home made motor mounts
Discussion in 'The Hokey Ass Message Board' started by silversink, Nov 4, 2011.
  1. silversink
    silversink
    I've been going back and forth from frount mounts to side mounts on a sbc. Lets see what you all did to mount your small block chevs and ford engines
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    The frt. mounts were used when there was a mid-mount[at the bellhousing] side mounts came about as a way of doing away w/ these. If you use a frt mount w/a tailstock mount , it puts to much strain on the bellhousing[ the weak link]... this help?
  3. HOT40ROD
    HOT40ROD
    from Easton, Pa
    Yep. Seen some turbo 350 bells break because of this.
  4. Dane
    Dane
    from Soquel, CA
    Modified FatMan mounts.
  5. Fenders
    Fenders
    Back about 1985 I put a SBC which had an auto trans in a '51 Mercury, the engine had the threaded holes in front so I welded up a front mount (I guess I could have bought one but hey...) and attached it to the original Merc front motor mount places ... rubber donuts etc.
    The back of the trans had a single down bolt on the trans mount, so I drilled a hole in the Merc cross member and there it was.
    I never though about a mid mount so never worried about that. I drove the car cross country (M*** to Arizona and back) pulling a travel trailer.
    Maybe it's true, ignorance is bliss.....?
  6. el Scotto
    el Scotto
    from Tracy, CA
    Bellhousings breaking are an old wives tale.
  7. RB35
    RB35
    My flathead has waterpump mounts and a t-5 ****** mount. Probably a bit heavier than your sbc.
  8. mctommy
    mctommy
    from sweden
    33 ford, front mounts and rear mounts, it's a 57 283 engine so there is no mid engine mounting bosses.
    Hopefully won't break the bellhouse because there is no transmission mount. The transmission will be hangin loose :)
  9. zman
    zman
    from Garner, NC
  10. cain
    cain
    from riverside
    We sell these , tigg welded
  11. Danburnsart
    Danburnsart
    from 59044
  12. Jim Stabe
    Jim Stabe
    LT1 in my MGB project
