Folks Of Interest 1938-1939 Ford Truck Club!!
Discussion in 'The Hokey Ass Message Board' started by squigy, May 12, 2010.
  1. Rods & Relics
    Rods & Relics
    It is like a rope in that channel that the tacks go into ;)
  2. pex
    pex
    from alberta
    on that strip in my cabover there were 3 small blocks of wood about a inch thick screwed to it that the headliner screwed to. my truck on the salt on its maiden voyage.2k miles round trip. [​IMG]
  3. Rods & Relics
    Rods & Relics
    By the way, congrats on the trip!! (my mate was there, even doing a day's scrutineering............we are both scrutineers here in OZ)
    anyway, Bill Jansen from Oz sent me a link to your pics, looks like a good road trip (p.s. what size wheels & tyres are you running? thanks!)
  4. unkamort
    unkamort
    Thanks! I may try to form a piece of wood that extends further outboard for some extra support.
    Very nice COE ya got there! I like the color too... Congrats!
  5. pex
    pex
    from alberta
    the tires are 235-75r-15's all the way around. the colour is grey primer with 15% aqua paint mixed in.
  6. Rods & Relics
    Rods & Relics
    Thanks pex (for some reason I thought they where larger than that :confused:)
    Just thinking about my "pile of bits" of COE's I have stored for a "one day" project.
    CHEERS
  7. Old Roadster
    Old Roadster
    Just bought a 38 yesterday, clean, Ford black and orignal. picking up tomorrow and will post some pic's. Needs tank boiled , change fluids, tune up and good to go. Ah yes and brakes..........Keep posting pic's love those 38's & 39's
  8. On the issue of the square hole in the middle of the dash. The cutout was for an ashtray. '38s all had this cutout and had an ashtray from the factory. '39 does not have the hole. If a '39 has an ashtray, it's an add-on that was available from the dealer that attaches to the bottom lip of the dash.
  9. HRs&HDs
    HRs&HDs
    I'm in. No pics now buy my avatar is pretty good. I love my truck. Did suicide doors on it .came out cool. Sbc, 2004-R, 3:08 10 bolt. It's a real highyway runner.
  10. Old Roadster
    Old Roadster
  11. mlg, im in ga. and hunting a 38-39 project. can you find out anything on the one in your post? thanks
  12. street rod lover
    street rod lover
    from taylor,mi.
    worked on mine today. :D finally getting back to replacing there rear frame section.
  13. Ed Wrath
    Ed Wrath
    I would like to be in..............but I'm still looking for a truck.........Anybody know of any?
    Please PM me.
  14. street rod lover
    street rod lover
    from taylor,mi.
    rear frame section replaced and repaired.
  15. Old Roadster
    Old Roadster
    Nice work street rod lover, keep us posted on the progress......
  16. street rod lover
    street rod lover
    from taylor,mi.
    mocked up rear end,installed posie spring. back on the ground finally. splitting the rear wishbones next. now i need to lower the front some.
    Greg Ham likes this.
  17. unkamort
    unkamort
    Sorry to come begging ... But I just cant get my head wrapped around how this hood latch works. Photo 1 shows the latch pin. Its indexed so I can't screw that part up (maybe). Pic 2 shows the latch plates and they appear to be keyed to each other... but only the thicker one rotates? Pic 3 shows my best guess at an assembly. Many thanks again to Hammers who helped me out with these pieces. Finely... Pic 4 shows the latch plate in relation to the pin. Which way is up???
  18. unkamort
    unkamort
    wrong pic for #4... and I;ll add one more... easy to see why I want this to work
  19. Blue
    Blue
    I believe you've got both plates 180 degrees out of line.
    In your picture #1, in the hood "crossmember", you can see 2 small holes either side of the main shaft hole. The 2 tabs on the triangular shaped plate fit into those 2 holes.
    The 2 tabs I refer to are at either end of the long edge of the triangle, and have a small hole in each tab.
    So, the triangular plate goes at the top, on top of the thicker plate - the tabs come down through the holes in the crossmember - and the long edge of the triangular plate will be closest to the windscreen.
    Now, on the rear edge of said crossmember, you'll see 2 holes where a flat spring attaches. The spring has a ridge that fits into a notch on the thicker rotating plate when the hood latch is in the closed position.
    I'll try to get some pics on here.
  20. Blue
    Blue
    See if these are any help. I've shown a pic of my spare catch but don't have the other plate.
  21. Blue
    Blue
    Pic #4 above shows the catch partially open so what you're looking at in the centre of the hole, is the V (worn) at the front of the triangular shaped plate and the other plate rotating away from it...
  22. unkamort
    unkamort
    Thank you very much sir! Looks like I could possibly make a spring tab from a dizzy cap clip. I also see that it looks like I have the spring up-side-down. Dose the hood 'pop up' a bit when when the latch is released?
  23. Blue
    Blue
    Yes your spring could be upside down.
    Looking at my catch mechanism, I see it's quite worn, in need of a rebuild - the hood doesn't "pop" up. If anything it settles down a bit when the catch is released.
    One step further along?
    Good luck.
  24. unkamort
    unkamort
    Yep... think I got a handle on it now! If anyone has a spring clip they would care to part with... in the market for a hood support too, I'd love to hear from ya!
  25. orange39
    orange39
    from Roseville
    Happy New Year . . .
    Hey, are you changing the the suspension b/c it's going to be a better ride?
    Or just to get a lower profile?
    How wide are your rear wheels?
    Thanks,
    Dave
  26. red one
    red one
    Sign me up,I'm in Toronto Canada and I'm beginning to thiunk that i'm the only one up here with a 38/39 Ford pk,,feelin lonely.
  27. 1930FordCoupe
    1930FordCoupe
    from The LBC
    Some pics of my '39. Was a Minnesota farm truck until last November when it came out west. It is a work in progress, but I typically drive it 4 or 5 days a week. Does anyone know if the horn in the picture is correct for a 39? I bought it from a really nice guy who took it off a '40, but I am trying to keep the truck as original as possible. Thanks!
  28. Old Roadster
    Old Roadster
    Really good looking truck, love the fog lights and the bumper guard.
  29. 1930FordCoupe
    1930FordCoupe
    from The LBC
    The fog lights are my turn signals. Still trying to figure out what car the bumper guard is off of. . Someone said possibly a Buick
  30. billcox@kgbc.org
    billcox@kgbc.org
    from Sacramento
    It is the same as my horn so a good guess it it is correct. do you have any pictures of your rear bumper and tailgate? I'm trying to figure out how to install the rear bumper so that you can see the license plate.
