early ford drum brakes with 5x4.5 inch bolt pattern
Discussion in 'The Hokey Ass Message Board' started by windsor mike, Nov 18, 2011.
  1. windsor mike
    windsor mike
    i was wondering if there is any way i can convert my model a front brakes from 5x5.5 to 5x4.5 inch bolt pattern? i want to keep the front end drum but i dont want to have to run the old rims. just wondering if there are any other brake setups that will work on early ford spindles.
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    The easiest and cheapest way to do this is with wheel adaptors...5 on 5 1/2 to 5 on 4 1/2 bolt pattern. They will extend the wheel out about 1 inch, but are inexpensive. Speedway probably sells them.
    kidcampbell71 likes this.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Well, what rims do you want to run? Late model Ford full size pickups are 5 on 5.5" until the late 80s-early 90s.
    Depending on what spindles you have, as in 37-41 or 42-48, there are beaucoups of disc brake conversions, but none for 28-31, 32-34, 35-36 spindles.
  4. windsor mike
    windsor mike
    i have a set of 14" chrome reverse with coker white walls that i want to use. i know i could use adapters but was wondering if there was another way
  5. chaddilac
    chaddilac
    Yea have them drilled to 5x4.5.... A machine shop can do it!
