Customs How should i extend the fender on my custom???
Discussion in 'The Hokey Ass Message Board' started by tankwilson, Oct 11, 2011.
  1. tankwilson
    tankwilson
    Hey guys. Thinkn bout changing bumpers, install all the stock trim, and shave the door handles. The car is bagged and will lay frame. I would like to come up with a solution to make the front and rear look lower. Bigger bumpers, extend the bottom of the fenders????? what your ideas??
    Thanks
    matt
  2. chaos10meter
    chaos10meter
    from PA.
    I think it looks real good the way it is except at the bumpers, maybe you could extend the bumper brackets lower the brackets and get them level with the pans would look lower. But then again what do I know ?
  3. tankwilson
    tankwilson
    The car lays even lower now than that pic but the front and rear still seem like they are in the sky. Doesn't need much, move the bumpers down, put on taller ones and mount same height, add an inch to the bottom of the rear part of the fenders????
    Lets see some bagged kustoms.
  4. Chris Stapley
    Chris Stapley
    With great looking bumpers like a 49 Plymouth has it would be a shame to take 'em off. Why not make pans to go underneath them painted body color, extend the rear portion of the rear fenders down to mate up maybe even do the same with the front lower section of the front fender heels too.
  5. tankwilson
    tankwilson
  6. You could extend the rear fenders something like that, but keep your bumpers, they're the coolest ever!
    Klaus
  7. tankwilson
    tankwilson
    not really the look im going for.
  8. 51 MERC-CT
    51 MERC-CT
    Section it.
  9. BCCHOPIT
    BCCHOPIT
    Just drive it it cool as is
    My .02
  10. tankwilson
    tankwilson
    Thanks i apperciate that. The car does have a good look but i want to take it to the next level and really give it all the right lines. The chop is awesome (thanks to choprods) and love the low look of laying frame, just needs a few mods here and there to really complete the look.
  11. 40StudeDude
    40StudeDude
    If you want it to look lower, the bumpers need to be lowered front and rear...the rockers right now are lower than the bumpers, and the bumpers being higher give it the illusion that it's not that low.
    I'd figure out a way to lower the pan below the trunk , that would in turn require you to lower the rear of the fender, that would make it look lower than it is. Same with the front bumper and lower front fender...problem with both is it makes it less drivable over dips and driveways that way.
    If nothing else, add some fender skirts to the rear, that always helps make it look lower...and I'd remove the stone guards too.
    R-
  12. 52pig
    52pig
    Bring the bumpers down and in, via modifying the mounts and tray. Could look pretty good that way. Would be a little work but worth it in my opinion.
  13. tankwilson
    tankwilson
    The frame sits an inch lower than the rockers. Thought about welding an inch on the rockers and reinstalling the rocker trim lower to sit on the ground. I think the fenders definatly need to be lower even if i only add an inch.
    any threads on lowering fenders??? where to cut???? where to add???
    Thanks
    matt
  14. 52pig
    52pig
    A lot more work, but you could channel it.
    It looks pretty low, and you say it goes down more? A friend of mine sectioned his frame so it would sit completely flat on the ground, he spent 2 years doing this. Obsessed...probably.
  15. tankwilson
    tankwilson
    naw dont want to do that much work. It lays frame now just need to make the body "appear" lower.
  16. NTAPHSE
    NTAPHSE
    The license plate is not doing you any favors. Start by moving that down and it would visually change the back of the car.
  17. tankwilson
    tankwilson
    Yea i'm strongly thinking about putting on 50 buick rear bumper on. It has a spot for the plate in between the bumper guards.... also the bumper is 3 inches taller than mines so it will be three inches lower to the ground. need to do some mockup and post pics.
    thanks
  18. 19Fordy
    19Fordy
    Straight side trim coming off the top edge of the front fender and going towards the rear.
  19. tankwilson
    tankwilson
    I have the belt line trim off a 50 plymouth fast back (will look similar to merc) and also have the stock fender trim i mite put back on.
  20. wbrw32
    wbrw32
    I've noticed that you have completely ignored the suggestion to run fender skirts,,,That alone will improve the long low look you desire.
  21. 19Fordy
    19Fordy
    You will notice that car designers of the 50's and 60's often added a strip of chrome or stainless to the lower third of the car so as to give it the appearance of being lower and sleeker.
  22. Flynn's_57
    Flynn's_57
    from Nor*Cal
    Pretty sure just dropping the bumpers will accomplish what you are after...
    If not, you could lower the highest part of the wheel-wells.
  23. LOWBLAZERO1
    LOWBLAZERO1
    i agree drop the bumpers
  24. resqd37Zep
    resqd37Zep
    from Nor Cal
    Man skirts would change everything. That should be your first step. Dropping the bumper without adding skirts is kinda goofy to me.
  25. Zeke
    Zeke
    stole the above dropped bumpers and did down and dirty skirts
  26. Yichoke
    Yichoke
    How about extending the rear fenders FORWARD instead of back? Plus long skirts that line up with the stone guard. Gives you a longer look without having to rework the entire rear end.
  27. That actualy looks very nice! makes the lines flow so much better!
  28. James D
    James D
    Thats exactly what these cars need. Seems like Mopar cheaped out and used the same (too short) rear fenders on two and four door cars. That why they look a little off.
    And don´t lower the bumpers. It just adds visual depth to the body, which is exactly what you don´t want.
  29. 60galaxieJJ
    60galaxieJJ
    I agree!
