Installing "blue dots" in lens
Discussion in 'The Hokey Ass Message Board' started by LostHope, Nov 15, 2011.
  1. LostHope
    LostHope
    I guess i cant start a thread in the tech section since im not a paying member but thought someone might be interested in how i did it so ill post it here!
    Well i picked put some blue dots and decided to try and install them on my old lens, ive drilled lens before but it is always risky chipping or cracking them,i know from experience! So i tried a new technique which worked well for me that you guys might like it....
    Stock lens:
    On these lens there is round ridges on the back side the bloue dots need a 15/16 inch hole and the(hard to see) the deepest ridges in the center are 1 inch so lining up the center was easy:
    I tool i will be using is socket on a extension that measures 15/16":
    Over at the stove i heated it up:
    And then line it up right in the center and let it melt into the lens..This part stinks a little!......i had to reheat and melt a couple times to get all the way thur:
    next was install the blue dot's:
    Twist the prongs with pliers to hold the gl*** in and everything to the lens:
    Presto!!:
    Installed:
    Apply power:
    I couldnt get a good angle with the camera with out it blinding the picture showing the blue dot part but they are quite blue! ill have to get a night time shot!
    Hoped you guys liked it!!!
    Hdonlybob and 1Nimrod like this.
  2. Edelbroke
    Edelbroke
    Never liked them. just anouther excuse to get pulled over
  3. Thats good tech.
    On a gl*** lense you can use your bead blaster. Cover the lense with duct tape - maybe two layers. Cut a cricle from the tape the size of the hole you need. Fire up the blaster and blast away at the exposed surface! Slowly and carefully. I did this on our 36 gl*** tail lights and it worked swell....
    1Nimrod likes this.
  4. Well I guess if you don't like them don't use them pal.
    Well done, a very informative thread, Ive used a drill before with very mixed results so next time Im going to use your method.
    1Nimrod likes this.
  5. LostHope
    LostHope
    My thread wasnt meant for you to like or not like anything, it was meant to be informative!
    And did you notice i said old lens?who said you cant drive with stock red lens and swap blue dot lens on when your at a show? thanks tho for your meaningless comment.
    qicvick and 1Nimrod like this.
  6. cookiemonster131
    cookiemonster131
    never thought of doing it that way. good job!
    qicvick likes this.
  7. 28 jalopy
    28 jalopy
    from arizona
    Great idea! So simple the thought whizzed p***ed most of us back in the day.
    1Nimrod likes this.
  8. Edelbroke
    Edelbroke
    Life is full of meaningless coments. Get used to it. Maybe clean the stove before you use it in your tech thread
  9. swimeasy
    swimeasy
    ^^^^^^^ What a JERK!^^^^^^^^
    1Nimrod likes this.
  10. 61TBird
    61TBird
    Great Job LostHope! They do look good regardless of what some people think...
    I guess was lucky that my Taillights in the Tbird are made for Blue Dots :D
    I used a small drill then a Dremel tool with a sanding wheel...
    As for getting pulled over...Never got pulled over in the 3 years they've been there.
    I've ran Blue Dots in 3 other Cars I've owned and have only been stopped once and issued a "fix-it" ticket.
    I went home,swapped out the lenses with an extra set,drove to the nearest CHP office and had the ticket signed off the same day :rolleyes:
    1Nimrod likes this.
  11. ummm, chicken...
    It's cool to see it done another way. Good job!
    1Nimrod likes this.
  12. dirt slinger
    dirt slinger
    Ive always liked bluedots, good idea!
  13. 40Standard
    40Standard
    from Indy
    I had blue dots on a few cars, never had a problem running them
    1Nimrod likes this.
  14. lango
    lango
    from Georgia
    Yardbirds are cool as hell. Blue dots are neat if that's what you like.
    1Nimrod likes this.
  15. jcmarz
    jcmarz
    from Chino, Ca
    Good idea but what if it's a gl*** lens??
