questions for the vinegar guys
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, Nov 2, 2011.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    My dad is thinking about making up a tank to do fenders with vinegar ,How long do the chemicals keep.Just curious before he buys 100 dollars or so worth of vinegar,,,,,
  2. Rickybop
    Rickybop
    Hi John. Some here say mol***es works well. I think I heard a 4:1 ratio of water and mol***es. Maybe a little less expensive.
    I honestly don't know the answer, but I know one thing for sure...
    You're a new uncle.
  3. mr.chevrolet
    mr.chevrolet
    you'll need a pretty big tank and it's gonna smell. keep it away from the house. keep it covered and it should be good for quite some time.
  4. Rickybop
    Rickybop
    Maybe make pickles or sourkaut at the same time. (high in iron)
  5. carcrazyjohn
    carcrazyjohn
    from trevose pa
    No pickles or sauerkraut ,I just pmd you, I figure Id ask that question for him,Before he goes to Sams club and spends all that money ,He has to do at least 8 fenders....He's got many cars .............
  6. plym_46
    plym_46
    from central NY
    My buddy who is a body man who also does body work and restoration stuff in his garage, bought a 35 gallon plastic barrel and cut it about 2/2 , 1/3 length wise and hinged it, put in a wooden base. It holds about 18/20 gallons, and he can get some pretty big stuff in there, rotated as necessary to get it all under.
    In his shop with all the solvent and filler smell you hardly notice the pickle barrel. His stuff is over 2 year old and he is still using it, adding more as needed for evaporation.
    Go to a whole sale grocery place (lots of produce places have it) and you can get it cheaper. Most of them are all 5% acedic acid, you can some times find 10% for commercial usage but I don't know if the difference in price or efficacy would be enough to justify the extra cost.
    He also set up a vertical electrolysis tank for long thin stuff.
  7. Zeke
    Zeke
    The issue with mol***es and it does work well but it doesn't keep long term because it's sugar based. it will mold up on you after a bit. Nice thing is it won't kill your lawn like vinegar will. It actually helped my gr*** when I dumped about 25 gallons on it.
    Before
    After about month in the bath in cold weather
    Your results may vary.
    I did on gallon of farm grade mol***es to 20 some gallons of water. cost $12
  8. I used muriatic acid from a pool supply place, and cut it even more to make it less aggressive. It's cheaper than a whole bunch of vinegar, but you need to be more careful handling it. Mine is in a pail with a lid for smaller parts. I use weed-whacker line to suspend the parts.
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    I did a thread on a vinegar bath and I can tell you the vinegar lasts a long time...several months.
    kidcampbell71 likes this.
  10. ONAROLL
    ONAROLL
    from Oklahoma
    I just finished a ton of parts using vinegar, I was amazed, cant tell ya how long it lasts but I wont be blasting anything if I can get it a vinegar bath, Im going with a 55 gallon plastic drum with a lid, it does stink but no big deal and a lid will cure that.
  11. Rhinodaddy
    Rhinodaddy
    from mesa az
    Zeke - That's outstanding. It looks hot tanked. I tried the wshing soda and battery charger business myself once, and I wasn't too happy with the results for the effort. Maybe I'm too impatient. I definitely like your results with mol***es.
    As far as a container, I've seen guys who like the washing soda process (more than I do) make a frame with dimensional lumber and then line it with several layers of visqueen. Should work regardless of what other method you prefer, mol***es or vinegar. John, I'd be concerned about hydrogen brittling if using vinegar, but it is just a fender.
  12. 1960impala283
    1960impala283
    That was just from the bath? or did you do some scrubbing and wire brushing or something? I'm off to get supplies to start doing this....:eek:
  13. Rhinodaddy
    Rhinodaddy
    from mesa az
    I know I have some parts that are about to get the mol***es bath. I'm hoping I can get the cheap stuff from a local tack and feed store.
  14. stimpy
    stimpy
    instead of buying vinager , call a chemical supply place and buy glacial acetic acid , its the stuff thy make vinager from , it has more of a kick , but the same amount of smell , and to nuetralize it you get a bag of baking soda and make a big fizzy , I used to buy it in 30 gallon drums and dilute it 50/50 it will not remove paint but will clean off rust and crud .
  15. I say, go for it. Vinegar is delicious on about everything.
  16. Yeah, as much as I like mol***es I'm not a fan of mol***es on chips but I hear its better on rust.
    Doc.
  17. I used Mol***es on all my panels, thought it worked very very well, takes a few weeks though. I made a tub from left over wood and lined it with a builders tarp, no leaks.
    You will need a high pressure washer to clean the parts when they come out of the mol***es. Every panel on the coupe in my avatar was soaked in mol***es, hit them with the DA sander and a light spray with oil and they are good to work with. Dont leave the metal raw for more than 10 min, it will start to surface rust pretty quick.
