How to remove the inner door handles on a '51 Ford pickup
Discussion in 'The Hokey Ass Message Board' started by pineconechevy, Oct 17, 2011.
  1. pineconechevy
    pineconechevy
    Hi all,
    If this thread is in the wrong place just let know and I'll take guidance on where it belongs. I'm a FNG and am learning.
    OK, I have a cab to a '51 F2 that I am getting ready for a visit to the body shop. All four inner door handles seem to be attached the same way. I see a little round hole in the handle when I pry back the estucheon ring a littel bit. But I can't see well enough to tell if it is a HEX screw or a rolled pin that hold the handle in place.
    I don't want to break anything. I've busted way too much chit over the years by doing first and thinking/asking second.
    How do I get these ******s off?? :confused: Hacksaws, M-80's, torches and crowbars are off the table. I want to re-use them as they are in nice condition.
    Thanks for any replies.
    Tom
  2. chrisntx
    chrisntx
    from Texas .
    not a roll pin but it is a pin. When you drop it in the dirt and lose it, cut off a piece of 1/8" welding rod for a replacement
    Push the spring and plastic collar away and you will see it
  3. Ole don
    Ole don
    Hold the cover back top and botom and push the pin through.
  4. Atwater Mike
    Atwater Mike
    There is a Snap On hose tool that resembles an offset s****er, with a wide, forked end.
    Put the fork under the escutcheon (beneath the handle) and use a 3/32" flat nose drift (long shank punch) to drive the pin out.
  5. pineconechevy
    pineconechevy
    Thanks Chris, Don & Mike.
    I feel ready to tackle the removal now.
    And uh, Chrisintx......you didn't say 'IF' I dropped the pin, you said 'When I drop...'
    I resemble that remark. ha ha ha
    Thanks again.
    This site is great.
    Tom
