Projects 57 F100 project.
Discussion in 'The Hokey Ass Message Board' started by NITMARE, Sep 8, 2009.
  1. NITMARE
    NITMARE
    What's up guys, been awhile with no progress. I will have some more pics up soon. Just doing some tedious metal work now. The floor boards were A LOT rougher then it seemed originally so I'm just doing some cuttin and weldin now. We got hit with 20 inches of snow last week so I'm in no huge hurry to get her whipped out but I will have more pics to come.....oh, and she'll still have 3 pedals ;)
  2. Gimpdad
    Gimpdad
    from Waco Texas
    Has anyone reappropriated and space taken up by the step up into the cab? I need more head room (wheelchair user)
  3. pigpin75
    pigpin75
    [I have been toying with the idea of running some little T04b turbos' on it [/QUOTE]
    I turbo'd my I6 with a T03/4E :D. Do it!!!Put put twin hair dryers on the 272 y block!
  4. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Lowered 2.5 inches, wheels are 16"s
  5. Do a search for Kripfink (Cripfink?). He has the same panel as yours, and his is flat out amazing. He's over in UK, but it's still a LHD rig. PM him-he has LOADS of info and pics.
  6. mbmopar
    mbmopar
    from Canada
    atta boy, nice work so far and keep us posted as usual.
  7. cjmac
    cjmac
    regarding the step removal. go to steve's auto restoration site. shows the build up of gary coe's red 57. I believe he filled in the steps.
  8. NITMARE
    NITMARE
    Remember this thing?.....well it hasn't been totally forgotten. It got put on the back burner as much more important projects needed to get done but I am back to getting the ol truck back on the road. One of the things that stopped the progress in it's tracks was discovering quite a bit of rust in major structural parts of the cab. And the more I dug into it the more I found. So the once seemingly to good to be true deal was in fact not too badly priced.
    Here are some pics from the past couple days of work. As you can see the front cab mounts are 100% gone. most the sheetmetal forward of the seat was gone. And the steps inside the doors that SEEMED solid were a couple layers of sheetmetal pop riveted to the remaining metal. So I've been making new panels. Cutting, grinding, and welding away. I didn't get before pics of the p***enger side but it looked just like the driver side with the exception that the bottom of the hinge pillar had to be totally rebuilt as the doors weight was making it sag. So here's the pics of what I've been up to since Sunday. Going to get all the sheetmetal work done this week and hopefully get some paint laid down and get behind the wheel.
    The driver side as it sits now
    Here's part of what was cut out of the p***enger side. Note, the cab mount laying there. They do sell new ones....for $210 a side! So I made mine.
    New side step
    New floor board ready to be welded in.
    Once side almost done.....now I get to do it all over on the other side.
    This is all the junk removed from the cab so far. Rust, tin cover panels, and the styrofoam was glued inside the doors for sound deadening :roll:
  9. Those steps look great...
  10. NITMARE
    NITMARE
  11. 57blueboat
    57blueboat
    Great thread, enjoyed reading so far, look forward to its continuation now that the weather is getting better.
  12. BEAR
    BEAR
    you know about the pitman arm prob when you flip the axle on this truck right?
  13. NITMARE
    NITMARE
    Yep, going to get it on the road and see if I have any problems and go from there.
  14. BEAR
    BEAR
    man i did my old 60ty last summer and when i got it on the road the thing would get to about 25 and want to drive itself
  15. 53olds
    53olds
    Looks Cool NITMARE, yeah I'mbuilding a 59 f100....
  16. Nice job! they sure do like to rust in those areas. :p
  17. NITMARE
    NITMARE
    Damn, what did you do to address the problem?? Sounds like some guys have problems and some don't...but more do then don't.
    Thanks man
    That's no lie! The door edge of both front fenders is pretty nasty also. I'm going to see if I can save them but it's hard sayin'.
  18. Landmule
    Landmule
    This is a great thread - first one I've read from beginning to end in a while. Nice work on the cab and floor repairs. I love those 57 Fords. It's great to see your ingenuity in taking that truck from a find to the road. Too many projects get stalled out. Great job - thanks for posting!
