Hot Rods Brakes for Willys beam axle?
Discussion in 'The Hokey Ass Message Board' started by txcr13, Oct 31, 2011.
  1. txcr13
    txcr13
    Just picked up a '40/'41 Willys car front beam axle, which I intend to put under my '46 Stude coupe. Axle needs full restoration, and I want to upgrade the brakes to discs.
    Any suggestions about what company makes brake kits for this axle? I heard of one application that used Hurst???
    Or, any ideas about what GM or Ford spindles could be adapted to the Willys axle to accept to upgraded brakes and have a 5 x 5-3/4" bolt circle?
    Any help appreciated.
    Thanks!
  2. bykerlad
    bykerlad
    from australia
    i put 39 stubs on mine,then a disk brake hub ,ended up with 5 x 4 1/2 bp
  3. BobbyD
    BobbyD
    from Belmont NC
  4. 39WILLZ
    39WILLZ
    Hi i used 37/41 Ford spindles on my Willys axle fairly simple job reamerd axle out to fit Ford kingpin then machined up spacer between axle boss and spindle bearing worked out perfect and lots of brake choices for Ford spindles hope this helps cheers Wayne
  5. gasserjohn
    gasserjohn
    send your spindales to Aerospace compotents they will custom make them for you........thick vented rotors donot look right.........
  6. drumyn29
    drumyn29
    I'm using 65 volvo disc brakes like the g***ers used. There is a post about it here somewhere.
  7. txcr13
    txcr13
    Thanks to all for the replies.
    I am limited at this time to using a bolt-on or very simple modification of parts solution. If there are any more ideas out there, keep 'em coming.
  8. cahaldo
    cahaldo
    from Wisconsin
    Just wandered into this thread. Sorry I'm so late on the uptake.
    I used the original Willys spindles coupled with a- believe it or not- 5-4 1/2 trailer hub, heavier lugs, matched the bearings, added an SKF seal 16667 .5 -wider to cover the lip of the spindle, added a Wilwood hat with an 11.25" disk, and wrapped it all up with a pair of ET spokes. I did this all in 2001 because no one I knew had any knowledge of this swap. This is a project I've had since I was 16- long before buying **** off the shelf was available and we had the luxury of H.A.M.B!
  9. cahaldo
    cahaldo
    from Wisconsin
    I also made my own caliper bracket and made spacers to line it all up with. The entire axle ***embly including tie rod, etc. are chromed just to make it look nice. And, oh yes, I'm now 70 and still have it.
