Anybody have an interesting way to start your engine?
Discussion in 'The Hokey Ass Message Board' started by killa fab, Sep 29, 2011.
  1. Lotek_Racing
    Lotek_Racing
    No, you missed it, he paid a girl $100 to ride in his car :D
  2. amphicar
    amphicar
    Not to hijack the thread... It was a grandpa wanting me to give him and his 4 yr old granddaughter a ride. I said if he put that $100 in her piggy bank, I'd take him for free. I have only accepted $ for charity rides, NEVER for my benefit. That's just me.
    The best part is giving free rides to bikini clad hotties who always want to sit on top of the back seat. (reach up, adj rearview, smile) Then they always give me kisses and hugs after... I am no dummy! :eek: :D :cool: :)
    To return you to the regularly scheduled programming already in progress...
    Amphicars have a factory installed unique to Amphi sequence to start them. It is where car stuff and coast guard meet. I hesitate to say in public as it does serve as a theft deterrent.
    I dig the radio ****on version posted earlier!! I have always loved Rube Goldberg contraptions so weirder the better!
  3. hotroddon
    hotroddon
    That or a perfect case of why you shouldn't post on the HAMB with the crack pipe in the other hand
  4. BCR
    BCR
    Have you ever owned a Ford with this feature? (I have and do)
    It ****s enough to be honking the horn every so often while turning through an intersection, firing the starter on random turns would be a hoot!!
  5. bgbdlinc
    bgbdlinc
    ...geez, all I've got is a process -'29 Roadster w a flattie and 2x2's:
    1) uncover car;
    2) manually set chokes half way;
    3) get a ball peen hammer and tap the float bowls (tap, tap....tap,tap);
    4) pump gas twice, turn key...roars to life every time.
    (Note: if you skip #3 you risk self immolation...)
  6. flatheadjohn
    flatheadjohn
    Have a toggle switch on my dash with a host of other switches that's marked WTF if it's not on you ain't going no where. Have other theft deterrent devices as well but I'm not telling where.
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I think he always posts weird like that..i think its for attention..mommy didnt hug and kiss him enough? maybe?....
  8. jrt49box
    jrt49box
    If I told ya .... I'd have to kill ya!!!!!:eek::D
  9. Blackmaria60
    Blackmaria60
    I had an O/T one once that I had to arc across the Solenoid to start it, then reach underneath to shift the trans into D. Did that till the FL brakeline squirted me in the eye. I abandoned that vehicle in the Walmart parkinglot in Napoleon, Oh! LOL
    I was so over that thing. It was falling apart faster than I could fix it!
  10. dabirdguy
    dabirdguy
    A friend once told me his new girlfriend could start a motor by ****ing on the tailpipe, but I don't believe that the exhaust system would be air- tight enough to accomplish this.
  11. Ebbsspeed
    Ebbsspeed
    Don't you mean "closed"?
    On my 37 Buick, I turn the key to mechanically unlock the ignition lever, flip the ignition lever up, then push the accelerator all the way to the floor to engage the starter, via a switch in the carburetor. Once the engine is running, a vacuum switch disables the starter circuit. Goofy, you say?
    That's the way it came from the factory, 74 years ago.
    On my 56 New Yorker, I have to push the cigarette lighter in to ground the negative side of the electric fuel pump.
  12. 48FordFanatic
    48FordFanatic
    from Maine
    I have what is known as a Dial-Up Mag System. I dial a special phone number which provides clearance to initiate the engine start sequence. The sequence is initiated by a bar code memory encoder magnetically activated by placing a magnet fob on the dash in a secret location. This activates a transmitter under the floor that sends a signal to a communications satellite . The signal is bounced back to a receiver attached to the frame of the car....the frame acting like a big antenna. A rotating beacon and an audio alarm let me know when its time to start the engine. Push the " Engine Start " ****on and away she goes.
  13. Cheapstreet duster
    Cheapstreet duster
    from georgia
    ive done it with a crow bar on my 69 chevelle all through highschool....
    Headers are a *****...ya know...
    chepast
  14. OldTC
    OldTC
    I've still got an old pitted up Craftsman 7/16-1/2 boxend wrench in my box that had to be used to short the solenoid on my '60 Impala.
    No one ever stole that baby!
  15. Voice activated Ignition Switch..!
  16. diesel dr
    diesel dr
    from western NY
    Bought a '65 mustang for parts years ago, put a battery in it to see if it would run, opened the drivers door and the starter rolled the engine over....handy for robbing banks? It ran good by the way.
  17. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    When I was in high school I had a buddy with an old Falcon. Junky lookin POS. Had an old outboard motor top with a scoop looking air inlet and a pull rope starter mounted on the hood. He had a push ****on hidden inside the air inlet and he would turn on the ignition, put it in neutral, get out and reach inside and push the start ****on the same time as he was pulling the cord. It was hillarious.
  18. 1928Fordman
    1928Fordman
    I think you won. LOL :D
  19. amphicar
    amphicar
    My friends 51 Nash(car) you put the column trans selector in N then pull it towards you to engage the starter. More for the factory WTF category.
  20. Cub8556
    Cub8556
    ...I have a push pedal Buick... thats 'interesting' enough for me
  21. TONY2000
    TONY2000
    Fkin priceless, im laughing 20 minutes later !
    i think weve all been there with 1 car or another !
  22. I'll stick with the inertia... that's enough noise to piss off the neighbors!:cool:
    <iframe width="420" height="315" src="http://www.youtube.com/embed/WkPFRpbSU9o" frameborder="0" allowfullscreen></iframe>
    Much less complicated than all those fancy switches and levers...
    <iframe width="420" height="315" src="http://www.youtube.com/embed/vOl5YpFVGYU" frameborder="0" allowfullscreen></iframe>
  23. BJR
    BJR
    WTF who cares if the car didn't start....... All that matters is she was willing to try.
  24. falcongeorge
    falcongeorge
    from BC
    Now THATS an interesting way to start (Not start?) your car!
  25. Hot Rod Elvis
    Hot Rod Elvis
    One time at a show, there was this man talking about his car (don't even remember the car) to a group of people and it just started up! Everyone was scared stiff becasue there was no one around or near or in it. Found out later the old man had a remote starter in his pocket. Thought it was mighty neat!
  26. falcongeorge
    falcongeorge
    from BC
    My first car was a pinto with a small-block in it. The headers on the p***. side were pretty close to the solenoid, and when it was hot the solenoid would stick, so I would get out and whack the solenoid with a pair of vise grips. One time it wouldnt start, and I got a little carried away, and whacked it so hard a piece of the bakelite case flew up and bounced off my forehead. I know, not as interesting as Dons T-bird, but no small animals were injured...
  27. Hot Rod Elvis
    Hot Rod Elvis
    I don't think that'd work for the Duke Boys as they always slid threw the window:p
  28. Bet she didn't work with zoomies...:eek:
  29. tjmercury
    tjmercury
    Ummmmm........Screwdriver
  30. bulletproof1
    bulletproof1
    from tulsa okla
    i have a moon tank in the front and a stock style gas tank out back.. have a aeromotive pump for both tanks , they both go to the fuel block then to the carb.they are wired to a 3 way switch,, on each pump has a on/off valve.when i run the front tank with race fuel i close the rear valve . when on the street i close the front valve and run the rear tank. also have a battery kill...