  19. 100% Matt
    100% Matt
    Updates???? How's it been going?
  20. LM14
    LM14
    from Iowa
  21. 57 cut up
    57 cut up
    from dixon ca.
    time for slammin'
  22. NITMARE
    NITMARE
    It's back! In the past year and a half not much has happened with the truck. A LOT has been happening in my life though. Opened up my own shop specializing primarily in race car/ turbo system fabrication, got engaged, bought a house, and had a little girl....so my personal projects got back burned for a while but I am finally got the 57 dug out of the back room.
    I finally ditched the aluminum 80's truck rims that came on the truck and threw some tires on a set of steelies. The tires are staggered with 235/60 R15's front and 235/75 R15 rears.
    Still need to finish the floor pans I started then it's just a quick bit of re***embly and I am ready to get it on the road. The body and paint look MUCH nicer then they are. The body has a lot of mud slapped in some pin holes and it really needs to be blasted down to bare steel but that will have to wait. The truck looks good from 20 feet and I just want to drive it so the final touches will have to wait.
    The first pic is how the truck sat in the back room for the past 18 months. And the bottom pic is how it sits now after throwing on the steelies with new rubber and wiping off the dust.
  23. thishero
    thishero
    Very nice, and with winter beginning you have several months to really get it going.
  24. 53olds
    53olds
    Nice, good to see this back up!
  25. Wow!!! Im really digging this truck!! Was there any issues with bump steer or any steering parts that need headed/bent for the dropped front axle?
    I'm helping a buddy with his '58 f100 swb doing all the rust repair, body/paint work. We live in the ventral valley of cali, and his truck looks like it spent most of its life at the bottom of a lake!! I pretty much reconstructed the whole front of the lower cab and floor, plus cab supports were nonexistent too. Still got cab corners left before paint prep.:)
  26. NITMARE
    NITMARE
    Thanks guys, I'm enjoying getting back to work on the truck.
    Lead Footed - I will try and see if I can dig up some pics of the modified steering arm on the driver side spindle. You need to shorten it up quite a bit to get the tie rod from the steering box to the spindle as level as possible. However I have since ditched the steering box setup. I'm adapting a mustang power steering rack to the front axle. I will then custom fab a steering shaft that's splined and moves with the suspension. I figure this will eliminate all the bump steer issues and give me true power steering.
    One issue I did run into with the front axle flip was that on REALLY hard bumps the axle would just barely kiss the oil pan on the 272 Y-block. My plan was to sometime down the road put a notch in the pan. After looking at it again today I realized an easier/faster solution would be to just machine some spacers for the front motor mount to raise the motor up away from the axle. From the factory there are two rubber spacers about 1" thick. The factory ones were starting to crack and split anyway. Grabbed some aluminum out of the rack and 30 minutes later I had some solid spacers that were 1 3/8" thick. I also cut some 1/4" thick spacers out of aluminum flat stock for the trans mount. The motor now clears the front axle adequately. I forgot my camera so I snapped a couple pics with my phone. Nothing special here but it gets the job done. One step closer to being back on the road.
  27. jhutch713
    jhutch713
    Great Job, staying tuned.
  28. 76cam
    76cam
    Awsome im glad to see you back on this.And congrats on the engagement and kid!!!
  29. Mart
    Mart
    Ummm.. I'm thinking you just solid mounted your motor - not a good idea. You might want to make some thinner spacers and re-introduce some rubber into the system. You will soon get tired of the noise and vibration that setup will generate. It would be better to get some new mounts and then look at spacing them up.
    Mart.
  30. NITMARE
    NITMARE
    I regularly Sunday cruise my Mustang with a big cammed 408 windsor that utilizes solid motor mounts...and honestly....I never understand why people always complain about noise and vibration with solid mounts. Perhaps I am too unrefined to notice such things. In my line of expertise (high HP street/strip cars) solid mounts are the norm.
