Is this gay or just a good idea
Discussion in 'The Hokey Ass Message Board' started by steel rebel, Oct 24, 2011.
  1. JimC
    JimC
    from W.C.,Mo.
    That's what we do around here.
    Just cout the elastic top to fit.
    The Gold Chainers use Brand newSocks.:)
  2. cheveey57
    cheveey57
    Then you go to the Maxi.Pads!
  3. cool57
    cool57
    Did you try dryer sheets?
  4. steel rebel
    steel rebel
    I must not be gay. I can't stop looking at your avatar. Thanks for responding.
  5. fogs58
    fogs58
    from ooo
    I always thought the only cool way to do it was wrap a orange shop rag around it with a little duct tape lol. This was an old trick used at the dirt tracks for years.
  6. tattoocharlie
    tattoocharlie
    from omaha,ne
    in the pic they look black but they say pink is the new black.....so are they really pink?
  7. knotheads
    knotheads
    a red or blue grease rag is the traditional way.
  8. steel rebel
    steel rebel
    Would you put a pvc on this? If so you might be gay.
  9. hozem396
    hozem396
    from ohio
    and what color are your fingernails?????
  10. tfeverfred
    tfeverfred
    I used to use an old sock. Then, I tried the breather inserts that have a baffle inside. Summit sells them, as well as a few others. They work great and will keep you from being gay.
    http://www.summitracing.com/parts/MOR-68775/
  11. brad chevy
    brad chevy
    Putting a pcv valve ain't going to take away from the looks of the engine than that goofy looking top water hose. Fix your ventilation problem and quit being a poser. Thats whats gay about this whole thread.
  12. lostn51
    lostn51
    from Tennessee
    I use cut off pieces of old T shirts to keep mine from dripping, hell I like this idea better!
    Billy
  13. Atwater Mike
    Atwater Mike
    Cylinder taper, ill-fit rings, guides/seals, constant lugging of engine...
  14. Atwater Mike
    Atwater Mike
    Norm Grabowski had that identical upper radiator hose on the original 'Kookie Kar'. Caddy upper flex hose is now an icon...
    More 'gay' to get out and start wiping oil off your engine in front of spectators...
  15. JaBoney
    JaBoney
    Engines are supposed to be oily! Makes them manly. Loose the scrunchy.
  16. captaintaytay
    captaintaytay
  17. 29sportcoupe
    29sportcoupe
    from arizona
    I actually use scrunchies in my hair, not to sop up oil.
    Now I might have to cut up some of my good black socks as recommended.
    Oil keeps the rust at bay, and chicks dig it.
  18. RichG
    RichG
    Sorry, I couldn't resist :D
  19. captaintaytay
    captaintaytay
  20. go-twichy
    go-twichy
    but then he would try and do it with you.[​IMG]
  21. dontlifttoshift
    dontlifttoshift
    That's a dude....
  22. What if ya go commando?
  23. milwscruffy
    milwscruffy
    A wrist sweatband sold at sports stores in various colors always worked well for some of my friends cars. As for me I'd try to fix the problem rather than put a band-aid on it.
  24. Mmfh
    Mmfh
    from Oregon
    Could you not put a sponge or something similar inside the tube as a oil catch, what it stops from getting out would just drip back into the crankcase.
    Mm
  25. Sphynx
    Sphynx
    from Central Fl
    Libarace was gay ???
  26. 49F1Jeff
    49F1Jeff
    from Oregon
    "Is this gay or just a good idea?"
    Yes. ;)
  27. AKA Kustoms
    AKA Kustoms
    from Racine, WI
    Poor Liberace, he was great at the piano, but he ****ed on the organ.
  28. people have posted on here on how to install a pcv on older motors without making holes in the valve covers. i'd rather see a pcv than a pair of boxers wrapped around the breather tube.
  29. 73super
    73super
    Ewwwwwww!!!!!:eek:
  30. BOWTIE BROWN
    BOWTIE BROWN
    I would have done the RAINBOW KOLOR .
    "AND THE BOWTIE ROLLS ON"
