Stuck rings
Discussion in 'The Hokey Ass Message Board' started by Tha Driver, May 28, 2005.
  1. Tha Driver
    Tha Driver
    from S.E. USA
    I have a problem: I'm prepping the pistons to install in my tow vehicle engine - they have been sitting around for, well, decades. :( I got the rings out of all but one piston, but this one has the rings stuck against the piston & I can't get them out. The others were expanded & gave me something to work with, but they were still a pain to get out. Anyone know any tricks?
    For that matter, ditto on the wristpins....:rolleyes:
    Thanks,
    ~ Paul
    aka "Tha Driver"
    Giggle Cream - it makes dessert *funny*!
  2. Bugman
    Bugman
    Heat'em up with a propane torch. The aluminum will expand more than the steel/iron rings and wrist pin. Just don't heat them so much that they melt.
  3. Tha Driver
    Tha Driver
    from S.E. USA
    Thanks Bugman for the suggestion; I'll have to wait 'till I can afford some oxygen for my torch. I don't have a propane unit.
    They are not gummed up they are more like dried out & corroded. I've been soaking them with PB Blaster but only for a couple days so far.
  4. noboD
    noboD
    try kerosene or diesel fuel.
  5. I have had the same problem
    I soaked mine in ATF / auto trans fluid
    for a few days and it helps to remove the gum
