  1. Harms Way
    Harms Way
  2. Harms Way
    Harms Way
  3. Harms Way
    Harms Way
  4. Harms Way
    Harms Way
  5. Harms Way
    Harms Way
  6. Harms Way
    Harms Way
  7. Harms Way
    Harms Way
  8. Harms Way
    Harms Way
  9. Harms Way
    Harms Way
  10. Harms Way
    Harms Way
  11. Harms Way
    Harms Way
  12. Harms Way
    Harms Way
  13. Harms Way
    Harms Way
  14. Harms Way
    Harms Way
  15. Harms Way
    Harms Way
  16. Harms Way
    Harms Way
  17. Red Foreman
    Red Foreman
    Holden Dealer Melbourne Australia mid 50s
  18. Harms Way
    Harms Way
  19. Harms Way
    Harms Way
  20. Harms Way
    Harms Way
  21. Harms Way
    Harms Way
  22. moefuzz
    moefuzz
    "You did good son, your ma would be proud"
  23. roadkillontheweb
    roadkillontheweb
    That would be Danny in the Firemite with the hottie and Gaston his dad in the full size Desoto. Both are still alive and kicking and Danny can not remember who the girl was. just a car show model.
  24. 327-365hp
    327-365hp
    from Mass
    This was often done as a promo for the bridge building company.
  25. fnqvmuch
    fnqvmuch
    Red was pattersons holden between the 'Bowl and the station?
  26. norby48
    norby48
    from NW Indiana
    at least he won't get parking lot dings in his doors....
  27. yellerspirit
    yellerspirit
    from N.H.
    You searched for: Burlington, airport. Here are the results:
    • <!-- ImageSets.h.php GetImages SQL: SELECT ls, sequence, county, town, ***le, PHOTOGRAPHER, images.FILENAME, MEDIA, PHOTOYEAR, PHOTOSOURCE, description, keywords, format_extent, DATUM, longitude, la***ude, utm_northing, utm_easting, ELEVATION, format_creation, contributor_collector, contributor_scientific_advisor, contributor_reviewer, coverage_periodname, coverage_placename, times_viewed, PUBLIC, (longitude<>"" or utm_northing<>"") has_location FROM images left join viewcounts on (images.FILENAME=viewcounts.FILENAME) WHERE MATCH (images.FILENAME, OriginalFileName, ***le, keywords, description, town, county, PHOTOSOURCE, PHOTODATE, PHOTOYEAR, PHOTOGRAPHER, MEDIA, identifier_citation, ***le_alternative, publisher) AGAINST ('+Burlington +airport' IN BOOLEAN MODE) AND (STATUS = 'X') ORDER BY ***le LIMIT 0, 1 --><LI cl***=location>[​IMG] <!-- ImageSets.h.php GetImages SQL: SELECT ls, sequence, county, town, ***le, PHOTOGRAPHER, images.FILENAME, MEDIA, PHOTOYEAR, PHOTOSOURCE, description, keywords, format_extent, DATUM, longitude, la***ude, utm_northing, utm_easting, ELEVATION, format_creation, contributor_collector, contributor_scientific_advisor, contributor_reviewer, coverage_periodname, coverage_placename, times_viewed, PUBLIC, (longitude<>"" or utm_northing<>"") has_location FROM images left join viewcounts on (images.FILENAME=viewcounts.FILENAME) WHERE MATCH (images.FILENAME, OriginalFileName, ***le, keywords, description, town, county, PHOTOSOURCE, PHOTODATE, PHOTOYEAR, PHOTOGRAPHER, MEDIA, identifier_citation, ***le_alternative, publisher) AGAINST ('+Burlington +airport' IN BOOLEAN MODE) AND (STATUS = 'X') ORDER BY ***le LIMIT 63, 1 -->
