wont run unless you have a test light touching neg. side of coil.
Discussion in 'The Hokey Ass Message Board' started by BISHOP, Oct 30, 2011.
  1. BISHOP
    BISHOP
    I was at a friends shop yesterday, and never seen this before. If you try to crank the engine, it will not run unless you have a test light touching the neg side of the coil.
    If its running with the test light, and you take the test light off, it will die.
    Its a v8 with electronic ign.
    Whats going on here.
  2. Abomb
    Abomb
    You are basically adding a ground with the test light, so is the actual wire on the neg. coil post good ???
  3. BISHOP
    BISHOP
    Here is the weird part. Tried two different new coils, same result.
    Tried to run a straight wire off the neg post to ground, would not run
    Tried a ballast resister, would not run.
    Test light, runs.
    Ohm meter to see what the test light was pulling, 10 ohm, get 10 ohm resister, wont run
    Back to test light, runs.
  4. WDobos
    WDobos
    Ground to engine is no good. Put a good ground to the engine block and I'll bet it runs.
  5. squirrel
    I wonder how the starter works, if there's no ground to the engine?
    There's not enough info about what it is you're working on, to try to figure out what's wrong.
  6. Just wire the test light to it then!!
  7. 9310alloy
    9310alloy
    Like Abomb said...you lost your ground...circuit going thru the filament of the lamp.Wire broken , distributor not making good contact to the block , block lost its grond strap/wire to frame/firewall. Missing that part of the circuit....
  8. 50dodge4x4
    50dodge4x4
    What brand of electronic ignition are you using? I'm betting you need to ground the electronic ignition module/box. If it was a points style ignition, I'd say replace the condenser or ground the dist. Gene
  9. BISHOP
    BISHOP
    I understand what your saying about the ground, but we run a ground straight to the battery and it would not run. Take the ground wire off, hook the light back up, she busts right off.
  10. bobwop
    bobwop
    from Arley, AL
    halloween related?
  11. tooljunkie
    tooljunkie
    from manitoba
    ok,battery to positive side of coil,trigger/ignition module /points on negative side of coil?what flavour of engine/ignition system?
    cannot hazard a guess at anything til we know what we are dealing with.
  12. mace69
    mace69
    from mass
    Do a voltage drop test to the engine. I suspect wdobos is right.
  13. BISHOP
    BISHOP
    Painless brand, works just like the pertronics magnetic pick up.
  14. BISHOP
    BISHOP
    I will go back over there tomorrow, I will have better details and follow up what happens.
  15. TANNERGANG
    TANNERGANG
    from alabama
    Look at it in a positive way...with the test light hooked up......(1) Your riding...(2) you'll always have a light so you can see at night...........
