please help id an axlei saved from the scrapper
Discussion in 'The Hokey Ass Message Board' started by butti, Oct 24, 2011.
  1. butti
    butti
    I saw this on the s**** mans trailer and bought it from him for $30. I figured it was worth the gamble...
    Anybody know what it is? Im scouring google right now but so far no luck.
    Someone made a trailer out of it many years ago and welded the spindles to the axle but i have my fingers xed that maybe i can use the hubs,drums and backing plates on my 30 model A axle...
  2. David Chandler
    David Chandler
    Late 40's or early 50's F1?
  3. Pete
    Pete
    Early Chevy.
  4. alchemy
    alchemy
    Yeah, you gambled and lost.
  5. el Scotto
    el Scotto
    from Tracy, CA
    Yep, early Chevy.
    On a positive note, you might be able to use the spindles, brakes and such on a tube axle from Speedway. They make tube axles that use Chevy spindles.
  6. butti
    butti
    Oh well,it was worth a shot. The spindles are welded to the beam and the kingpins are welded in... its all s****.
    Thanks for the replys
  7. chaddilac
    chaddilac
    Not technically s****... lots of guys use them on g***ers!
  8. 2manyprojects
    2manyprojects
    you could use it for trailer axle
  9. butti
    butti
    Im gonna put it in the back of my truck and carry it everywhere i go so that next time im tempted to buy junk i can just look back there and be reminded that i already have plenty.
  10. F&J
    F&J
    The way s**** keeps going up, you maybe will do OK.
  11. Bruce Lancaster
    Bruce Lancaster
    5 lug early Chevy??
    Anyhow, I think rust is sufficient that nothing from brakes would have been realistically rebuildable.
  12. butti
    butti
    The backing plates look rough in the pics but they are def good. the drums are mismatched and one of them is grooved bad. the other is good.
  13. Alienbaby17
    Alienbaby17
    :D:D:D A thought we could probably all benefit from. :D:D:D
  14. 38Chevy454
    38Chevy454
    Spindles definitely Chevy. The axle is parallel leaf (duh...) meaning it is from an early car to 41, or truck up to 54. Can't tell specifically. The 5-lug hubs are probably 49-54 car, which fit the truck spindles. That is my best guess as to what you have specifically.
  15. 48 Chubby
    48 Chubby
    Be careful about that.
    I bought a rear end off CL that ended up being some thing I couldn't use. Made my self haul it around as punishment. Not even two weeks into my penance some guy offered me enough for it to make a $5.00 profit. Now I'm haunting Craig's again. Didn't learn a damned thing.:(
  16. butti
    butti
    i am confused... i had a guy here buying some stuff who said the drums and hubs were def ford so i cleaned them up a bit and sure enough the hubs have ford stamped on the dust seals but they do not seem to fit my 46 square back spindles. any ideas what hubs these are??
  17. squirrel
    Take out the bearings and find the numbers on them.
    I don't see anything Chevy in your pictures, but I'm not real familiar with the Ford truck axles over the years. Ford used solid axles and parallel leaf springs from 49-64. but those brakes look pretty early.
    Dodge and international used the smaller 4.5" bolt pattern at that time, I think. Chevys were 6 lug.
  18. butti
    butti
    the inner bearing is lm 48548
    the outer is lm 11949
    the hubs are 5x5.5 and the drums look like ford to me but im just comparing to pics off the net so thats really just a guess..
