Pictures of my flat head super charger
Discussion in 'The Hokey Ass Message Board' started by ROADSTER1927, Oct 4, 2011.
  1. ROADSTER1927
    ROADSTER1927
    I want to put this on a later flathead and I need all the 3 groove pulleys to run it.Enjoy the pics,if you have any pulleys or ideas for them,please send me a pm.Thanks have a great day Gary:)
  2. Never thought I could be jealous, envious, and aroused all at the same time, TR
  3. Someday I'll find a Graham supercharger for my Chevrolet 4 :)
    Nice catch- enjoy it!!!
  4. I'm adapting one for my flathead :)
  5. Give up (p*** it on to me) and look for a McCulloch :) !
  6. hozem396
    hozem396
    from ohio
    I have never seen anything like that ever! Sweeeet!
  7. jipp
    jipp
    its all dirty better send it to me.. you do not want such a dirty piece crampin your style.. i do not have flat head so ill just treat as art :D
    chris.
  8. A friend's dad GAVE me one of those back in the 80s. Stupid, I didn't have an engine it would work on so I stored it and it got left behind in one of many moves...
    Is that another pulley on the back end of the shaft? The one I had didn't have any of the pulleys on it...
  9. ROADSTER1927
    ROADSTER1927
    The pulley on the back runs the generator. Gary
  10. woodypecker
    woodypecker
    Fantastic, Do whatever it takes to make it work.
  11. so what are you missing?
  12. HotRodJosh
    HotRodJosh
    Looks like a 1937 McCulloch. I run a 1940 on my flathead.
  13. Rusty O'Toole
    Rusty O'Toole
    That is a McCulloch, the first model they made before WW2.
    You might try some kind of industrial supply house for the pulleys. Industrial machinery uses all kinds of different pulley and belt setups. They should have a catalog. Or search online.
    There is probably a stock pulley that can be machined or adapted to your use.
    Do a search for McCulloch or VS57 there was a web site by that name with a lot of info on McCulloch superchargers including a couple of pages on the prewar jobs.
  14. ROADSTER1927
    ROADSTER1927
    top top Thanks Gary
  15. ROADSTER1927
    ROADSTER1927
    Any ideas for pulleys? Thanks Gary
  16. Irish
    Irish
    Like Rusty said...build one.
  17. barslazyr
    barslazyr
    Took this Picture because I thought it was cool.They only use two belts, Hope it helps
  18. nickk
    nickk
    i can dig it! awesome score
  19. hambhawk
    hambhawk
    from Bay Area
    Goes up and up-- like a gothic cathedral.
    looks so cool that it must be fake!!
    is to too early to revive the term 'schwing!'?
  20. Rockerhead
    Rockerhead
    Congratulations on finding a 1936 McCulloch supercharger. It was designed for the early 21 stud Ford engine. The rear pulley drove the generator that was mounted back on the side of the cylinder head.
    Attached is a photo of my setup. It is also a 1936 blower. I use Ford truck water pumps with 2 groove pulleys to drive the supercharger and use one groove of the blower pulley to drive the generator, mounted similar to the 1937-1940 models. It is a great conversation item but do not expect too much hi-performance - it puts out about 2 psi. Have some fun with it.
    Don www.montgomeryhotrodbooks.com
  21. 61 Fairlane
    61 Fairlane
    If all else fails and you have the pullies for your engine, or you can mic the crank diameter, etc. Take the pulley off the supercharger and take it to a maching shop. There are plenty of guys around West Bend, Germantown and Milwaukee. I used a guy in Pewaukee to make up a pulley for me when I just couldnt find what I needed. It wasnt cheap but it wasnt expensive either.If you decide to go that route, PM me and Ill give you the guys contact info.
    You'll have to give the guy the pulley diameter size you want, which Im ***uming is the same size as whats on the motor now, but I guess a supercharger that could be different, and then he can turn one for you with the correct Vee groove spacing.
