Webber carbs on a SBC
Discussion in 'The Hokey Ass Message Board' started by swimeasy, Nov 17, 2011.
  1. Ebbsspeed
    Ebbsspeed
    Weber. I'm kind of **** about the spelling, because my name is Bob Weber.
    A lot of times when I am at an event or ordering something, They ask for my name, to which I respond "Bob Weber". Often I will get a question in return: "Is that one 'b' or two?" When I say "three" it really screws up their day.
  2. ibcalaveras
    ibcalaveras
    Here a 8 IDA set up the my younger brother put together. the other is a 4 IDA on a tunnel ran intake.He works for pierce manifolds in Gilroy Ca.
  3. 30tudor
    30tudor
    You did make (cast?) those adapters eh metalshapes? Nice way to go after that, smart thinking. How does it run, flow? Not too many SM's around anymore to pick over.
  4. When is to much too much....?:eek: I don't think I could see that many cfm going through that 409??? LOL it is different... kind of like running a pipe organ for an engine.
    How many of those carbs are actually functioning? How many vacuum leaks did you have to chase before you could get it to idle?
    At least there is a common plenum for each set of 4 carbs
    About the time I would have to tune those carbs... I would've pealed them off and got the Hilbourn to run on the street... I think it would've been much easier and just as impressive!
  5. metalshapes
    metalshapes
  6. Normbc9
    Normbc9
    I have a set of three on a side draft Chevy 292 used as a daily driver and another on a similar engine for racing. Both are trouble free dependable and as pointed out; yes, expensive. BUT... you get what you pay for. How many Chevy inline 292's are out there dusting many varieties of small block V-8's? The Weber setup is easy to mount and to work with.
    Normbc9
  7. feeeser32500
    feeeser32500
    from PA
    i run 4 48 idfs on a 500 caddy. the intake i made with individual runners 1 carb per cylinder its alot easieser to set up than what everyone says the car runs perfect put about 1500 miles onit since i finished it in june. ther is no problem running them on a sbc. i got mine from inglese they were $400 a piece
  8. GassersGarage
    GassersGarage
    A guy I know did that to a street/strip car. When it was tuned for the street, it fell on its face at the track. When it was tuned for the strip, it would load up on the street. He ended up going back to a single 4 barrel.
  9. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    I love WEBERS. Easy to play with and change jetting. IDAs are the ultimate. Dont worry about having too much carb, I have two 40mm IDFs on a 108ci 4 banger and they work fine (like having a 650-750 cfm holley). Alot of manifold/carburetor theory and math doesnt work the same for IR (isolated runner) systems like they do with a regular "plenum" style system. Oh, and Weber only has 1 "b".
  10. Dellorto quit manufacturing carbs a few years back, and production is now solely Fuel Injection.
    I was in the high-po VW field for many years, and found that the Dellorto was a lot more tunable than the Weber, as a general rule. Theres a lot that can be done to the worn-out Italian ones now, re-bush the throttle shafts, re-configure the ramp underneath for the accelerator pump ( a very common wear area), but it isn't cheap, it's somewhat labor intensive (spelled $$$) to farm out the repairs.
    That being said, I have a set of 48 IDA's on my 2 liter VW engine, Italian ones, and a guy in Salt Lake City drilled the 3rd progression hole in for me... I can go from 19 to 90 in 3rd gear, with no pops, farts, hiccups, or anything... it just pulls like a freight train (but a little one...)
    CB still has jets and rebuild kits for the Dellorto's, but last time I talked to Rick, the owner, he didn't have any more "Dells" for sale, they were all gone...
  11. propwash
    propwash
    from Las Vegas
    Here's my contribution to the Weber® collection.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    simply beautiful!!!!!! dave
    volvobrynk likes this.
  13. big duece
    big duece
    from kansas
    Here is my set of IDF's. Building a IDA setup too...
  14. Kerrynzl
    Kerrynzl
  15. mike c
    mike c
    I have a book how to build & power tune weber & dellorto by Des Hammil. It has been the best book for understanding weber's tuning. It is mostly tuning of 4 cylinders. Hope it will help someone. Mike
  16. racemad55
    racemad55
    Do a search on the H.A.M.B. cl***ifieds for "weber look a likes"
  17. swimeasy
    swimeasy
    Wow! I have ordered a book and have now learned to spell "Weber". I want a setup like this!
  18. One thing I found when tinkering with these carbs was that I got better all around performance on the street with the smallest 37mm chokes in the IDF's and IDA's took less tinkering for street use mainly because their choke sizes can run smaller. Larger chokes are fine if for high rpm engines but I don't see many of those running the streets reliably... or for very long!
    The most important piece of information I can give anyone running Webers is to run large fuel lines and "never" exceed 3 1/4 lbs of fuel pressure... in fact if you can run 3 lbs and not starve the carbs on long full throttle blasts that would be perfect! You're looking for high Volume to the bowls not high Pressure!
  19. Deuces
    Deuces
    Go on ebay and type in "Weber side draft intakes" Let us know what you find!!
  20. powers524
    powers524
    from mesa
    jiminglese.com has them
  21. metalshapes
    metalshapes
    Thanks. :)
  22. Lotek_Racing
    Lotek_Racing
    The nicest thing about Weber carbs is the fact that you can change the venturi size in the carb to match your airflow requirements.
    They offer more tuneability than any other carb I've dealt with.
    Shawn
  23. Deuces
    Deuces
    I have 4-bbl carb that has interchangable venturies also... It's called a "Gold Claw"...
  24. Lotek_Racing
    Lotek_Racing
    Never heard of a "gold claw" until now.
    Googled it, looks pretty cool.
    I wonder if there will be any support for them in the near future.
    Shawn
  25. bonez
    bonez
    from Slow lane
    :O
    Thats actually a 4 DCOE+4IDF, but it is still crazy.
    I'd really like to hear it, but mostly does it really need 8 of those?
    The roadster i know, i got a few pictures, that manfold w/ the 4 DCOEs is awesome.
  26. If you run a Inglese set up with 4 48 idf's on a sbc. What distributer would you recomend... What did you guys use, Its a tight fit...
  27. vrod64
    vrod64
    from Katy,Texas
    Louvers is correct. Webers whether IDA or IDF are great. I run both and prefer the race proven IDAs.
    Run 4 48s on a lil 327. Most critical issue is have a cam ground specifically for Webers. (Very little valve overlap) 3.5# fuel pressure. I run 100 LL Av Gas in mine and the perform flawlessly. Initial tuning is required , but pretty straight forward.
  28. vrod64
    vrod64
    from Katy,Texas
    I use a Unilite on one motor and a Joe hunt magneto on the other.
  29. Harell Los Angeles
    Harell Los Angeles
    I have run 48's on my 327 for a few years now, I love them. The whole setup came from Inglese. The jets have the numbers ground off of them, I guess that was common in their old days, the guy didn't want you to have all the info on it. That is what I was told on the phone when I called them. I love it and would definitely run them on other projects.
      81.5 KB
