hydralocking your hot rod.....
Discussion in 'The Hokey Ass Message Board' started by brandon, Oct 22, 2011.
  1. brandon
    brandon
    How many times can you do this , before you tear something up...?
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Not many times, the connecting rods don't like being pushed against an immovable object like water. I was in the marine industry and inboard engines would get this all the time when the exhaust manifolds would rust through. It generally resulted in a rebuild or fresh motor.
    Don
  3. brandon
    brandon
    This time was way different than the god knows how many times before.....would have sworn the starter broke off ....:eek:
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    I have seen the starter actually crack off, and stuff like stripped teeth on the flywheel, bent rods, etc. If one of the valves is slightly open the water will go out, but if they are closed, it becomes what you have there.
    How and why are you getting water in the cylinders.......bad head gasket?
    Don
  5. nexxussian
    nexxussian
    Usually F's something up the first time.
    At least when I see it.
  6. brandon
    brandon
    Rain....had a plastic bag over the air cleaner but........usually I catch it at the click....this time was different, but car runs fine.....think im going to pull pan off and take a look.....still have another month of racing to go.....lol:D
  7. gas pumper
    gas pumper
    Do a compression check. You could have one sort of pretzeled rod there and it will run OK. Just a little low comp on one hole.
    I had a 350 with a bent rod. It still ran fine, but it wasn't a race engine. Found the rod bent when I took it apart.
  8. chrisntx
    chrisntx
    from Texas .
    Hydra is a multiple headed sea serpent. You may be thinking of hydr-O-locking
  9. Blue One
    Blue One
    from Alberta
    Harbor freight has small tarps and bungee cords and you could likely get out the door for less than $10 :p And you say this has happened before :confused:
  10. Larry T
    Larry T
    I always thought it was hydraulicing.
    Larry T
  11. olscrounger
    olscrounger
    My 57 fuely did this years ago--the early Rochester units were famous for leaking fuel by after shutoff--was a fresh engine--bent #1 rod and cracked the block!! Fixed it with a electical fuel shutoff in the spider line back then--still inplace and has never happened again.
  12. Yep, had it happen with a 58 and 60 Fuelie that leaked overnight.
    My buddy Joe and I changed the bent rods bot times.
    We went with an electrical micro switch to stop that nuisance problem.
  13. It will bend the connecting rods and turn the crankshaft into a chop-saw !!! A few revolutions with the crank chopping on the pistons and the bottom of the piston is gone. Then all hell breaks loose !!! >>>>.
  14. Larry T
    Larry T
    It's also real rough on bearings. You'll scar a bearing a long time before the rod bends. If it's a race engine, I'd for sure drop the pan and check the bearings. Even if it's just to make it through the rest of the season. The wear pattern on the bearings could tell you something about whether the rod is bent too.
    Larry T
  15. brandon
    brandon
    Fairly easy on a old coupe without a hood.....guess most people keep them in the garage when it rains....or shines
  16. 23dragster
    23dragster
    from U.S.
    Had a case of that happen in a 355 Chevy powered boat once (Hydro-locked). ****ed in some water and stopped the motor. I got lucky and it still runs perfect after a head gasket change and head resurface.
  17. Ole don
    Ole don
    When in doubt, pull the plugs and spin it. I had open top air cleaners and got rain water in the engine. My buddy said "aw crank it up". I pulled the plugs and darn near drowned him. Those air cleaners were replaced that fall.
  18. brandon
    brandon
    Done it so many times, can pulls plugs, spin and re***emble in about 5 minutes....lol . About drown the kid yesterday
  19. Cantstop
    Cantstop
    buddy did it to an OT sunbird, did it going thru a flooded street at about 40. locked up tight. We pushed it out of the puddle and broke out the socket and rachet Not really thinking well, I'd pull one and then tell him to hit it. All fun and games until 200+ degree water blasts you right in the middle of the chest.
  20. Unkl Ian
    Unkl Ian
    Did it once at New Smyrna.
    Push starting is a bad idea.
    Still have the bent rod.
  21. brandon
    brandon
    Bent rods make great column drops....lol
  22. Von Hartmann
    Von Hartmann
    One of the Holley carbs malfunctioned on my Henry J. It filled number 8 cylinder with gas when it wasn't running... when I went to start it 'chunk!' that was it for the rod. It didn't damage the crank or block though.
    I would be very nervous about running a motor that was hydrolocked (I thought it was hydrauliced too). In my case, the rod bent and shortened the stroke so much that the piston wedged against the crank counterweight. From what I have been told, it can also crack the block, head, or damage the crank.
    The rod from my Henry J. 327 chevy.
  23. brandon
    brandon
    Did a compression test today....4 were 190.....1 was 185...1 was 175....1 was 155....and last was 150....the two 150's were cylinders 7 and 8....how much is not right..?:)Figure 35 - 40 is probably too much of a jump....lol
  24. Don's Hot Rods
    Don's Hot Rods
    from florida
    150 and 155 are getting down there. If nothing else, they sure aren't contributing a lot of HP to the mix. They say 10% variation is ok, maybe even 15%, but I like them to be as even as possible.
    Don
  25. brandon
    brandon
    I was liking the 185/190 range....all numbers added and divided gave me average of 175....so the 150's are still below the average....time to pull the pan
  26. super plus
    super plus
    once
  27. olscrounger
    olscrounger
    My 57 fuely leaked by and did this as mentioned--bent the rod and broke the bore in #1--junked that one and started over
  28. Hnstray
    Hnstray
    from Quincy, IL
  29. bobss396
    bobss396
    I use the 10% rule too, close enough for hand grenades, very fitting in this case. Take it apart...
    Bob
  30. brandon
    brandon
