Is this axle worth straightening???
Discussion in 'The Hokey Ass Message Board' started by 94hoghead, Sep 28, 2011.
  1. 94hoghead
    94hoghead
    I bought the front axle and radius rods out from under a trailer. I think it is 36 Ford. had wide five wheels on it. After I got all the angle iron and crap cut off of it I realized that the axle is bent. Is this worth trying to straighten out or should I just buy a new one from Speedway???
  2. TagMan
    TagMan
    You can pick them up fairly cheap, if you look around. I just picked up a '37-'41 axle for $52, which included postage and it was in great shape. I would guess by the time you took trying to get that hunk of iron back into shape and finding the caster / camber was still out of specs, it would be time well saved to just locate another one. My 2¢
  3. 94hoghead
    94hoghead
    Kinda what I was thinkin'...
  4. metal man
    metal man
    I would say that if you pay someone with the equipment to fix that,you'll spend more than you would to find a good one at a swap meet or on here. I personally really like to use FORD axles,and would not buy a new one.You should be able to find a nice FORD axle for under $100
  5. anteek
    anteek
    Talk to someone who drops them. They can usually repair one reasonably or sell you a core to drop.An original dropped is a lot more desireable than any of the aftermarket ones. Just my .02.
  6. metal man
    metal man
    The last one I bought cost me $20, and the two before that were free.Going rate at swap meets around here is $50-$80
  7. HomemadeHardtop57
    HomemadeHardtop57
    hang it on the wall and look for another. Those 33-36's are not that hard to find. It needs alot of work from someone who knows what they are doing...and it still might not be right
  8. brad chevy
    brad chevy
    Scrap it and keep looking probably some here in the classifieds.
  9. 117harv
    117harv
    I think it's fixable, don't scrap it.
  10. youngster
    youngster
    from Minnesota
    I had a Model A axle straightened for $15 at a big truck repair shop.
    Ron
  11. Fe26
    Fe26
    Is this axel worth straightening? Yes.
    As anteek said you could use it as a core on an exchange for a dropped axle.
  12. VoodooTwin
    VoodooTwin
    from Noo Yawk
    A big ole press and about 10 minutes of fun will have that sucker ready for the road. Save it.
  13. Dale Fairfax
    Dale Fairfax
    That axle looks as though it has been bent at an alignment shop-probably to adjust camber on that side. It could be straightened by using the same technique: A bottle jack and some heavy chain. But that would throw the camber back off.