    You can also use wood bleach from the hardware store, have not used it but i hear it works well also.
  18. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I did mol***es on my flathead block and heads. Looks nice and clean! 7:1 ratio.
    Gotta watch for some pitting, and the smell ****s.
    A flathead fits just fine in a 35 gallon rubbermaid trash can.
  19. willymakeit
    willymakeit
    Check and see if there is a vinegar plant around your area. Sometimes you can buy it with a higher acid content. Most store bought is 5% acid. We have one about 10 miles from where I live. hope this helps.
  20. tlmartin84
    tlmartin84
    from WV
    To the guys using nuratic acid, how are you diluting it?
  21. Rhinodaddy
    Rhinodaddy
    from mesa az
    tlmartin84 - I'm a chemist by edjumacation. Always add acid to water, never, ever, the other way around, and very slowly at that. Wear goggles, PPE, and have adequate ventilation.
    Muriatic is a common name for 31% diluted hydrochloric acid. This is very potent stuff and needs to be treated with respect! I can tell you a 10:1 dilution of water and muriatic will make your concrete fizz like an alka-seltzer. At 10:1, you have a 3% concentration and it will still thump your ***!
    I promise the chemistry lesson is almost over: Muriatic (or hydrochloric) is a strong acid. Acetic acid (vinegar) is a weak acid. Diluting a strong acid in water does not make it weak. 5% acetic will not destroy your body. 3% hydrochloric will.
  22. sawzall
    sawzall
  23. tlmartin84
    tlmartin84
    from WV
    HAHA I'm going to try the electro thing.....wonder if that would work with a 50 gallon drum so that you could get fenders in it?
  24. tlmartin84
    tlmartin84
    from WV
    How long does the the soda bath stay good for?
  25. stimpy
    stimpy
    basically till it don't work no more , when it takes longer to remove the **** you know its going bad , mostly the anodes need cleaning or replacing before the mix . you have to change it out or add more to it oc***ionally , the soda method works real good ( I was doubter till I tried it on some real rusty stuff )
    for a fender try a box with a pool liner or heavy water proof tarp in it and make a anode from mesh to get a large surface area , if you use a drum it has to be plastic to prevent shorting out .
    , I would never use Hydrocloric or muriatic acid as it makes the metal brittle also ( hydrogen embrittlement ) .
  26. Saxman
    Saxman
    Take the fast track! Phosphoric acid is what I use. Dissolves rust without hurting the base metal. In my experience, Muriatic acid will cause everything to rust again after you remove it from the solution. Even the vapors will cause anything that happens to be nearby to rust.
    Phosphoric acid will remove and convert the rust to something inert. I wouldn't screw around with mol***es. It sounds like it has a nasty smell and creates a hell of a mess. Although, I admit I've never actually tried it.
    You can pick up phosphoric acid at the hardware store. It often sold as concrete or rusty metal cleaner. Check the label to make sure the active ingredient is phosphoric acid. It's usually about $20/gallon but it can be cut pretty good with water. It is pretty fast acting too. Even cut about 5:1 with water it seems to clean even the rustiest stuff in about a day. When the parts come out you don't have to worry about the parts re-rusting again for a long time either (unless you leave them out in the rain or something.)
  27. Rhinodaddy
    Rhinodaddy
    from mesa az
    To the guys who have used washing soda and the electrolitic process - what's the largest piece you've done, and how long? how many amps? any useful info would be appreciated. I did this with some Model T hardware a while back (22 ga straps about 2 feet long and 4" wide). My results were OK but not great. I filled a rubbermaid garbage drum with solution, tied off on the pieces, and stuck a three foot length of #4 rebar in the solution. I baked it for about 3 days with a 10A charger. Any comments are appreciated.
  28. Piston Farmer
    Piston Farmer
    ^ It shouldnt take that long, when done right it is pretty fast, the thing you have to remember is it works by line of sight.
  29. Saxman
    Saxman
    This process has worked for me pretty well in the past. I think the largest piece I did was a 235 valve cover. Just make sure you have the right concentration in your solution and remember it it only works "line of site" so you may have to move your part around to get all the areas.
    I used a large plastic tub with about a dozen pieces of rebar wired in series around the edges. For a power source I just used a small battery charger. I was happy with the results.
  30. Mr. Clean
    Mr. Clean
    The largest piece I have done is an F-1 hood. As stated above I made up a grid work of rebar and pieces of metal I had laying around. I placed the hood in a plywood box that I made up and added sodium carbonate (washing soda if available; or PH increaser for swimming pools). I used a 40 amp sear battery charger. Unfortunately, I didn't take a picture of the hood after I took it out of the bath. I did have before and after pictures of the rear fender. I used the same process on the rear fender.
