I would like to know can I reverse the starter motor on my 8BA engine. These things were positive ground. I want to make it negative. Thanks! Mike
You don't need to reverse anything. I changed my 59AB to 12v NEG grd, and the starter worked just fine.
WOW! That is amazing! I am going to test it out. Can anyone explain why this is? All DC motors I have ever dealt with are polarity sensitive. Mike
they work just fine as 12v negative ground, as a precaution install a NEW bendix spring and bolt, they turn over with much more torque and the old springs like to snap, past experiance has us keeping a spare in the trunk..
DC motors that reverse direction when the current is reversed use permanent magnets in the housing (field) and electromagnets in the armature (the part that spins). Reversing the current only reverses the polarity of the armature, so the motor turns the opposite way. Older starter motors are universal which means that they can use either DC or AC power (and will always spin the same way regardless of the way they are connected). The reason is that both the field and armature are electromagnets that will change polarity simultaneously if the current is switched.
