Labelling Switches
Discussion in 'The Hokey Ass Message Board' started by RocketSled, Nov 9, 2011.
  1. RocketSled
    RocketSled
    I remember Dad using a Dymo Labeller to mark things out and, man, it just seemed hokey.
    Those new labellers are cheap, and cover the print in plastic, which would make the label last longer, but it's lacking in cool
    Then there's the plastic engraving where they cut through to the white underneath...not bad, but...it's missing some I-Don't-Know-What.
    I have a plate in the 89 Vette and want to label the switches N2O ARM and PURGE....functional (and misleading, they're not hooked up...yet) but I'd like a little snazzy.
    So, what have you seen that's H.A.M.B. worthy for this plate?
    IMG_0832 by Matey-O, on Flickr
    Edited to add:
    I got a little smirk when thinking the label should read:
    Code:
    ARM      PURGE
       SQUEEZE
  2. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    pinstripe that thing up..
  3. Stamp it. Letter stamps are not expensive.
  4. Kripfink
    Kripfink
    Hamb worthy? 89 'vette?
  5. RocketSled
    RocketSled
    Ain't the only horse in the stable. ;)
    HAMB worthy in the way Kerb feelers are not.
  6. cederholm
    cederholm
    This or make some plates and have them silk screened like the Alliance plates.
    ~ Carl
  7. RocketSled
    RocketSled
    I'm liking that idea. Keeping them in line vertically shouldn't be a problem, horizontally may take a little practice...
    But I could use a set of stamps in other parts of the garage.
  8. davidbistolas
    davidbistolas
    I deem this to be relevant. :)
    Letter stamps can look as bad- or worse - as anything else, unless you get them all even and at the same depth. I was thinking it might work if you got a few sets and built a jig to hold the WORD together.
    There's another option, but it's quite involved.
    Use clear plexi-glass, a overhead transparency and a photocopier.
    (1) Print out your labels on regular paper. Take your time to lay out the lables and other graphics you may want properly. The beauty of doing it on paper first is that you can mock it up and test fit everything.
    (2) Use the photocopier to reverse the image (so it's a black background with white letters)
    (3) Touch up the reversed image, if necessary
    (4) Copy the page on to the transparency.
    The end result will be that the letters will remain clear, while the background will be blacked out.
    (5) The transparency goes under the clear plexi, with another clear plexi layer under it. Sandwich them all together.
    (6 ) Paint the BACKSIDE something that matches the rest of your gauges. like blue or green or whatever fits your style.
    (7 ) Add a bulb or led and you've got an awesome, backlit panel.
  9. RocketSled
    RocketSled
    Dave, I like what you're thinking, and will have power to the plate (the switches are lit)...using an art package and laser printer really avoids the registration issues with using letterstamps.
    I'm also toying with brass etching, but that may be a little period incorrect for the car (a-la the HAMB plates mentioned by cederholm.) You can silkscreen plates, or float paint over an etched design.
    Using something like: http://blog.makezine.com/archive/2006/07/making-antique-brass-name.html
    Opens up a whole world of possibililties.
  10. RocketSled
    RocketSled
    Something like:
  11. R Frederick
    R Frederick
    from illinois
    Like pinstriping, It would be cool to get good at engraving fancy lettering.
  12. gnichols
    gnichols
    from Tampa, FL
    I don't know where to get them or if they are still available... but I've seen blank, etched metal tabs (like the HAMB plate) that are designed to fit over a toggle switch and the blank area can engraved with the function. They remind me of something you'd see on a WWII aircraft. But it would be easier ifn you could just get cool knobs with the lettering already on them, eh?. I smell a business opportunity here. Gary
  13. Murphy32
    Murphy32
    from Minnesota
    Laser engraving is cool...
  14. Ned Ludd
    Ned Ludd
    There is an engraving process similar to the laminated-plastic process, but in metal, and sometimes the letters are filled with paint afterwards. One sees it on everything from the back of watches to pet collar tags to trophies to professional practitioners' brass plaques. One can use that process either on little tags with a screw hole on each end, or on plates like Gary describes (they're shaped something like an inverted keyhole) only somewhat thicker to allow for the depth of the engraving. I think that would be most HAMB-friendly of all, and there is still a lot of scope for creativity within the constraints of the process.
  15. I have a vintage Dymo label maker that has stainless steel tape in it.I've printed some labels out but I don't know if the tape is still available.Same as the plastic tape only metal. If you like PM me your address and I'll print them up and mail them out in an envelope.
  16. RocketSled
    RocketSled
    Thanks, safariknut, I don't think I'll be heading in that direction, but I appreciate the offer.
  17. Canuck
    Canuck
  18. Fenders
    Fenders
    electronic transfer letters, as used by ham radio operators for their home built devices (and probably available at electronic supply stores), are good if properly applied and sealed.
    And oh, re "not bad, but...it's missing some I-Don't-Know-What" if you want to sound cosmopolitan you say "missing some ... je ne sais quoi."
  19. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    PetSmart has some nice engraved plaques available. The small rectangular one might look nice.
  20. Canuck
    Canuck
  21. Slonaker
    Slonaker
  22. RocketSled
    RocketSled
    I didn't wanna sound too ejumacated.
  23. Make the blanks to suite your fancy, take them to the nearest "things rememberd" at any major shopping mall. Pick out a font you like and let them engrave it.
    Fast, cheap, and good!!! Most of the time you only get two of those.
  24. twenty gallons
    twenty gallons
    Take the entire plate to a trophy shop and have them engrave whatever you want on it in whatever style of lettering you choose.
  25. pinman 39
    pinman 39
    You might also "ESREVER" Engrave on clear plastic then turn it over for
    a smooth look "REVERSE " . You can then color your letters also .
    FOR SALE 1940 Chev 4 door sedan in Classifieds .
  26. Salty
    Salty
    from Florida
    look up KIRK! and his previous posts on etching the dash of the Legion Special....
    if anything you'll learn something....
  27. _ogre
    _ogre
    from Motown
    my thoughts too, they can engrave your existing plate. rub some paint on it to make the letters show.
  28. RocketSled
    RocketSled
    I wasn't all that happy with Things Remembered...I used them for an award and it looked nice enough, but this ain't that.
  29. RocketSled
    RocketSled
  30. chaos10meter
    chaos10meter
    from PA.
    Maybe try your local jewelry store or watch shop ?
    I have had some really inexpensive pcs. / plates lettered at them.
