Are these F100 front hubs or ?
Discussion in 'The Hokey Ass Message Board' started by Crazy8, Oct 7, 2011.
  1. Crazy8
    Crazy8
    from KY
    I got a set of 55 F100 front brakes and I ordered the speedway bearing kit. The kit comes with bearings, races and seals. The rear bearing fits but the hub looks like it has the races made into them. Also the front bearing and the rear seal from the kit is to large. Here are some pics, I am trying to determine if they are or what are they. I am installing them on a 46 from spindle.
  2. oldrelics
    oldrelics
    from Calgary
    this is the difference between f100 (left) and f1 (right)
  3. Crazy8
    Crazy8
    from KY
    Here is mine looks like F100 but dont see ribs on side of drum....
  4. oldrelics
    oldrelics
    from Calgary
    Mine don't have ribs either
  5. RICH B
    RICH B
    The new bearings in the pictures have the correct numbers on them. Looks like you possibly have post '56 hubs that don't adapt to early Ford spindles. If you have the old bearings or you could knock out one of the races and see if the bearing or race number is for a later year F-100 to confirm this.
    The drums may be usable as the same front drum was used from '53 up to '62-'63 or so.
    F-1 and F-100 drums can be either smooth or any of several ribbed versions.
  6. Crazy8
    Crazy8
    from KY
    I have a rear bearing I will get the number from. Are the f100 spindles hard to get?
  7. bigscooter
    bigscooter
    the post '56 hubs have smaller od on the bearing races than the pre '56
    pre '56 inner od 2.717"
    post '56 inner od 2.5630"
    i wonder with a little machining the post '56 hub might work.