    • [​IMG]<LI style="WIDTH: 230px; OVERFLOW: hidden" cl***=current nowrap?; height:12pt; display:inline-Block; border: 0px solid #ff0000;?>Now Showing Image 65 of 66 <!-- ImageSets.h.php GetImages SQL: SELECT ls, sequence, county, town, ***le, PHOTOGRAPHER, images.FILENAME, MEDIA, PHOTOYEAR, PHOTOSOURCE, description, keywords, format_extent, DATUM, longitude, la***ude, utm_northing, utm_easting, ELEVATION, format_creation, contributor_collector, contributor_scientific_advisor, contributor_reviewer, coverage_periodname, coverage_placename, times_viewed, PUBLIC, (longitude<>"" or utm_northing<>"") has_location FROM images left join viewcounts on (images.FILENAME=viewcounts.FILENAME) WHERE MATCH (images.FILENAME, OriginalFileName, ***le, keywords, description, town, county, PHOTOSOURCE, PHOTODATE, PHOTOYEAR, PHOTOGRAPHER, MEDIA, identifier_citation, ***le_alternative, publisher) AGAINST ('+Burlington +airport' IN BOOLEAN MODE) AND (STATUS = 'X') ORDER BY ***le LIMIT 65, 1 --><LI cl***="location next">[​IMG] <!-- ImageSets.h.php GetImages SQL: SELECT ls, sequence, county, town, ***le, PHOTOGRAPHER, images.FILENAME, MEDIA, PHOTOYEAR, PHOTOSOURCE, description, keywords, format_extent, DATUM, longitude, la***ude, utm_northing, utm_easting, ELEVATION, format_creation, contributor_collector, contributor_scientific_advisor, contributor_reviewer, coverage_periodname, coverage_placename, times_viewed, PUBLIC, (longitude<>"" or utm_northing<>"") has_location FROM images left join viewcounts on (images.FILENAME=viewcounts.FILENAME) WHERE MATCH (images.FILENAME, OriginalFileName, ***le, keywords, description, town, county, PHOTOSOURCE, PHOTODATE, PHOTOYEAR, PHOTOGRAPHER, MEDIA, identifier_citation, ***le_alternative, publisher) AGAINST ('+Burlington +airport' IN BOOLEAN MODE) AND (STATUS = 'X') ORDER BY ***le LIMIT 65, 1 -->
    • [​IMG]
    LS25064_000
    [​IMG] <FORM style="DISPLAY: inline; CLEAR: none" ***le="Submit a Reshot Image" method=post name=sub_reshot action=../submitting/submit_options.php><INPUT name=image_add align=baseline src="http://www.uvm.edu/landscape/images/image_add.png" type=image> <INPUT name=ls value=25064 type=hidden> <INPUT name=AddRel value=1 type=hidden> <INPUT name=sequence value=000 type=hidden> <INPUT name=FILENAME value=LS25064_000.jpg type=hidden> </FORM>[​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    ***le:
    Six Planes
    <TABLE><TBODY><TR><TD><DL cl***=image-details><DT cl***=town>Town: <DD cl***=town>South Burlington </DD></DL></TD><TD><DL cl***=image-details><DT cl***=county>County: <DD cl***=county>Chittenden </DD></DL></TD><TD><DL cl***=image-details><DT cl***=county>State: <DD cl***=county>Vermont </DD></DL></TD></TR></TBODY></TABLE><DL cl***=image-details><DT cl***=date>Date: <DD cl***=date>1936 <DT cl***=description>Description: <DD cl***=description>This is a black and white photo of about six planes that are parked on a runway at the Burlington Airport. The airplanes look like they could have been small war planes. All image rights reserved to Henry Sheldon Museum, www.henrysheldonmuseum.org. Walt Houghton, Former Mgr. BTV Airport writes on 2010-11-16: The aircraft are Boeing P-26s from the 20th Pursuit Group, Barksdale Field, LA. They were here in Burlington for cold weather manuvers in January of 1936. They never came back, it was too cold! </DD></DL>
  28. 2loud2old
    2loud2old
  29. fbi9c1
    fbi9c1
    "One of my all time 'Super Heros' has got to be Gene Winfield...."
    Thanks for the nice Winfield piece, Moe. We were driving on Sierra Highway near Mojave a couple of years ago and noticed his place and a lot of cars in progress. My wife urged me to take some photos so I stopped and was doing so. One of the guys came out and we talked. He asked if I would like to meet Gene Winfield and we went inside and he introduced me. Very cool.
    We drove by the shop a couple of weeks ago and it looked like they were busy working on cars. It is great that they are still active.
  30. pipopak
    pipopak
    from florida
    The perfect commuter car!:D
