What is a fair price to pay to have your driveshaft shortenned?
Discussion in 'The Hokey Ass Message Board' started by malaguena, Oct 13, 2011.
  1. big creep
    big creep
    lmfao!!!!!
  2. Still_Crazy
    Still_Crazy
    from . .
    Shortened 1" and rebalanced. $125
  3. i think i paid $115 for shortening and balancing in NJ 7 or 8 yrs ago
  4. 53sled
    53sled
    from KCMO
    inland truck parts built me a new one for $225 in 6 hours.
    i shortened one for $.25 in welding and grinding.
  5. Panama Red
    Panama Red
  6. C4 Metal Werks
    C4 Metal Werks
    We have a guy here in Chico,CA that charges around $80.00.
  7. Sounds like they do the shortening, and you get the shaft.
  8. Bigdaddyhemi
    Bigdaddyhemi
    I just had a complete new one fabricated and the cost out the door 325.00. They must have quoted a new one
  9. mustangsix
    mustangsix
    Did it myself like the tech article, but around here $75-$100 is the usual.
    I used a big pipe cutter to cut it nice and straight and measured several times. Also, I took a piece of angle iron and drew an index line along the tube up to the yoke so that when I re***embled it, it was indexed the same way as before.
    After tacking, I measured several times from yoke to yoke to ensure it was square.
  10. JimSwann
    JimSwann
    Do it yourself, if you have a grinder, welder and a dial indicator.
  11. in switzerland those *******s charged me 450 swissbucks. Nearly 500$
  12. Deuce Roadster
    Deuce Roadster
    I usually just find a driveshaft the right lenght. :D
    The salvage yard I frequent has them hanging on a rack.
    Hundreds of them. The driveshaft in my 32 Ford roadster is a 1988 Chevrolet Corvette aluminum driveshaft. I had the change the yoke ( I have a 400 Turbo ) ... but the rest is just as it left Bowling Green Ky.
    A lot of the later model vehicles now come with the aluminum driveshaft ( Camaro/Explorer/Chevrolet pickups ect ) I have a Camaro aluminum driveshaft in my 32 3W ... even has the correct 700R4 yoke on it.
  13. 4950ford
    4950ford
    from cushing,ok
    I had mine done for my dodge in Tulsa and it cost me $120, and that was to have it shortend and new u joints and a new rear flange for my caddy rear end.
  14. zman
    zman
    from Garner, NC
    same here and they put new u-joints in it...
  15. HotRod33
    HotRod33
    I just had one done for my model A and it was 125 dollars with new ujoints.......
  16. outlaw256
    outlaw256
    i have no idea what they charge around here, but we shorten our own. we make our marks where we want to cut draw a line down the marked area and cut then line up the ends of the lines and weld. grind smooth and we are done. never had a problem with balance either.
  17. gsport
    gsport
