painting a steering wheel
Discussion in 'The Hokey Ass Message Board' started by 55delray, Oct 27, 2011.
  1. 55delray
    55delray
    from Florida
    A few years back I picked up a lecara mark 10 steering wheel at turkeyrod, I liked the style and itg was cheap. ($50) Only thing, it was unpainted. I found a thread from 2006 that offers several suggestions, but doesnt really talk about how to insure the paint dries sufficiently and what to do to keep the paint from melting in typical 105 degree Florida heat. So I ask those esteemed painters and restoration experts out there, whats the secret to painting a steering wheel? Not doing anything fancy, basic gloss black for my 51 tudor, but the cars black and interior will be white, can't afford a melting sticky wheel on fresh white vinyl seats. Thanks
  2. squirrel
    Paint gets harder with heat and time. Paint it, let it dry for as long as it takes to not be sticky or soft any more. Usually that's a day to a week, depending on what kind of paint it is.
    Use good automotive paint, not a spray can.
  3. pjungling
    pjungling
    from Sweden
    I painted my steering wheel for my chevy pickup 47, now i live in sweden and do not have the florida sun. but i painted it whit a good plastic/vinyl "primer" don't know the name in english but its a paint you put on before the "real" paint.
    then a put on the paint and color i want. think about that you have to use plastic/vinyl paint if your wheel is made in that.
  4. CutawayAl
    CutawayAl
    from MI
    The right paint will cure and not melt or remain sticky. If you live in hell possibly it might be a problem:D , but if paint can tolerate engine heat it's not going to be overheated on your steering wheel.
    Although it may be tack-free in a short time, some paint takes as long as a month at normal temps to fully cure.
  5. LeadSledMerc
    LeadSledMerc
    Prep the wheel real good, clean it with surface prep, use PPG Adhesion Promoter, then spray it with a decent single stage paint. It'll be bullet proof even in the heat!
  6. cruzr
    cruzr
    Ive done several with spray bombs and no problems
    my coupe wheel was done with a spray bomb and its held up for a lot of years
  7. Roger Walling
    Roger Walling
    I painted my worn 55 F100 wheel with Black Industrial Imron. I had it in a horzontal position and applied the paint very heavy. (Industrial Imron is a very thick paint and does not run easly)
    I allowed it to slightly drip on the under side to improbe the "finger groves"
    It realy "grips" the hands real good now and is super slick.
  8. millersgarage
    millersgarage
    I have the same wheel in my '28 coupe, just painted it with the same paint as the rest of the car.
    No worries
  9. mr.chevrolet
    mr.chevrolet
    i was told to add more hardener to the paint to keep it from wearing through.
  10. 39 Ford
    39 Ford
    Sprayed mine with Krylon 1613 semi-flat black from my small stash of cans, no problem.
  11. Rusty O'Toole
    Rusty O'Toole
    You could paint it your favorite color then take it to an upholstery shop and have the rim covered in leather like the new luxury cars. Not very expensive and adds a nice touch of cl***.
  12. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Just 400 or 600 ,I mean sand and paint ,I always prime them first ,320 then shoot with a good quality auto motive paint .Back in the day I think they were laquer ,Even though enamel was also around,,,,
  13. 52Poncho
    52Poncho
    The vinyl paint used for painting plastic deck chairs is suppose to work good but have never tried it myself.
  14. 55delray
    55delray
    from Florida
    Leadsledmerc, I was just turned on to PPG single stage, so the adhesion promoter is the missing piece of the puzzle for me. I appreciate the other tips ... Will takes some pics during the process and post them.
  15. sierra rod shop
    sierra rod shop
    sprayed mine work great
  16. LeadSledMerc
    LeadSledMerc
    When I originally did the wheel bone in my '37 years back it seemed to chip real easy. The PPG rep recommended the adhesion promoter and thats all I changed this time around and the durability is night and day. I was also told not to prime it at all.
  17. gasolinescream
    gasolinescream
    Being cheap and not having a paint gun I've always hit mine rattle cans. Rubbed down well, prepped, primed/painted and a good few coats of clear normally works best for me. Here's one i did on my old 58 100E Wagon last year, excuse the bad picture but shows up the flake just about. Did the wheel and dash and threw in some gold flake with a homemade gun. Used alot of clear on it and alot of wet sanding but came out well for a home job and is lasting well.
    Many times i've used radiator enamel paint on black or white steering wheels and given it 2-3 good thick coats with no primer or clear. Seemed to be the toughest paint and didn't chip easily and gave a tough finish. Got one to do soon and i'll use black enamel.
  18. hobbs53
    hobbs53
    from leo, In.
    anybody have to fill in the cracks that often develop (have some pretty good gaps in the wheel).......how do you deal with these?
    thanks!
  19. 40FORDPU
    40FORDPU
    A '56 Olds steering wheel I repaired and painted for my '40, using Eastwoods steering wheel repair, and rattle can paint. It had numerous cracks in it.
  20. stuart in mn
    stuart in mn
    I used the Eastwood kit and it worked well. However, their kit includes PC-7 two part epoxy, which you can probably find at a local hardware store for less money.
  21. hobbs53
    hobbs53
    from leo, In.
    Wonderful....thanks guys!!
    hey 40fordpu...........LOVE the motor!!!
  22. neilswheels
    neilswheels
    from England
    I painted a good wheel, no cracks, just prepped with 320, primed and painted, using 2 Pack at the time, tho not available over here anymore. Worked grat, never cracked or wore thru. I've been told that if you go thru the original paint, its good to use a plastic primer, same as would be used on new car plastic bumpers.
  23. tooslow54
    tooslow54
    I used simple epoxy from home depot and rustoleum gloss white rattle can ten years ago..still looks good
  24. Richie Martinez
    Richie Martinez
    from San Diego
    Anyone ever try that Herculiner rattle can stuff? I've used it on a few pieces of trim for my door panels and it seems to hold up really well. Not sure how it would look though...
  25. Pats55
    Pats55
    from NJ
    This is what I used on my steering wheels over 10 years ago. It comes in a clear besides some limited colors. So you wipe your wheel down with the thinner , and paint it with the color you like. And then clear coat it. This is a polyester urethane has high abrasion resistance and will not melt in the Sun.
  26. chubbie
    chubbie
    Good tech is never old tech. I had 3 JUNK steering wheels. I J B weld the huge cracks, And powder coated them gloss black. Yes they are plastic
  27. 210superair
    210superair
    from Michigan
    20210111_095908.jpg My 51 has that same steering wheel... Painted Grey. How about a Pic of your Ford?
