how lond did it take to wire your first hot rod?
Discussion in 'The Hokey Ass Message Board' started by guido`s 40, Oct 18, 2011.
  1. guido`s 40
    guido`s 40
    from nebraska
    how long did it take you to wire your first hot rod? seems like it is taking for ever its my first time,I seem to keep going back over everything I have done it has been a slow process but I want to make it as clean as I can and right
  2. KJSR
    KJSR
    from Utah
    Thought about it for a month and then did it in six hours.....
  3. rustrodder
    rustrodder
    I wired my first hot rod about 6-7 years ago and used a Qwik-Wire harness. Took me about 3 days working about 3-4 hours a day. I went slow and took my time. Amazingly everthing worked fine! alex
  4. 1971BB427
    1971BB427
    from Oregon
    Spent a bit over one day wiring it.
  5. pineconechevy
    pineconechevy
    Spent about 18 hours doing every square inch of wiring in a '57 Chevy.
    I didn't own a good crimping tool so I had a lot of re-do's.
    Tom
  6. Metaltwister
    Metaltwister
    My first car wire job was an ignition switch, coil, head lights and one brake light. It took about 3 weeks. LOL Na, not really it was done in no time. Hang in there and do it right the first time no matter how long it takes... You will be happy that you did it right down the road.
  7. guido`s 40
    guido`s 40
    from nebraska
    sounds like I am doing about the same except for the six hours thanks!
  8. PRB
    PRB
    from Az
    Not too long and I think electricity is like magic. If you are redoing or repairing an old harness it may take a long freakin time to ID wires etc, especially if it has been jacked up by a PO.
    OTOH I have a rebel wire harness and each individ wire is embossed with it's function so it's pretty bulletproof...I think most new harnesses have that feature unless you are going for a cloth wrapped original deal.
    A short days work to get it all channeled properly but you'll get to every connection part as you build it up....take your time to make it as sanitary as poss especially behind the dash leaves excess wire for bundles. Save headaches later.
  9. caseyscustoms
    caseyscustoms
    from st.joe, MO
    x 2.
    just make good connections the first time and you will never have to **** with it again.
  10. 1971BB427
    1971BB427
    from Oregon
    I think it's easier to gut all the old wiring and start from scratch, than it is to repair or replace part of it. Mine had virtually no wiring anywhere, and not even lights or gauges, so starting from scratch with new parts (or rebuilt parts) made it faster.
    I used NW Autowire's 12 ckt universal kit, and it came with a nice wiring diagram for various makes of cars. Simple, easy, and inexpensive.
    http://www.nwautowire.com/servlet/the-10/hot-rod-jeep-14/Detail
  11. Zeke
    Zeke
    generic wiring kit for my ex 54 chevy... about 6 hrs after reading the instruction and figuring out where all the connections were.
  12. Boeing Bomber
    Boeing Bomber
    7-8 hours, Thanx Ron Francis. Not a problem in over 20 years.
  13. 40Standard
    40Standard
    from Indy
  14. flat 39
    flat 39
    two weeks @ 3 hours a day.
  15. scrap metal 48
    scrap metal 48
    Wired my first hot rod(street rod) in the late 70's.. Took me about 1 month to wire my 38 Chevy and worked fine, all in BLACK wire... What an idiot.....
  16. plymouth1952
    plymouth1952
    five days with loming counted in used a ron frances bare bones kit
  17. miraclepieco
    miraclepieco
    Four weekends, but that included soldering and heat-shrinking every connection.
  18. tfeverfred
    tfeverfred
    Did mine from scratch. All told, about 12 hours.
  19. Russ B
    Russ B
    First one, probably a day or so, forty five years ago, mol. Car Craft had a Model T hot rod build in a series of issues. I just followed guidance of their wiring diagram issue.
    Most recent rewire took me a couple months. I used an Enos box; wires from a Rebel kit; fusible links, relays and remote solenoid from MADD; gauges from Cl***ic Instruments; and wiring diagrams - my own design adapted from multiple sources. Most of the time was figuring what I wanted, waiting for parts, and trying to resolve design issues of previous rewire jobs.
    both were of Model As.
  20. PhilJohnson
    PhilJohnson
    My ole 53 Cranbrook took a couple of days with a couple of friends helping. However it didn't turn out the best plus my friend wired in all in one color (red). I'm sure who ever has the car now is probably thinking what kind of idiot would wire a car with all one color.
  21. Russ B
    Russ B
    I originally did the wiring of the Model A (I just rewired this last year) in all Black wires back in the 90s. It was tough to see and get enough light on the job. ...and then it was almost impossible to figure out any problems later on. Thankfully there were few problems that ever came up in over 15 years. ...but I agree, it was a big mistake to do it in black.
  22. gasserjohn
    gasserjohn
    not very long
    1wire from bat to coil
    1wire from coil to dist
    2bat wires [bat on running board]
    jump start at starter
    away to gas station& road test..............
  23. tedley
    tedley
    from canada
    Wired my first 30 yrs ago. Can't remember how long it took but i'm sure it took awhile. Still using it today. Althou looking around it could have been neater. No wiring kit back then. Gl*** fuses to. Makes me laugh.
  24. kemp kid
    kemp kid
    scratch wired mine in 1 day. diagrams look scary but once you start wiring it that **** gets easier then stressin out thinkin about it!
  25. chrisntx
    chrisntx
    from Texas .
    My first hotrod is a 47 Mercury with 392 Hemi that I wired in the early 1970s and then spent 100 hours wiring just the console. I have toggle switches for everything.
    I have a switch that turns the brake lites off!, you know, in case the cops are after me.
    A switch that allows the interior lights to come on when the door opens and another that turns on the interior lights when the doors are closed.
    Headphone jacks for four p***engers, interior lites on the console, all my gages are in the console, radio is in the console and a couple of speakers, glove box with light in the console, you can tell I was influenced by the 60s custom cars
    The car has a tilt front end powered by a convertible top motor and cylinders.
  26. Sheep Dip
    Sheep Dip
    from Central Ca
    Good Harnesses, I've used them a couple of times with great results.:D
  27. MR. FORD
    MR. FORD
    from Austin, TX
    Rebel Wire kit, took 1 day for everything. Do yourself a favor and get a Power Probe.
  28. Urhur
    Urhur
    It took the amount of time to cut a hole in the firewall and install the excellent '73 Nova wiring harness I scavenged from, what else, a '73 Nova, from which I also took the fuel tank, transmission, differential, dash cluster, brake lines, spare tire, sheet metal (for rust repair), and I forget what all else, for my '40 Chevy Master Deluxe. The two cars are almost exactly the same length and weight, and blend beautifully together. A '73 Nova wiring diagram, is available free online, and it's all in living color! Parts for all the Nova stuff are available at any NAPA store within 24 hours. I know this doesn't mean anything to you Model A guys, and I mean no disrespect. Just saying that a little planning and research can save you lots of time, headaches, and bucks.
  29. churchboy
    churchboy
    I used Tex Smiths electrical wiring book. The book was great, it showed how to make a fuse block from scratch (gl*** fuses), each circuit is drawn out, how to wire headlight switches, sterring colomns, it covered everything. A great book, everything worked first time. It took longer to find everything I needed than it did to wire it. it took me about a week.
  30. Steves32
    Steves32
    from So Cal
    I did my 1st car in the 60's. There were no kits then. You bought spools of wire & gl*** fuse blocks. Probably a few weekends to do the car. I would draw out all the circuits before I started.
