with a manual. The previous owner never used it so he couldn't help me. I haven't tried it yet because I am puzzled by the front panel controls. See the picture; besides the on-off switch there are three knobs. The upper right one is obviously wire speed; I think the center left one is voltage. The one that has me puzzled is the bottom one. It clicks off at the "0" setting and moves smoothly between 1 and 10. Anyone have a clue what it does?
  2. Mr48chev
    A little more info and better photo might help guys identify it and give you some leads.
    Did you Google the machine brand/model to see what is out there?
  3. DadsDodge
    DadsDodge
    Fine adjustment between steps on main switch ?
  4. Ben DeBumper
    Ben DeBumper
    It's called a Baby MIG 131. When I googled it I found that the maker is now called SAF-FRO and it's mainly sold in Europe. The machines they make now do not have these controls and I could not find any info on it.
  5. eddiebroadway
    eddiebroadway
    My ESAB Migmaster 250 has three knobs, so does the DipPack at work so its pretty common, co**** voltage setting, fine voltage setting, and wire speed. I had a Snap-On Mig with only two knobs and hated it, either too hot or cold. If there is a chart inside the door where the wire spool is that would be handy, if not just play with it starting with middle settings, Good Luck!
  6. Engine man
    Engine man
    from Wisconsin
    Judging by the dots below it, it might be a timer for spot welding and the circle is for normal welding. It will be easy to tell when you try it. It will weld for a short time and shut down. If you set it to the circle it should weld as long as you hold the trigger.
  7. 23reotim
    23reotim
    from arizona
    i think its like a timer for doing spot welds.
  8. Mr48chev
  9. Ratroddude
    Ratroddude
    It wouldn't be a "s***ch" function , would it? :confused:
  10. Copper Top
    Copper Top
    I wonder if the knob on the left is for heat settings and the bottom right would fine tune the heat within that setting. I have an old Forney (Clarke) that works this way but with switches.
  11. Stu D Baker
    Stu D Baker
    from Illinois
    The bottom dial (0-10) dials in the percentage of the amp setting, i.e., if you set the amps at number 3, the bottom dial will "fine tune" the amperage setting. Usually, if you need to have it set on 10, it's better to go to next higher amp setting and fine tune it down to where your machine can weld good. Very similar to Miller and others. Looks like a good machine. Stu
  12. Ben DeBumper
    Ben DeBumper
    That's what I got! It even came with a gas bottle, I guess it has argon in it.
    Cool! I'll try it out.
  13. leon renaud
    leon renaud
    from N.E. Ct.
    check with "Daytona Mig" that machine is most likely made by the same Italian company that makes Astro and several other cheaper 115V machines. I have a Mac Tools branded one I believe Astro is the manufacturers name in fact.Daytona Mig got me manuals and parts when I was told Mac Tools no longer offered this machine and could not get me anything for it!My mac tools unit works fine for light jobs like sheet metal and with proper prep I have welded up to 1/4 inch with it with good results but that's pushing it and I was in a bind when I did the 1/4 inch.Both myself and my son were certified weldors and I like it for sheetmetal and he hates it! If you have experience with a good shop grade mig it will take some adjusting to get used to this machine it's not going to run a bead as easy as a Miller or Lincoln but you can get nice light guage welds with them.If anyone needs parts or service for what you think is an oddball welder give Daytona Mig a call I had everything I need in just a couple days,OH my machine is set up for gas not flux core.
  14. Engine man
    Engine man
    from Wisconsin
    If the dial with the lightning bolt under it is detented in position 1 through 6 you might have a fine adjust but if it is fully variable, I doubt it.
    The detented O position and the line of spots under the lower right knob lead me to believe it's for spot welding.
    As I said, it will be easy to find out when you try it.
  15. My vote for the lower right is " s***ch ". The 1-6 is voltage tap settings, and the upper right is wire feed, TR
  16. www.fro.it/, if you know anyone who speaks italian, hope that helps, TR
  17. Blue One
    Blue One
    from Alberta
    The top dial is for wire feed speed (amperage) . The bottom dial is for voltage.
    You will want to set them roughly the same, for instance if you set the wire feed speed at 5 then you also set the voltage dial at 5.
    The other dial is a range selection dial giving you a selection of 6 different ranges from a low of 1 to a high of 6.
    As the symbol below it indicates it is a series of steps, 1 being lower and 6 being the highest.
    You select the range you want, low for thinner metal and higher for thicker metal.
    You then set the wire speed and voltage to where it gives you the weld you need.
  18. Stu D Baker
    Stu D Baker
    from Illinois
    This machine does not have a "spot timer". Typically, with a spot welder, there is a toggle switch (S***ch/Spot) which changes the function of the welder. It's a nice welder, but no real bells and whistles. Stu
  19. You should have got the one that goes to Eleven!
  20. GREASER815
    GREASER815
    Just plug it in and mess around with it. You could already know.
  21. Being a European made machine does it even work with our standard 110/220 60 hertz? Is it European made for our market? What does the plug look like?
    Italy as well as much of Europe is 220 50 hertz coming out of the wall sockets.
  22. Mike51Merc
    Mike51Merc
    The symbols look like a set of spots and a clock, so I go with spot weld timer.
  23. Ben DeBumper
    Ben DeBumper
    It's 110 volts. There's a plate on the back that says Widder Corporation, I guess they were the US distributor. I would fire it up and experiment but I need to get a welding helmet.
  24. Stu D Baker
    Stu D Baker
    from Illinois
    Perhaps the universal symbol for "On/Off"? Main power switch. Stu
  25. Blue One
    Blue One
    from Alberta
    Ignore all the other posts, post 17 has the correct info. :D
  26. leon renaud
    leon renaud
    from N.E. Ct.
    yes until he needs to find parts or manuals for that machine!:D
  27. Ben DeBumper
    Ben DeBumper
    I plugged it in and it powered up, fed wire, and flowed gas; so far so good. I can't make sparks until I get a helmet. But you're right if it breaks it is probably s****.
  28. RugBlaster
    RugBlaster
    The mainest thing is that it is free. I wouldn't give a **** if it had 15 knobs and a built in kazoo on a beaded chain............IT'S FREE. Weird, but free
  29. jay7262
    jay7262
    Translate the Italian instructions on-line with Google translator
  30. mysteryman
    mysteryman
    from atlanta
    the other setting is for s***ch welding
