clean flat black
Discussion in 'The Hokey Ass Message Board' started by trailer park playboy, Jun 25, 2011.
  1. trailer park playboy
    from tulare ca.
  2. got-h2o
    got-h2o
    from NW IN
    Wow man that looks great!
  3. Mothers spray detailer works awsome
  4. rougebeats
    rougebeats
    Thanks for posting pics of the end result...looks killer
  5. americanstandard1
    americanstandard1
    So I was thinkin of painting my car flat black and came across this thread..I was wondering about the SEM HRB...would you do a flat clear over that stuff or no? Is there any kind of flat black paint that you could throw some flat clear over to protect it/make it easier to clean up?
  6. 52carsontop
    52carsontop
    from East TN
    ttt would also like to know the above.
  7. Don's Hot Rods
    Don's Hot Rods
    from florida
    vividlyvintage suggested the tech wax routine on satin black so I decided to try it out on my 27 (painted with SEM Hot Rod Black) What a difference ! It really didn't make it shiny, like I feared, but just brought it back to what it looked like when the paint was fresh.
    I also noticed that rain and dirt clean off easier, and I still use Mothers Detailer to do quicky cleanups. I had the occ***ion to call SEM for another question and mentioned to them about the tech wax and they were surprised to hear it worked, they said it was probably because you simply put the wax on and do not let it dry, just wipe it right off. They said if you let it dry you would then be buffing the surface, which could lead to shiny in spots and dull in other spots.
    My car has been so much easier to maintain since vividlyvintage mentioned that tip............thanks VV. :)
    Don
  8. psychopathic51
    psychopathic51
    I had black epoxy primer on my cowl hood i made for my car and i used this stuff called 303 Aerospace Protectant is works great and has a 40 spf protectant in it to help keep paint and vinyl from fading. Works great on the vinyl bed covers also and a little goes a long way once you get it warm. Works excellent and protects against sun fade.
    Here is a link to the stuff.....
    http://www.bing.com/shopping/303-ae...2FD?q=303aerospace&lpq=303aerospace&FORM=HURE
    Can usually get it at parts stores or most truck and van places.
  9. Actually aside from the other suggestions a DA works wonders it'll clean the flat black right off of it.
    You could help yourself out a ton, once you get it clean lay a couple of coats of flattened clear over it. No more chalk spots, give it a rinse an a quick wipe and you're done.
  10. mustangsix
    mustangsix
    Flat paint is officially p***e.
    I just got back from Europe and saw no fewer than a dozen BMW's and Mercedes' painted flat black, silver, and gray......from the factory. When you see that, you know the trend is over. Kinda like hearing your favorite hard rock song on the elevator musak.......
