Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Wow, cant wait to see what the wheels will turn out to be.....
  2. Toby Denham
    Toby Denham
    from Georgia
    Great build thread!
  3. tmfcracing
    tmfcracing
    from Sweden
    Dont know but as i understand the black sand is used for "light pressure casting" . It gets hard when pressed together and is also re-usable.
    The sand we had was mixed up together with a binder liquid. As we did the lathe metod it was the way to go, this sand is not reusable.
    Later on when the model is done and there is time for casting the real 4 centers we are going for the light pressure casting ...with black sand :)
  4. tmfcracing
    tmfcracing
    from Sweden
    This method for making a model might seems a little bit strange but I just dont have a cnc lathe and if I ask someone to do it for me I better open up my walet.
    A very good friend of mine have this alu casting shop and we have fun doing it. :)
    Thanks you guys for all the positives :)
  5. tmfcracing
    tmfcracing
    from Sweden
    Lifting the half to take out the sand-center out and be possible to fill it up with aluminum.
  6. tmfcracing
    tmfcracing
    from Sweden
    Pulling out the center.
  7. tmfcracing
    tmfcracing
    from Sweden
    Fill it up and waiting.
    kiwijeff likes this.
  8. tmfcracing
    tmfcracing
    from Sweden
    And here is the alu-center backside............
  9. Django
    Django
    from Chicago
    It was exciting to see a Milner coupe get chopped up and reborn.
    Then I was impressed with the fab work. Very nice!
    AND THEN, you go an make your own wheels! Whoa!!
    As for the paycheck every two weeks, if you feel like moving to the good ole USA, I can help you with that. :D Although our last overseas relocation hire didn't work out, I think we'd all be willing to give it a go again for work like that. Very nice.
  10. tmfcracing
    tmfcracing
    from Sweden
    ........and the frontside, sadly there was a misstake using the "black liquid". It made the frontside a little but ruff but I think some grinding will do it .
  11. Jeem
    Jeem
    Alliance Vendor
    Great thread!
  12. loudpedal
    loudpedal
    from SLC Utah
    WOW! I never thought about making your pattern out of sand! That makes it SUPER easy.
    ...excuse me while I go fire up my foundry.
  13. bonesy
    bonesy
    Casting your own wheels! Now that's initiative.
  14. tmfcracing
    tmfcracing
    from Sweden
    Build my own Hi Tech Lathe today to be able to grind the center, at the start I used a hand-held drilling machine for motor. After some hard time with the grinder in left hand and the drill in the right hand I figuerd out that that the grinder worked perfect as the grinder and motor at the same time when I held it against the wheelcenter.
  15. tmfcracing
    tmfcracing
    from Sweden
  16. tmfcracing
    tmfcracing
    from Sweden
    After some grinding
  17. tmfcracing
    tmfcracing
    from Sweden
    Just had to put it into the Excelsior Tire =)
  18. Fireant
    Fireant
    from Texas
    That looks awesome! Great job.
  19. Niklas sweden
    Niklas sweden
    Brutalt fränt Martin!
  20. kram
    kram
    Wow, cool stuff!
  21. Mart
    Mart
    So is the disc a dummy front to give the early Halibrand type look, or will it be a structural piece??
    Looks great after the cleanup, but doesn't look strong enough around the outer edge to attach to a rim as a structural piece.
    Mart.
  22. tmfcracing
    tmfcracing
    from Sweden
    It's a model that wont be on the car, I will glue on 5 ribbs on the backside to make the real once stronger. The disc is also a 1/2 inch thick. When we cast the 4 real once the ribbs and center will be one solid part. Hope you understand :)
    On the frontside there will be some text around the midsection, 3/8 inch tall.
    Anyone with some idea about what to write ?
  23. tmfcracing
    tmfcracing
    from Sweden
    Except from the wheelproject I have spend the last week putting the ch***i apart and started doing some final welding and today i notched the frame for more rearend-clearence.
    Next thing is sandblasting and painting :)
  24. tmfcracing
    tmfcracing
    from Sweden
  25. scootermcrad
    scootermcrad
    Wow! Been watching this thread and now it's time to say...
    ...WOW! Fantastic work!
    Be careful! You might get some requests for wheels! :D:D
  26. kiwiandy
    kiwiandy
    Thanks for sharing all those pics. The sand lathe is a great idea. Never seen that before. Great build! Cheers.
    Andy.
  27. hotrd32
    hotrd32
    from WA
    Always great to see a 5 window saved and put back on the road, especially one that was screwed up. Looks great so far and your work is excellent! Love the initiative to build your own wheels, bigger balls than I.
  28. BAD PENNY
    BAD PENNY
    from mass
    Really cool stuff. You sir are a true craftsman !!! Going back a couple pages, I love that column drop. Thanks for posting. :cool:
  29. Chris5.7ltr
    Chris5.7ltr
    I'm loving this build!
  30. tmfcracing
    tmfcracing
    from Sweden
    Thank you guys for all nice feedback :)
    This saturday gave me 6 hours in the shop, some more tig welding and also done with the rear notching. Ended the day grinding the boxing-plates.
