COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. Get Your RadioActive
    Just picked up a 1952 International COE
  2. LN7 NUT
    LN7 NUT
    Got any photos of it to post?
  3. The37Kid
    The37Kid
    Some day I'd like to have an Oval Grilled '40 Ford COE, but saw a nice looking 1950 COE at Hershey last month. Is there a big differance in inside cab room on the 40 vs 50 cabs? What are other plus and minus features?
  4. Gromit
    Gromit
  5. The Continental
    The Continental
    from Texas
    When were the last COEs?
    This one is not a COE, but a successor of sorts. Still runs and drives, anyone interested?
  6. evs1
    evs1
    The last COE's were probably the Fords built up till the early 70's. I always called them half-cabovers. Can't think of any others right now. Anyone else?
    After thinking about it, I suppose these count too. Up into the mid-80's.
  7. Bama Jama
    Bama Jama
    The top Ford is an LCF and the bottom one is a Tilt Cab. The tilt cabs have always been called cab overs.
  8. nyvp
    nyvp
    starting initial work on building a COE. your your opinion what the best/easiest ch***is to build on? RV E350 vans , stepvan
  9. LN7 NUT
    LN7 NUT
    it would depend partially on what your COE is, I measured my 56 Mercury COE and it will fit quite well on an E350 ch***is by the looks of it, but an older COE might be too small.
  10. iwanaflattie
    iwanaflattie
  11. RMR&C
    RMR&C
    from NW Montana
    This is pretty cool.....'38 Ford derrick truck. The platform extends upward for working on power lines, etc. I stole the pics from the Ford truck site (FTE)....
  12. nyvp
    nyvp
    looking at a ford f500 coe low 50's like 52 or something.
    does everything line up for steering and such in the e350??
    I'm worrying more on the front steering wheel and engine than the rear/frame i can extend the frame easily.
    something like this
    http://cgi.ebay.com/ebaymotors/2003...?pt=Buses&hash=item25692375d3#ht_18487wt_1165
  13. buggy5872
    buggy5872
    Here's my 57 so far... the members of the COE group have seen it
  14. nyvp
    nyvp
    what did you use for the back second doors?
  15. buggy5872
    buggy5872
    those are the back portion of 2 doors off a regular cab 55-59 truck.
  16. Gremlinguy
    Gremlinguy
  17. LN7 NUT
    LN7 NUT
    Nice back doors, they look a lot like mine!
  18. buggy5872
    buggy5872
    I was going for as stock looking as possible. I just dig your stretched burb. That coach company put out some nice ones.
  19. junk-junkie
    junk-junkie
    from Arvada CO
    I recently picked this up. It's an unfinished project with a Toronado clip in front. If anyone has suggestions on how to hook up a steering column to a box that is pretty much right under your feet, I'm all ears. Is there an exceptionally wide power rack that I could use to replace the Toronado center link? If I could install a rack and rotate it so the input shaft is pointed forward, that would get me most of the way there.
  20. Baron
    Baron
    Here is one way to do, although very expensive.
    http://www.wizardsteerclear.com/
  21. kooscoe
    kooscoe
  22. LN7 NUT
    LN7 NUT
  23. Baron
    Baron
    Look at using a 1999 Chevy van steering box to see if that may work for you. Box points straight up in the iar and drag link goes side to side.
  24. phat rat
    phat rat
    Put a picture on here of what you have to work with and around.
  25. bfreehill
    bfreehill
    from boulder,co
    Test fit my dodge cab on my newly acquired 73 chevy / Mitchel motorhome ch***is. Im in a build race with the ford guy in Arvada (junk-junkie), my steering should be much easier to deal with. : )
  26. b-bop
    b-bop
  27. kooscoe
    kooscoe
    Realy Nice Photo :cool::cool::cool:
  28. nyvp
    nyvp
    wow great pic they almost look fake.
  29. US_Marshall
    US_Marshall
    The 98+ Isuzu Rodeo has a rack&pinon the has the input shaft facing forward and a angled reverser box to get the steering column to reach it. I'm not sure if it is what your looking for though.
    not my picture
  30. daddio211
    daddio211
    Best part of this pic is the '60 Chevy behind the COE... anyone else see that?
    Not to demean your COE man, I just LOOOOOOVE '60 Chebbies! :)
