Had my White Walls shaved
Discussion in 'The Hokey Ass Message Board' started by Kerry67, Mar 19, 2011.
  1. slicknapier
    slicknapier
    from Tucson, AZ
    Is this cat in the Phoenix area?
  2. Kerry67
    Kerry67
    yeah he is.....he is not in the best health anymore and just does it from his home I believe. I am looking into one of these machines myself.
  3. slicknapier
    slicknapier
    from Tucson, AZ
    Very cool. Maybe somebody should do an apprenticeship under him to learn the trade..
  4. stealthcruiser
    stealthcruiser
  5. i have to look threw my attic some time. a uncle of mine managed a tire shop back in the day and gave me a tire buffer new in the box. i did not know what the hell it was for so i hope i just put it in the attic. i am thinking it is for this porpose. hope i still have it ! can start making my own ww tires.
  6. We had a fellow with a tire store here back in the 70s who had some
    sort of machine like that. I had him widen some whites on a 67 Ford
    convertible. It was done with tires on the car. The store has been
    closed for quite a few years now. I called him a while back to see if
    he still had that machine, which he said he doesn't.....but he may
    still have some of the grinding wheels. Need to get back to him to
    see. If he does, he might either give or sell them to me....but then
    what will I be able to do if I get them? Just need to see, I guess.
  7. stationWAGONS
    stationWAGONS
    from Vegas
    Cool - Curious - how far out from the wheel lip are those starting?
    About 1/2"...?
    Those tires are easy to get, too. Are they 215, 225/75r15s you have?
  8. springer99
    springer99
    Approx 1/2" is correct , most finish @ 2" wide safely with out getting to the uneven edge of the inlay.
    You can push the envelope & try & go wider but you run the risk as all tyres are not the same , re placement of the inlay !!!
  9. 54blue
    54blue
    That looks great! I'm gonna do it myself!
  10. 65PANELRAT
    65PANELRAT
    Bajito's in Alb. NM still grinds tires using that method. Cl***ic Cars of NM in Alb. buffs tires dismounted. Both do great work.
  11. That was cool, hey , who's the guy in the Army shirt? ;)
  12. Kerry67
    Kerry67
    I give up......Who ???
  13. Mr48chev
    Not really, Play with an old junk whitewall tire and a sanding disk a bit and you will see that there is a thin layer of black rubber laid over a fairly wide whitewall to get the desire narrow white wall. you just have to take the black back off evenly.
    There used to be a guy in the Waco, Tx area that made the rounds of the car lots putting white walls on tires on cars or making the white walls on a car match. On the car service and he could do it pretty fast.
    I'm lucky, my wife will walk a block before parallel parks any vehicle she drives as she hates parallel parking.
  14. hitman912
    hitman912
    Did this to mine about a year ago, no ghosting.
  15. chopper cliff
    chopper cliff
    from lodi ca
    how do you polish or keep them from cracking?
  16. Adrian Rollini
    Adrian Rollini
    They look great! I wanted to do that to my white walls.
