1950 chevy truck is it a longbed?
Discussion in 'The Hokey Ass Message Board' started by hobbyjp, Sep 30, 2011.
  1. hobbyjp
    hobbyjp
    from socal
    It's late and I'm beat, I just picked up a 1950 chevy truck seller said it was a shortbed and its. Missing the rear fenders so its kind of hard to tell. Can someone give me some deminsions. I'm starting to think I got shamed.
    Thanks
    Jimmy
  2. bubba57
    bubba57
    from k
    Do you have a picture of it?
  3. pistonhead
    pistonhead
    from Chicago
    send over the pic and vin
  4. pistonhead
    pistonhead
    from Chicago
  5. Kaptain Kustom
    Kaptain Kustom
    from Finland
    1/2 ton bed is something around 6' (or was it 6-1/2'?), 3/4 ton about 8' and 1 ton is about 9'.
  6. Kaptain Kustom
    Kaptain Kustom
    from Finland
    To add, the 1/2 has an A-shaped frame (when looked from above) and a torque tube, whereas heavier trucks have more like a ladder shaped frame and open drive. Also the 3/4t and heavier trucks have wider track width in rear than in front.
  7. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Measure the length of the bed. If it's anything longer than 6.5 feet, it's a long bed. Simple is as simple does. :)
  8. Wagonmaster2
    Wagonmaster2
    The fenders should be the same regardless of bed length. Go for it!
  9. hobbyjp
    hobbyjp
    from socal
    heres some pics of the truck
    Is the frame suppose to look like this in the back? the running boards and everything in the front half looks right but this almost looks like a frame swap.
    The bed measures about 6'8'' and the wheel base is 125. I'm thinking it might be a 3600? I'm almost positive it has a 1953 or 54 235 in it but I will have to knock some dust off for the numbers. I couldnt find the vin number. where is it on these trucks it has a blue california vin plate which also lets me know that it was once registered by the motor and someone switched it out.
  10. heatmiser
    heatmiser
    from mia
    yeah, short bed is 112 wheelbase... also, rear springs and 8 lugs say 3600...
  11. VoodooTwin
    VoodooTwin
    from Noo Yawk
    That appears to be a short bed off a later Second Series (or later) truck. Doesn't appear to be an AD bed.
  12. heatmiser
    heatmiser
    from mia
    good eye... definitely had larger, more square fenders on it....
  13. badshifter
    badshifter
    It's a 3600. Big truck. Sorry!
    Short bed 3100
  14. '54Caddy
    '54Caddy
    Like VoodooTwin mentioned, looks to be a short bed off a later truck. Also looks like a 3/4 or 1 ton ch***is, 8 lug wheels and frame hanging out the back. The running boards and filler panels almost look like they belong to a long bed originally.
  15. T Hudson
    T Hudson
    3100 wheelbase is 116"
  16. LowKat
    LowKat
    If it has a Calif ***igned blue VIN tag it's probably an ***embled truck
  17. hobbyjp
    hobbyjp
    from socal
    It's definitely a shortbed that was put on the back, what needs to be done for the shortbed to fit on the longer frame? Can the frame be shortened like other longed frames by cutting out X amount of the frame and welding it back together and shortening the drive shaft?
  18. caseyscustoms
    caseyscustoms
    from st.joe, MO
    Yep.
  19. waldo53
    waldo53
    from ID
    Doesn't apear to be an AD bed. The top rails on an AD are angled, the ones in the picture are flat, looks like a later bed.
  20. '54Caddy
    '54Caddy
    Waldo53, keep in mind the some of the AD GMC's had flat rails, but I agree it doesnt look like an AD bed
  21. ironhead68
    ironhead68
    1954 Chevys had flat top rails on the bed.
  22. waldo53
    waldo53
    from ID
    Chevy's and GMC's went to the flat top rails in '54, I shoulda said it doesn't appear to be a 1950 AD bed.
    Side note: GMC's were not called Advance Design, they were New Design.
  23. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Huh, I learned something new today. Thanks!
  24. hobbyjp
    hobbyjp
    from socal
    Wow so I got screwed kinda guy told me three different times it was a longbed just looked funny because the bumper was missing, I did get a decent price on the truck. Paid 1700 and it came with a ***le and there's no rust holes and no rust in the cab only a little surface rust and a its got a 235. I got the truck for my cousin and he wanted a shortbed so now comes my next questions. Can the frame be shortened to 116 wheel base like I have seen done to other longbeds? Could the 54 bed ever fit right on the 3600 frame after its shortened and will other year(49-53 )rear fenders fit onto the bed?
    Thanks everyone
  25. '54Caddy
    '54Caddy
    I also learned something today! Thanks!
  26. henry29
    henry29
    The bed is a 55-59 long bed that has been shortened.
  27. hobbyjp
    hobbyjp
    from socal
    Now that you say that I'm looking at the bed and it does look like the rust circle where the fenders were are the shape of a 55. I noticed repop rear fenders fit 49-55 will a 1950 rear fender fit on this bed? I was just about to go pick some up down the road but now I'm on hold until I figure this out. damn this deal is getting ****py fast
  28. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I wouldn't say that you got screwed at that price. Lots to work with there, and you can certainly shorten up that frame and have some fun with it. You can always trade/sell that bed to get the proper bed for that style truck.
