’28 Tudor update #6; Steel Roof Covered by Stock Vinyl
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Oct 18, 2011.
  1. Just Gary
    Just Gary
    1. I made a plywood template; one edge matches the stock roof’s lengthwise crown, the other follows the lateral crown….
    2. …and took it to a local junkyard to shop for a matching donor roof ~74” x 43” with no lengthwise ribs. I was looking for a Volvo station wagon but found an ‘86 Toyota minivan matched perfectly.
    3. A battery-powered sawzall got me a new roof and three interior reinforcing crossmembers, one of which contained a dome light and wiring. Thanks to my buddies who loaned me the sawzall and helped with the roof-lobotomy.
    4. There are two ways to weld the insert: You can either lap-weld the insert over the stock hole, leaving the stock lip where the wood slats used to rest. Or you can remove the lip and ****-weld the insert.
    Since I was using a MIG welder, I chose the former, because (a) there’s no gap between the patch and roof for the welder to blow through, (b) vinyl will cover the seam anyway, and (c) the lip’s rigidity helps minimize warpage, which was a huge concern.
    5. I applied ****m, then measured and marked scribe lines and cut it with a jigsaw and new blades. The patch overlaps the stock sheetmetal hole by 0.25” on all sides.
    6. Then I sanded both the patch and roof down to bare shiny metal and sprayed the edges with weld-thru primer.
    7. Tack, check, pound, grind, repeat… All welding was done with my small but trusty Lincoln 140C with Argon/Co2 mix and ESAB “easy-grind” 0.025” wire.
    8. The long weld seams shrank a lot. I minimized it with short tacks and moved around to prevent heat buildup, but the shrinkage around the patch’s perimeter raising a noticeable “bubble” above and between the rear windows.
    9. I alternated between ~20 minutes of tack welding, followed by ~three hours of hammering on-dolly around the perimeter to stretch it and drawing down the bubble with a shrinking disc, then checking my progress with the plywood template and repeating the tack weld/hammering/shrinking process.
    Also, the roof’s extremely low crown (it’s almost flat) would cause it to oil-can if not for the shrinking disc and the Toyota minivan crossmembers.
  2. Just Gary
    Just Gary
    10. I rolled the car outside for a better view of its silhouette. Once the bubble was eliminated and the weld seam was complete, I ground it down almost flush and sanded it with a 4.5” sanding disc.
    11. I added small patches at the front corners- in the remaining gap between the stock roof’s sides and the header panel.
    12. I sprayed a light rattlecan primer guide coat and sanded the roof with 80 grit on a longboard. This exposed the remaining highs and lows that my clumsy hands couldn’t detect.
    13. More hammer & dolly and shrinking disc work, followed by a temporary coat of black rattlecan primer to protect the bare metal from our northern Virginia humidity.
    14. Later (after media blasting the entire body), I’ll weld the inside Toyota van crossmembers to the stock lip (but not the roof skin itself). The vinyl top will be added later, after blasting, epoxy primer and a thin skim coat of bondo over the seam.
    So there you have it! What do you think?
  3. green53ford
    green53ford
    from Wisconsin
    Thats the way i did it on my 31 tudor. I used a roof from an early 70s ford wagon. But this was almost 30 years ago. I still have the car today.
  4. Boxcar's 1928
    Boxcar's 1928
    I've a 28 Tudor top in my future as well, thanks for sharing. I'm searching for a top with ribs. Fine job.
  5. need louvers ?
    need louvers ?
    Great way to go with the vinyl top and all! The filled roof section adds sooo much rigidity to the body of Model "A"s it's almost unbelievable. Good work finding the Toyota deal too!
  6. djust
    djust
    from Oklahoma
    Looks great.
  7. Bruce A Lyke
    Bruce A Lyke
    Nice work, very resourceful!
  8. deadbeat
    deadbeat
    wow, great job.Alot of hard but fun work & the final result is amazing
  9. scrap metal 48
    scrap metal 48
    Looks good.. Nice job..How much is it chopped???
  10. Looks great! Thanks for the tip on the Toyota van!
  11. motoandy
    motoandy
    from MB, SC
    Great job. I used an 84' Astro Van flipped around backwards. Short tacks and movement from side to side is key. Looks nice
  12. Brads MONSTER
    Brads MONSTER
    from Buford GA
    I like it keep up the great work
  13. 40Standard
    40Standard
    from Indy
    nice job, any pics with the vinyl on it?
  14. gbgh
    gbgh
    Couldn't ask for a better tutorial ! Thanks!!
    Just Gary likes this.
  15. scott34
    scott34
    Thanks for the great detail in the pictures
    It will be helpful with my 34
  16. barrnone50
    barrnone50
    from texas
    Great Job!! thanks for sharing your handy work I might try this on my 31 Tudor great tutorial on the roof.
