lets see your battery box
Discussion in 'The Hokey Ass Message Board' started by zgears, Sep 7, 2011.
  1. zgears
    zgears
    I'm looking for ideas for a nice neat battery box behind the seat of my roadster. If you have a nice battery box lets see it.
  2. Chopp'd49
    Chopp'd49
    I am using an Optima battery and made this tray out of 18 gauge flat sheetmetal. It is hard to see in this photo, but I think it is pretty cool
  3. RatPin
    RatPin
    guess we'll have to take your word for it...
  4. frankenfords
    frankenfords
    from SoCal
    I like the early '60 Ford Econoline battery boxes. They have a sanitary latch, a rubber seal, and vents out of the bottom. I have one in the cargo area of my strip-style Falcon Wagon.
  5. 60galaxieJJ
    60galaxieJJ
    That's pretty sweet
  6. vert1940
    vert1940
    this is an antique metal picnic basket.the battery sits about 4 inches in the floor and the basket covers it.the bottom of the basket is cut out,and i welded tabs on the inside to hold it down. i made a shelf in the basket to carry tools.the basket has vent holes from the factory in it for air circulation for the food you would have put in it.eventually it gets painted same color as car with the ford logo in the top.you can pick these up in an antique shop for about $20.00
  7. littlechris
    littlechris
    from MILWAUKEE
    that Econoline box is great
  8. hotrod_32
    hotrod_32
    I built a area between the inside rear wall and trunk to house batt. and other things I wanted to hide. Cut a hole in the floor and dropped the batt. down 2''s so it couldn't move around. Still get to it easy if I need a jump.
  9. 33Tudor
    33Tudor
  10. Deuce Roadster
    Deuce Roadster
    On both my 32 3W and my 32 roadster ... I wanted to have as much trunk space as possible ... so my battery is under the seat. Henry Ford put the battery there for many years. I use a group 24 battery and it does not hang down below the frame rail.
  11. Canuck
    Canuck
    Didn't have too much room in the trunk for a battery, so looked for a smaller battery. Decided on a Type 51 like the ones used in late model Honda's. Wasn't sure if one would have enough jam to start the big ol Buick so I made two boxes, one on each side of the Gas tank. Both boxes are vented under the car. Due to lack of room the tops are held on by screws and the sides of the boxes lift off.
    Styled after a 50 cal. box with ropey welds, handles on top and front, color and a stencil.
    If one battery has enough jam, will use the other box for spare parts or tool storage.
    Canuck
  12. hotrod_32
    hotrod_32
    Nice work Deuce ! Dash lookin good also/
  13. tommy
    tommy
    Shoe box Ford 49-51. Very traditional and you have to love the louvers.:D I bolted it to the back side of the 32 K member on the p*** side. A 32 sedan came with one and I finally figured out what it came from. You can't get one on a web site but they are usually not that expensive.
  14. deuce666
    deuce666
    from Oregon
    I fabricated this battery box to fit inside the '32 Ford rails and crossmember. 10 gauge plate on the bottom, 16 gauge on the sides, and some left over '32 gennie parts to make the mount.