  16. rusty rocket
    rusty rocket
    I drilled my gl*** 47 ford taillights with a chunk of 3/4 copper pipe chucked in a drillpress using valve grinding compound as a cutting solution.
    1Nimrod likes this.
  17. swissmike
    swissmike
    Harbor freight makes diamond coated hole saws for gl*** which I used before on a gl*** lamp shade I needed a hole drilled. You will need a drill press and go slow witha lot of water for lubrication.
    1Nimrod likes this.
  18. LongT
    LongT
    Use the water BEFORE the gl*** gets hot. I know from experience.
    Bill
    1Nimrod likes this.
  19. '51 Norm
    '51 Norm
    from colorado
    Great idea! So why didn't I think of it before I broke my lenses?
    I did eventually drill mine with a hole saw; cleaning up the edges with a Dremel tool.
    Your way looks lots easier with much less chance of breakage to boot.
    1Nimrod likes this.
  20. dclickster
    dclickster
    You can also line the housing with tin foil for extra bright illumination,
    1Nimrod likes this.
  21. pasadenahotrod
    pasadenahotrod
    from Texas
    For the brightest taillamps, change from 1157 bulbs to 2357 and paint the inside of the taillamp housing gloss white, I use rattlecan "Appliance White" usually the cheapest everywhere.
    The 2357 bulb is far brighter on the stop circuit than the 1157.
    1Nimrod likes this.
  22. 1959apache
    1959apache
    ^^ Wow... you are a douche
    Back on topic... LostHope, great idea and execution. You made it look so stupid easy its unreal :p
  23. LostHope
    LostHope
    Thanks for the positive comments guys just trying something new to see if it would work and help other car guys out,rather then bagging on their dirty stoves.......I guess id rather be working on cars then cleaning oh well guess im Lucky to be a Loser(avatar)hahaha :D
  24. derbydad276
    derbydad276
    cool now i know how to do it
    1Nimrod likes this.
  25. Bud Crane
    Bud Crane
    No one seems to offer a '32 Ford lense with the blue dot over the tail light bulb, only over the brake light bulb. I didn't want blue dot brake lights, so I drilled mine with a copper tube in a drill press. Now I think maybe I'll use one over each bulb for maximum effect.
    1Nimrod likes this.
  26. Excellent.
    Thank you!
  27. DirtyJohn
    DirtyJohn
  28. The_Monster
    The_Monster
    I love the idea, very cool tech! I also dig on those old chevy trucks, good job dude! I happen to love the look of bluedots and run them myself.
    On gl*** lenses, I did a tech on that. It may not be the best tech, but it worked for me.
    http://www.jalopyjournal.com/forum/showthread.php?t=184213
    And as far as this guy
    According to Oregon law:
    <TABLE dir=ltr border=1 cellSpacing=0 cellPadding=7 width=90><TBODY><TR><TD height=20 vAlign=top>
    Are blue or purple dot inserts in taillights legal?
    </TD></TR></TBODY></TABLE>
    <TABLE dir=ltr border=1 cellSpacing=0 cellPadding=7 width=193><TBODY><TR><TD height=39 vAlign=top>
    On a motor vehicle that was manufactured before 1959, the taillight or taillight ***embly, if the taillight is combined with another light, may contain a blue or purple insert of not more than one inch in diameter.
    Edelbroke, check your local laws. I noticed your cars listed in your profile are '55 and older, so you may be ok. Course, if you just dont like them, then thats your choice. But then... why open a tech thread on bluedots and post a response? And you're gonna break this guys balls about how clean his cook top is? Really?? hummm...:rolleyes:
    1Nimrod likes this.
  29. n.z.rodder
    n.z.rodder
    Great stuff. I have a set to go in my '46 Chev, mine are gl*** so i'll be trying the copper pipe and valve compound on a couple of old ones first before I attack my brand new set.
    Scotty.
    1Nimrod likes this.
  30. greazy john
    greazy john
    simple and cool ..just one more easy way to add to the list of things you never seem to remember
    GREAZYHUBCAPZ CC EAST TN
    1Nimrod likes this.
