Projects [PROJECT] Laidout53 Part II
Discussion in 'The Hokey Ass Message Board' started by HarborKustomSpeedShop, Oct 11, 2010.
  1. resqd37Zep
    resqd37Zep
    from Nor Cal
    I've been hooked since the first cut. Looks great!
  2. thanks guys
    Moparman- do you happen to have drivers side door hinges upper and lower?
  3. cab side or door side? I have the s**** doors, I will have to look to see. I will get back to you.
  4. yup. just went out and looked at the s**** drivers door, hinges are there. You can have them.
  5. oldman2
    oldman2
    Been waiting for any update, it was worth the wait, looks good.....Jim
  6. I don't know how I missed this build. I have subscribed. I love it.
  7. Thanks Oldman2 and Sobastrace
  8. robleticia
    robleticia
    Chop is looking great!
  9. Jon1953B4
    Jon1953B4
    from MD
    Just subscribed, in the planning stages of my 53' pilothouse build.
    This build is a huge motivation. Since I don't have fabrication skills worthy to be on the same planet as yours I think Im going to use a sid's dropped axle in the front and a sping under with c-notching the frame in the rear to get her low where she belongs.
    Anyway keep up the great work and thanks for sharing.
  10. Jon1953b4, Thanks man and good luck with your project.
  11. hartman601
    hartman601
    from Tulsa, OK
    laidout53, any new progress?
  12. bradpac
    bradpac
    from Taylor, TX
    Awesome build. I loved the first incarnation of the truck a few years ago and even more now. Great inspiration for my 52 1.5 ton.
  13. Thanks Lunacy..
    No progress, will be back on it soon...
  14. OK, big update!
    Im happy with the chop but i didnt like the front window. still looked to big and aslo wanted to take some of the crown out of the roof, so i lowered the frame work an 1/2". Then i removed the seems on the A pillers. Fixed the drivers side corner and door jam area. Recently bought a TIG welder so what better time to learn than now. then on to filling the gap between the roof sections, need to redo it cause i got to big of gaps but it will have good flow. Then i tried to fix more of the driver side roof but i decide to just make a new section.
    Any ways heres the pictures!!
    Before lowering the window opening
    During
    After
    New corner and a pillers
    Back cab wall welded and smoothed
    Cab upper corner after my first atempt to fix it
    New peice i made
    And fitted
    What do you all think?
    Justin
  15. hammeredrods
    hammeredrods
    all I can say is AWESOME...
  16. as always, you are a stud! sure wish I coulda come and seen the truck and you in person before I moved. Did the hinges do you any good???
  17. Thanks hammeredrods
    Bud, Thanks for sending those hinges to me, but the pins were rusted in them so i just fixed mine. Worked pretty good when i took the door off and use BFH and hit them Lol. Where'd you move to? If your ever in the area hit me up and you can come check it out..
    Justin
  18. Justin. I moved to Othello, Washington. Let me know if you are ever in the area. I got lots of room for visitors. I will be putting a 30 x 40 x12 shop up by spring if everything works out. Bud
  19. Nice, thanks bud I'll keep that in mind.
  20. 510madmav
    510madmav
    Wow! Great work
  21. Thanks 510madmav!
    Heres two pictures showing the roof curve (like i said im going to redo the filler peice)
    Justin
  22. oldman2
    oldman2
    First, glad to see you back on it, second, nice job top look great....Jim
  23. 53olds
    53olds
    I dig the hell outta this truck!
  24. resqd37Zep
    resqd37Zep
    from Nor Cal
    Dude your work is soo clean! I love it man.
    James
  25. Thanks James! hows the caddy going?
  26. neverdun
    neverdun
    Fantastic workmanship. Keep it up.
  27. resqd37Zep
    resqd37Zep
    from Nor Cal
    Slowly but coming around. Threads like this one keep the motivation up. Thanks for the updates.
  28. Thanks!
    I'll do my best to keep you motivated...:D
    Justin
  29. hotskins
    hotskins
    from Justin Tx.
    Man this makes me want an ol' dodge truck even more now, thanks.
