283 327 Chevy Balancers
Discussion in 'The Hokey Ass Message Board' started by worstnightmare, May 27, 2005.
  1. worstnightmare
    worstnightmare
    Did any of the 327 Chevy engines use the small balancers like the 283's??
  2. do you mean the small one like this? sorry, i'd like to help you , but after reading your profile , and seeing you car is better , and where you are from ...i'll wait until you are serious,
  3. KoppaK
    KoppaK
    The HAMB is dedicated to spreading the gospel of traditional hot rods and kustoms to hoodlums world wide. That’s right – TRADITIONAL. And we aren’t talking Beach Boys and poodle skirts here fellas. If you are into a-side 50’s pop, lawn chairs, ruler contests, and all things that make hot rodding warm and cozy then you might want to find another message board. If you aren’t sure what we mean by “traditional”, then you might think twice as well. If you’ve come here to set a rep, talk some ****, and make some fun then you had better turn around right now. We aren't patient.
    Even if you have come here for all the right reasons, don’t expect posting to be easy. We don’t cater to new fellas unless they show a dedication to spreading this tradition of ours first. We welcome young, old, foreign and all – but our original members and our staff expect a certain level of respect and an effort to keep things true and on topic.
    Maybe you are an old fart with a past. Maybe you are one of the guys that started this tradition we cherrish. We built this place for you and your posts mean the world to us. Hop on and introduce yourself. This is your board.
    Still reading? Then you must be cut out for this, right? We recommend you read some more. Check out all the forums, develop an understanding for how things work around here, learn the “do’s” and “do not’s”… The key to a happy HAMB newbie is to understand the joint BEFORE you begin posting. You want to be happy don’t ya newbie?
    We have very few written rules here on the HAMB and that’s the way we like it, but we won’t hesitate to dump disruptive posters, ego freaks, or **** talkers. We are all here to learn and teach - please keep your other perogatives on the sidelines.
    Rules:
    1. No profanity in subject lines
    2. No political/religious/racial posts
    3. No ****.
    4. All personal information listed on this board is private and protected. The HAMB does not sell this information and you are not privy to use it for your own reasons. Test us on this one and we will bite.
    5. New Users must fill out thier profiles. Every bit that you can. Simply click on "User Cp" above and get to work.
    6. New users must introduce themselves in the intro forum.
    Guidelines:
    1. If in doubt, don’t post it
    2. Stay on-topic and relevant with your posts… OT posts aren’t generally appreciated by our membership.
    3. Gotta easy question? Try using the search function first.
    4. Your life here would probably be easier if you complete your profile and introduce yourself before jumping into the deep end...
    __________________
    Amen
  4. worstnightmare
    worstnightmare
    OK GOT IT..... Now Can anyone answer this question or what??!
  5. NoSurf
    NoSurf
    What diameter is that balancer?
    I thought that the 327 balancer was a little bigger than the 283. I have a 327 size on my 283 in my '64.
    You might have to wait a bit for a guru to answer your question.
  6. Mutt
    Mutt
    Like your bio, the answer is personal. :eek: :rolleyes:
    Mutt
  7. OldSchoolObee
    OldSchoolObee
    Yes, I've run into several early'64-65 327s with the small balancer....only the 400 sbc is externally balanced(damper& flexplate/flywheel)..i've used both the 283 and the 8" balancer on the 327s...NEVER use the 400 Balancer or flexplate or flywheel on anything but the 400...
  8. Ed ke6bnl
    Ed ke6bnl
    Not sure of the dia but it seems like most of the 327 including my 63 327 has a much thinner dampner then the 350's
    Ed ke6bnl
  9. Tony
    Tony
    All of the 283's i've had have had a 'hub' rather than a balancer.
    Very small in comparison to the 327, and to be honest dosn't even look like a balancer at all..
    They fit the same, but are only about 1/2 to 5/8 thick at the pulley flange.
    I have used regular balancer's on them though without a problem..
  10. magnet
    magnet
    i have mistaken the "balancer" as athat kooky little pully adapter... I have seen small ones on both stock motors.
  11. MIKE-3137
    MIKE-3137
    On a similar note...My 62 327 does not have a bolt hole tapped in the crank to retain the balancer, has anyone had one come loose? Just kinda worries me about it jumping off and chewing up my radiator or worse.
  12. tomslik
    tomslik
    yeah, they come loose.
    drill and tap it. (7/16 fine)
    i don't have to tell you to keep it straight, do i?
  13. tomslik
    tomslik
    exactly what do you want to do?
    sbc balancers will all fit but there's different sizes and timing marks not to mention 400 sbc that are externally balance and will shake the **** out of the enging until the crank breaks...
  14. worstnightmare
    worstnightmare
    trying to ascertain whether this is a 327 or 283 here..the date code is 1965..but it most definetly has a balancer like the picture above!! there is thread for a bolt but there wasnt one on it?!! yikes!! motor is fresh maybe 600 miles total.its in a 1958 Chevy.it has power Pak heads with a 2bbl?!!cant read the casting numbers while in the car!! i think its a 327 myself..my friend thinks otherwise...goin nuts!!!!!!!:confused: :confused: :confused:
  15. worstnightmare
    worstnightmare
    Also has a spin on filter not a cartridge,nad the starter has a three bolt nose cone.not like you typical GM late model gig..
  16. i see you have edited your profile , sorry to be a ***** , but your original info kinda rubbed me the wrong way...welcome
    i believe you are trying to figure out what size engine you have by the harmonic balancer on it...that may be hard to do , with a car that is 47 years old and who knows what modifications/changes has been done to it. you say the date code is 1965 , so the engine has been changed and the small balancer may have been put on ...the crankshaft having the threads for the retainer would sugest a later engine, but it may have been drilled and tapped... spin on oil fllter would also indicate a later engine , but adapters to put spin on oil filters on older blocks are available...power pack heads could have been switched...and the 3 bolt nose cone on the starter bolting to the original transmiission itself would not tell you what motor it is
    the only way you are going to know what engine you have for sure is to get the casting number off the back of the block...can you read it with the help of a mirror and flashlight?
  17. worstnightmare
    worstnightmare
    Problem is the dam kickdown bracket is bolted down so tight I cant get it off to read the numbers or lay some clay on it to get an imprint...I knew that was the only for sure way,but figured some chevy guru might know something I didnt...lol!! ohhhhhhhhhh sheeit!! I'll cut that damn bracket off!! who needs a kickdown anyways?!! lol...
  18. willowbilly3
    willowbilly3
    from Sturgis
    I had one come loose on a 327 once but I got it back on before it messed up the snout. I also remember some dirt track cars with it welded on because it wouldn't stay anymore.
  19. tomslik
    tomslik
    option 2; there's a pad on the right front of the block.get the #'s off it and post 'em.
    one of us surely has a motors manual that'll have it in there.
    the last 2 or 3 letters is enough..
