Column shift conversion
Discussion in 'The Hokey Ass Message Board' started by lukey, Oct 26, 2011.
  1. lukey
    lukey
    I am goimg to swap the 223/3 on the tree in my 58 ford custom 300 to a 302/aod this spring. Question is, is there a way to convert the stock manual trans column shifter to work with the auto trans? I have used the search, but the computer is smarter than i am! If not, i will be on the hunt fir an auto column. Thanks everybody!
    -LUKEY-
  2. Sure, adapt a cable shifter to it. Or round up a factory '57 auto shifter.
  3. VespaJay
    VespaJay
  4. niceguyede
    niceguyede
    from dallas
    I made a detent plate for the 55 fairlane I just finished. I found some rods that worked(our trans guy thought we were going floorshifter so I had to fab some shit). Then I made a plate that fit in the factory auto shift rod u-bolt set up(our donor car was an auto). Then I shifted it though the gears and marked where the pin hit for every gear and park and drilled holes so it was a positive lock in every gear. I put an extra spring in the shift rod housing so it was more inclined to rest against the plate I drilled. I checked my computer, but all the pics are on the shop comp. Pm me if you would like em and I'll dig em up. It isn't a hard conversion, just time consuming.
  5. lukey
    lukey
    Niceguyede, pm sent your way!
    -LUKEY-
