Orange peel 871 blower
Discussion in 'The Hokey Ass Message Board' started by gassermann, Oct 30, 2011.
  1. gassermann
    gassermann
    Hello: This is G***erman needing your help again. So I built this really neeto old 63 corvette g***er that has allot of history and it is pretty old
    school I have a BBC 427 in it with a dougnash 4+1 runs great but not as
    fast as it should be when I built motor 10+ years ago I thought I put it
    together for 11.5 cr it turns out the heads I put on was 122cc anyway
    my compression ratio is about 8.2 so I threw a Mike Kuhl 871 blower
    and it is magnesium dow 7 coated and cragar intake. Ive never worked
    on a supercharger but it went on great and it sounds good did a burnout
    and it felt good I'm 25% underdrive I don't know what I should be running.
    but i'm trying to from 11.30s to 10.50s I forgot to mention I like to go
    to local cruise in on occasion it race in nostalgic cl***es. Thanks for your
    help
  2. squirrel
    Hi, what is your question?
  3. H.G. Wells
    H.G. Wells
    more info please. And a specific question would be nice.
    Is the blower stripped? you don't really want a stipped blower for streat use.
    Injected or carburated? Did it behave correctly during the p***? How much boost?
  4. gassermann
    gassermann
    Sorry for the lack of info but it got it started. Blower is teflon stripped
    I have a 1000cfm b/g carb on it and I haven't had it down track yet
    did burn out in long driveway. Thanks
  5. squirrel
    You just want us to tell you have quick it's gonna be?
    That's what the dragstrip is for
  6. gassermann
    gassermann
    just wanted recomended underdrive ratio
  7. kkustomz
    kkustomz
    from Texas
    teflons stripps are not for street use on a 8-71. Run it like u have it 25 % under will be fine
  8. Still don't know exactly what you're asking? Are you looking for blower drive ratio, carb setup, timing, ????
    Blowers are fun, but you need to know that your fuel system, timing and boost are all correctly setup. The carb should be setup for a blown application - such that if it has power valves, they are boost referenced . . . also, it is better to be a bit rich than too lean - you don't want to detonate it!
    A teflon stripped blower is a race setup - normally you don't run teflon strips on the street . . . they're just going to wear out.
    What cam are you running? What springs?
    We need a lot more - starting with what help/questions you're asking us for?
    B&S
  9. gassermann
    gassermann
    Cam is 708/680 262/252 at 50 112 center carb has not been setup for blower yet springs are for 800 lift heads are dart 308 runners pistons are Kieth black rods are childs and albert crank 1969 gm steel crank headers are pro stock ****** 2.250 tubes
    with Borla built in header muffler vertex magneto total advance is 38deg
  10. squirrel
    Have you driven it enough to see how much boost it makes?
    If you just have one 1000 cfm carb on it, you may need more carb.
    you might also need to take some gear out of the rearend.
  11. gassermann
    gassermann
    Rear gear is 433 tire diameter is 32.5
  12. gassermann
    gassermann
    To finish question just trying to see what horsepower gain might be. As far as stripped blower on street its about 6 miles to cruise and take 3 times a year for
    racing I only go about 6 times a year buget doesn't allow for anymore thanks for all the help
  13. squirrel
    25 under with a 8-71 on a 427 should make only about 6 psi boost, which should increase power by roughly 30%.
    If you set everything up right, it should do what you want. There's only one way to find out
  14. H.G. Wells
    H.G. Wells
    At 12% under mine probably takes more HP to turn than it actually produces. You have low enough compression to up the boost some. Get it out and play with it, but... if you have not already done so make sure someone set up the carb for a blower. You do not want to run lean on the big end. (you already knew that didn't you?) If you are really looking for someone to give you a HP# I suggest you talk to one of the blower shops. You will have to know the boost number to even guess.
  15. gassermann
    gassermann
    Just ran a psi gauge on it when in burn out went about 6500 rpm made about 6psi
    will call shop tomorrow ask about carb just had that one on shelf and had to start it
  16. squirrel
    I guess that chart I looked up on google was pretty accurate.
    I'm getting about that much boost with a 3% over 6-71 on a 454. I've run my car with the blown engine and an almost identical unblown, there was 1 second difference in ET
  17. falcongeorge
    falcongeorge
    from BC
    Just what I was gonna say...
  18. kkustomz
    kkustomz
    from Texas
    38 degrees total timing u will melt that bbc. try 28-32
  19. gassermann
    gassermann
    thanks for your input if you are wondering why I bought a stripped blower it had just been rebuilt at dyers and the peice was right if I wear it out I probably can get new
    rotors without? and it looks cool on the old school motor
  20. gassermann
    gassermann
    I'll set timing down tomorrow thanks
  21. B&M street blowers have Teflon in the rotors.
  22. kkustomz
    kkustomz
    from Texas
    1000 cfm is plenty for 427" that is street and strip, it will cruise around nice and if properly tuned not loose much more et than two 750's on the track.
  23. kkustomz
    kkustomz
    from Texas
    b&m blowers do not move the volume of air a 6-71 and up do. The bigger volume of air and psi the more heat you generate, on the street no good. Race and alky no preoblem.
  24. squirrel
    Maybe, maybe not. If the heads have a modern chamber design, then 30 degrees would be about right. The old chambers can tolerate a lot of advance.
  25. Okay - here is a stab. If you really want to make a bit more HP, then you'll want at least dual 750 HP style carbs - setup with fuel curves for your engine, cam, etc.. Blowers need lots of CFM to make HP - right now you're choking it off. I'd talk to Patrick at Pro-Systems . . . he'll make you a custom pair of them for just about what you'd pay for stock units at Jegs.
    Hopefully those pistons are forged ones . . . and not any of the hyper or cast stuff - of you're asking for trouble. Keep the timing down initially and if you can afford it, think about some timing control to pull out some timing as the boost comes up. I'd probably start with about 30 - 32 total advance . . . to reduce the chances of detonation.
    I think you should be able to reach your performance goals - as long as you can hook it up.
    One last thing: After you run it a few times, check your bearings and see how the bottom end is looking. On a blown motor, I'd prefer to see some softer bearings and more oil clearance than you were probably running before. If it was mine, I'd run .00325 to .0035 or so on the front four and closer to .00375 to .004 on the rear. You want a lot of oil flow to cool the bearings -- and heavy oil. You can always put a new set of .001 LARGER clearance V series bearings in it - just depends how tight it is now.
  26. dodored
    dodored
    from Concord NC
    Plus teflon hates ethanol. Won't last too long on pump gas and then the boost goes away. That is why you see a lot of B&M blowers that need to be rebuilt.
  27. squirrel
    Running 6 lbs boost ain't gonna hurt much, guys....sheesh
  28. squirrel
    here's the bearings out of my blown 454, after 40,000 miles on the street and a dozen or so p***es down various drag strips. around 6 psi boost, stock clevite 77 bearings, walmart oil, but it never saw much over 6000 rpm. Running around 35 degrees advance, plus vac*** advance, and no boost reference on the Holley 4777 carbs.
    It's not rocket science.
  29. Just depends how hard you flog it, what parts you have in it and how much boost! :rolleyes: Lots of guys start out conservative, but they get the 'itch' to maybe just swap the pulleys and see what it does.
    Best of luck, let us know how it goes!
  30. Deuces
    Deuces
    I see a little pitting or flaking on the thrust cap bearing..... Maybe it's just a little dirt.. ;)
